I have an Augen netbook and though fully charging the battery, the indicator says it's only half charged once I disconnect the charger. I need to fix this, if possible as I bought it on sale and thre are no more at this price.
  • mikamaj Apr 04, 2011
    anything else i should look at? the numbers do match.
  • 124 Answers
Recommend you compare the Volt & Amp reading on both the A/C adapter & Netbook.
The Volt & Amps will be on the underside of the netbook.
The Volt & Amps will be listed on the A/C adapter (wall charger).
Compare the numbers:
Example: 19Volts / 3.9 Amps
These numbers SHOULD match between the netbook & A/C adapter.
Posted on Apr 04, 2011
Testimonial: "THanks!"
    They match. Is there a further suggestion o thing I can rule out?
  • laptopbonker Apr 04, 2011
    If battery is NOT charging to full capacity, then would suggest you pursue repairs/replacement under warranty provisions. Contact manufacturer and/or the retail store whom sold you the netbook.
I bought a Ryobi 12V drill w/ lithium charger. Green light on charger never went solid....continues to blink & fade. Does this mean its in the energy saving mode? Is it fully charged?
How long have you left battery on charger? It will take about 3 1/2 hrs to fully charge. t is probably not a good idea to leave the battery in the charger for long periods of time though, so once it is fully charged put it back in the drill. When fully charged the green led will turn solid. This link will have more info on charger and battery.
http://powertool.manualsonline.com/manuals/mfg/ryobi/130155001.html?p=2 C
Apr 19, 2017 | Ryobi Drills
I have a Augen Genbook I have been charging for about 24 hrs and it will not com one what do I need thank you
Lots of things to try.
  • Remove the battery plug it in and try to power on.
  • Remove the battery and charging cable, hold the power button for about 10 seconds then replace battery and charging cable and try to power on.
  • replace the charging cable and/or battery
  • Do you hear any sounds when you try to power on?
  • Anymore details would help a lot power issues can be as simple as charging cable not connected properly to system board issues.
Aug 08, 2016 | Augen E-Go OE-A736 AKARM ARM926-AK7802...
Can not run netbook off battery even though battery shows fully charged' When charger is removed netboook will not turn on
Make sure the battery is fully inserted and clicks in to the netbook body. Your battery may also be showing that it's charged but is actually dead. Try a new battery and see if it solves your problem.
Jul 04, 2013 | Wolvol Mini NOTEBOOK COMPUTER Laptop...
Samsung N145 Plus battery charge failure
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced.
Sep 03, 2012 | Samsung Computers & Internet
Ryobi charger model # 140295003 has a red and yellow light. When charging red light is on what does the yellow light mean? Also how long should the battery be left in the charger?
Completely wrong. Quoting from the user's manual:
"The charge indicator light (LED), located on the charg- ing stand, will light up red and glow when the char- ger is properly connected to power supply. This light indicates the charger is operating properly. It will remain on until battery pack is removed from charging stand or charger is disconnected from power supply.
After normal usage, 3 hours or less of charging time is required to fully recharge battery pack.
If both red and orange LED indicators glow, the battery pack is deeply or completely discharged, and 6 hours or longer of charging time is required to fully recharge battery pack.
Note: If charger does not charge battery pack or orange LED continues to glow after more than 30 minutes of charging, return battery pack and charging assembly to your nearest Ryobi Authorized Service Center for electrical check."
So to summarize: red = charging. orange (yellow) = fully discharged battery. orange after 30 minutes - bad battery or bad charger.
Apr 23, 2011 | Garden
Iphone 3g proper charging
Once you purchase the iphone,dont use it yet.Instead of using it right away,kindly charge your IPhone with the wall charger for 3 hrs.Please dont use the Iphone while charging.Kindly check always if the battery is full.Once its fully charged then that's the time that you can use the iPhone. Once fully charged, let the iPhone's battery fully drain.Please keep the iPhone off for 2 hours.Fully charge your iPhone and allow the battery to rest in the fully charged state for two hours. (You may use your iPhone during this time as long as the iPhone is plugged in).Repeat the third and fourth step a maximum of three times if you feel your battery indicator is inaccurate.
Here are some tips for your everyday charging for your IPhone:
#1 - Charge your iPhone throughout the day when available. Charge EVERY night, regardless of charge level. This will keep your battery active, which is healthy for the iPhone's battery.
#2 - Use a wall charger or car charger w/ rated output 5V 1A. Computer chargers might not charge when the computer is in standby mode.
#3 - You cannot overcharge your iPhone. You don't need to disconnect the iPhone from the charger after it's done charging. Once fully charged, the iPhone will run strictly off of AC power and will not damage the battery.
#4 - Every two months, make sure you fully charge and fully drain the battery, in one cycle. This calibrates your battery indicator. If you fail to do this, your indicator will become inaccurate. Calibrating your battery does not improve battery life.
#5 - If you ever need to store your iPhone for any reason, make sure your battery is stored @ roughly 50% and in a cool environment.
#6 - Always charge your iPhone out of its case (assuming you can easily remove the case). Charging your iPhone inside your case will make the iPhone hotter, which is bad for the battery.
#7 - Charge your iPhone in a cool location. Charging your iPhone in a cool environment has a tremendous impact on your battery's lifespan. The colder the location you use to charge, the more charging cycles you can complete without your battery deteriorating. Avoid charging in direct sunlight.
#8 - Use properly rated chargers. Using chargers that are not properly rated will have a huge impact on your battery's lifespan. Make sure your car charger has the same rating as the official Apple charger.
The official Apple wall charger is rated as follows:
Input: 100 240V ~ 50/60 Hz 1.0A
Output: 5V 1A
Thanks!
Apr 15, 2011 | Cell Phones
Bought my phone yesterday...Battery was losing charge quickly.. battery was down to half charge after about 15 minutes of fully charging.. Was trying to let the phone die completley then fully charge it,...
Ok first of all you should never let a phone die out of charge at all.IF it dies out of charge there are chances it might charge again once you charge it but in some cases it wont, you need to boost your battery just like jump start your car.It cannot be done anywhere except some service centre. If you are not taking to your service center , then you need to buy a new battery.
Oct 08, 2009 | Cell Phones
SAMSUNG ALIAS WILL ONLY POWER ON IF PLUGGED IN TO THE CHARGER
battery may show fully charged while charging, but it can noot hold the charge. So you need a new battery. If under warranty ask Verizon for replacement.
Aug 05, 2009 | Verizon Communications Samsung Alias Cell...
Phone does not charge
When my phone is connected to the charger, it says fully charged. But as soon as I disconnect the charger, the battery shows empty. When I connect the phone to the charger, it starts charging but after 10 seconds it says fully charged.
Aug 08, 2008 | Sony Ericsson K600i Cellular Phone
Computers & Internet Logo
138 people viewed this question
David Payne
David Payne
