Question about Echo CS600P Gas Chainsaw 20 Inch
Brand new chain saw bought from reputable dealer. The CS600. It was missing a part on the oiler and dealer fixed. Now the clutch overheats badly, to the point it acyually smokes. Does Echo have a policy for lemons. I think the saw could potentially be great, but I am not happy with all the problems this one is having.
  • Echo Master
  • 2,239 Answers
Not had a lot to do with Echo, but have always heard good reports, for smoke to come from the clutch cover the clutch would have to be slipping, either due to running with the chainbrake on, or useing with a very blunt chain. To make sure the brake is off, pull the hand guard fully back to the top handle.
Posted on Apr 04, 2011
Testimonial: "Thanks for the response. Agree that the clutch must be slipping. I have to believe it was not assembled correctly or a bad cluch. Thanks!"
The chain keeps falling off my brand new Poulan sixteen inch blade chain saw
It is possible they gave you the wrong chain for the saw. I would take check the manufacture to see which chain you need then check the numbers on your chain. Other thing it could be is the washer on the clutch may be missing. Either way, it is a new saw, I would take it back.
Apr 01, 2013 | Poulan Garden
Ms 170 leaks bar chain oil out bottom, no oil on chain
Your clutch drum bearing has gone bad, letting the clutch drum to move around and cut into the oiler behind it, so now it just pumps the oil out that hole. You have to get that fixed to use the saw, otherwise you're going to cause catastrophic damage to the saw very soon.
Sep 25, 2011 | Stihl 16" Chainsaw Bar Chain Saw 018 025...
I have an MS660 and the bar oiler has not functioned on my last take of fuel. is there a way to trouble shoot the oiler problem without taking it into the shop. I hate to loose a weekend of cutting.
Start by removing the bar and chain and start the saw with a full tank of fresh Stihl bar oil.
If you are or have used a low grade oil or used oil you may have worn the oiler out.
Watch for oil to come out of the oil port.
If it does at a steady rate of about 10-21cc per min at 13,000 rpm or about 1/2 oz. per min then the bar is clogged with saw dust and needs to be cleaned.
If oil does not come out of the hole you will need to trace back the problem. the oiler is under the clutch. To remove the clutch remove the c clip that holds clutch drum ,washer and bearing remove those comonents and you are to the clutch. the clutch comes off reverse threads (right to loosen)
The problem is that the engine wants to turn, so remove the spark plug and put something soft in the sparkplug hole like 2 ft of starter rope. the clutch will come off and you will be able to see the oiler gears and hoses. worst case you will need a new oiler which is held on with a few t-27 screws.
Again I stress the point of good oil.
find parts at a local dealer like www.arcolawn.com
joe
Feb 19, 2011 | Stihl 16" Chainsaw Bar Chain Saw 018 025...
I do not appear to be getting oil to my chain on my Stihl 028 chainsaw, can you advise me how to fix this ? I thought I may have the chain too tight but having used a chainsaw for many years, I thought it...
Hello Tom;
This is an OM for a Stihl 028. I did not see an oiler adjustment. It does have the "Master Control Lever" and from what little I know of Stihl this is a source of headaches if not used properly. If you are not familiar with it suggest you read everything the manual has to say about it.
http://www.stihlusa.com/stihl_ownersmanuals/STIHL028_with_safety_manual.pdf
Oil System Plugged:
  1. Remove the clutch cover, bar, and chain, clean the bar groove, any holes and passages on the rear of the bar (both sides, consider rotating the bar), if equipped with a sprocket nose ensure it rotates easily at least one complete revolution. Clean the saw oiler hole and channel. Insert a blunted, hooked piece of wire through the oil filler hole and pull the hose in the oil tank out. Pay attention to the screen or filter on the free end (clean or replace, difficult to determine serviceability). Start the saw and see if it oils when revved up (oozes down side of saw). If yes reassemble your saw. If no, continue with 2.
  2. Work your way through the linkage (use IPL to identify components and locations) cleaning and replacing any defective parts as you go. Carefully check the hoses for cracks especially at bends and connections. If equipped with an oil pump it is usually behind the clutch (clutch is a left handed thread). Please make extensive notes & some digital pictures will help during reassembly.
