Red screen my hp vs15 is stuck red(screen)
  • 65 Answers
1. check VGA cable Red signal cable is it fine or not, Checking procedure Ground to R,G,B sinnal wires From VGA connector Pin no 1,2,3 In resistance 75 Ohms It is OK
2.check loose contacts CRT Neck board
Posted on Oct 07, 2008
IBM 8303 DOESN'T SUPPORT MY FLATSCREEN HP VS15
2 steps:
1. plug the hp vs15 into another computer and see if it works, if not could be a bad monitor.
2. If you have the old monitor, plug it in to the IBM computer and in windows lower the resolution down to 640 X 480. Now turn off the computer and plug in the VS15 monitor. If resolution was an issue it should work now.
Hope this helps
Jan 31, 2012 | IBM Computers & Internet
I want to connect my playstation 3 to my hp vs15. But after doing a little bit of research i am asked to change my display mode in order to get video from my playstation 3. hence my question is how do...
You change the video resolution at the video source, in this case, your PS3, not at the monitor. VS 15 has 1024 x 768 60Hz Maximum Resolution, so your PS3 cannot be higher.
You need to google 'how to change PS3 video resolution' If the PS3 resolution is set to high, the VS15 will display Out of range/format/video not support.
http://www.fixya.com/support/r4873371-fixing_out_range_format_not_supported
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
May 20, 2010 | HP vs15 15"LCD Flat Panel Monitor
Monitor changing colors hpvs 15
Try the monitor with a different computer. If it work, then the problem is the other PC, if it does not work, then your monitor is failing.
good luck
Dec 13, 2008 | HP vs15 15"LCD Flat Panel Monitor
NEC Accusync LCD92VM monitor
Hmmm, seen this one before, did you recently clean the screen with some kind of liquid cleaner/spray? I had to repair a monitor with same problems, some fluid had leaked onto the switch board....If not, any key's stuck or pressed in too hard?
May 19, 2008 | HP vs15 15"LCD Flat Panel Monitor
HP vs15 Flat Monitor
It depends what computer you have, and what version of Microsoft you have. for those of you with the Presario SR1650NX computer, here is the Latest driver: Click. For the earlier driver: Click.** to download drivers for you computer go to your computers company website (Gateway, HP, Compaq, Etc.).
**I Recommend downloading the older version first, and if it doesn't work then download the latest.
Oct 06, 2007 | HP vs15 15"LCD Flat Panel Monitor
Hp vs15, black screen, power light goes on and off like it is in sleep mode
Monitor is dead. The LCD inverter board probably went out and needs replacing. More than likely, it will cost you over $100 to get it fixed. It's better to spend the money on a new monitor.
Jul 13, 2007 | HP vs15 15"LCD Flat Panel Monitor
Black horizontal line
The LC display is bad. The monitor will have to be replaced.
Jun 24, 2007 | HP vs15 15"LCD Flat Panel Monitor
Computers & Internet Logo
958 people viewed this question
David Payne
David Payne