If it does not oil on completion of 1 it is most likely a bad oiler or worm gear (see IPL). I has a gear driven oil pump but because it is Stihl and they claim proprietatry right you cannot find an IPL on line. You must also find a Stihl dealer for new OE parts.
ArboristSite Chainsaw thread (free to join)
http://www.arboristsite.com/forumdisplay.php?f=9
This thread is discussing an oiler falfunction on a similar saw, I think Fish is a Stihl dealer, is very helpful and his advice is proven.
http://www.arboristsite.com/showthread.php?t=121837&highlight=028+oiler
You can get IPLs and if the chainsaw Gods smile a shop manual or two here (please do a search and PM someone that has replyed to a similar request):
ArboristSite Beg for manuals thread (free to join)
http://www.arboristsite.com/showthread.php?t=72322
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Mar 13, 2010 | Garden
Husqvarna chain saw oiler problem
I fear you are correct about the oiler problem. I see a lot of oiler problems on these saws. Sooner or later Husky will have to address it. Ask the dealer about modifying your oiler; the 350 has an adjustable and might fit 1 or both of these saws. I think Husky needs to admit the nonadjustable is a mistake, and come up with a fix.
If you want to do some research start with the IPLs here:
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – useful when downloading IPLs and Manuals
06 1500198
06 = year produced – 2006 (single digit before 2000)
15 = week produced - March
00198 = 198th unit Husky produced that week
Please post back (below) with what happens at the dealer. Take your buddy and his saw with you! Good Luck. HTH
Lou
If Husky starts modifying all these with 350 oilers I want compensation...LOL
Feb 17, 2010 | Husqvarna 450 e-series 18" Chain Saw
I need remove the clutch on my 2150 poulan pro chain saw, so I can fix the chain oiler.
Good film. Make certain the piston is above the exhaust port or the rope can fall through and damage the piston above the piston ring. When started it comes apart and destroys the saw.
The oiler worm gear is behind the metal cover visible once all clutch parts are removed. HTH
Lou
Jan 02, 2010 | Garden
Chain binds saw dies saw runs fine with out bar chain on clutch bearing? help poluan 3416 16 inch 34cc
Is your chain oiler working? If you're using saw a lot and the oiler isn't working properly the chain will get hot and bind up especially if the chain is too tight. Tighten the chain so that you can squeeze it in the center of the bar, with your second and third finger on the sides of your fingers (not a very strong grip) and you should be able to almost pull the chain out of the bar guide but not quite. Clean the oiler hole in your bar where the chain oiler injects oil into the bar. You can also run your saw without a bar and chain and see if the oiler is pushing oil out of the injector.
Dec 04, 2009 | Tools & Hardware - Others
Not getting oil to chain....oiler working could bar be bad?
Remove the bar and verify the oil-hole in the bar is clear using air gun and/or spray-lube.
Verify that the bar's oil hole mates to the saw's oil port. (Is the original bar installed?)
If these things checkout OK and you still have problems, have a reputable shop delve deeper into it. ASK the shop if they will check it and call you BEFORE doing a repair.
My shop will give a diagnosis and estimate for $10.00 on hand-held products.
Hope this helps.
Oct 04, 2009 | Husqvarna Chain Saw 20" Bar
Stihl 024 chain oiler is not function, how to troubleshoot or repair
This isn't an easy repair. You'll need to take off the pto clutch and that might not be easy. The oiler is behind the clutch. There is a drive gear behind the clutch that drives the oiler. You should check to make sure oil is getting from the reservoir to the pump. That is easiest to do with the pump off the saw. If you take it to your local Stihl dealer, unless the pump is shot, this is not a complicated or expensive repair.
Jun 14, 2009 | Husqvarna Chain Saw 20" Bar
Chain oiler
Depends on the vintage, turn the saw upside down and you can see a screw to turn, 3 settings, right under the clutch and shaft. use a screw driver if it is adjustable. I like to keep mine set on high, oil is cheaper that new chains and bars. Use a bar oil, not old used motor oil.
Nov 01, 2008 | Husqvarna Chain Saw 20" Bar
Echo CS600P Gas Chainsaw 20 Inch Logo
197 people viewed this question
Top Echo Garden Experts
Jim London
Jim London
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you an Echo Garden Expert? Answer questions, earn points and help others
