Question about Akai PDP4294 42 in. EDTV-Ready Plasma Television
Im trying to remove my flat screen tv off the wall bracket
    Sergeant:
    Champion:
  • 277 Answers
Its a drop bracket you need to pull the bottom forward then lift it up you also mite have a anty theft bar going throu the back pull it out first
Posted on Apr 04, 2011
The word debug is on the screen. how do i take it off?
Unplug the power cord of the receiver box for 10 seconds and then plug it back.
Feb 27, 2014 | Sony Bravia 36 40 42 46 50 52 55 LCD...
My screen broke moving on my sony flat screen. Tv
I would try contacting<a href="http://www.tvvideorepairil.com">flat screen tv repair in Chicago, IL</a> because that's where I went when mine broke.
Oct 03, 2013 | Universal 40-42 Inch Flat Screen Panel...
Can you give me some advice on, how to mount a 46in tv above my non working fireplace mantle?
You would have to use a mounting bracket specifically designed for the type of installation you describe and it certainly would have to be fastened into the studs behind the sheetrock. A TV of that size will be heavy to lift and install in the bracket
Mar 04, 2013 | Universal Bedroom Mounting Bracket For...
I have a PROTRON Flat screen tv SRS BBEDigital
have a PROTRON Flat screen tv SRS BBEDigital that I will like to install on the wall. I do not see any holds in back of the TV for a mounting bracket. How do I mounted on the wall?
Jan 31, 2010 | Protron PLTV-32 Television
Im painting and need to remove the 42 in Toshiba off the wall, but want to make sure im not goin to break anything. What screws am I suppose to take off?
I have just done the same, though I have a panasonic.You need another person to help you lift it of the wall which will show the bracket on the wall.Take the screws out from the bracket. Leave the other part of the bracket which is screwed onto the back of the tv.
I hope this helps.
Tony
Jan 18, 2010 | Televison & Video
Try to mount TV to the wall and need to release the TV stand
To Display your LCD TV using a Wall Bracket:
If you decide to wall mount your LCD TV, always use a ULlisted wall bracket appropriate for the size and weight of the LCD TV: 32HL37/32HL37U/32HL17/32HL17U: 38.6 lbs (17.5 kg)
37HL17: 46.3 lbs (21.0 kg)
42HL17: 59.5 lbs (27.0 kg)
1) CAUTION: Two people are required for installation.
2) Unplug and remove any cables and/or other component connectors from the rear of the TV.
3) Follow the instructions provided with your wall bracket. Before proceeding, make sure the appropriate bracket(s) are attached to the wall and the back of the TV as described in the instructions provided with the wall bracket.
4) After attaching the appropriate bracket(s) to the wall and the back of the TV, remove the pedestal stand from the TV as described below.
Removing the Pedestal Stand
1) Carefully lay the front of the unit face down on a flat, cushioned surface such as a quilt or blanket. Leave the stand protruding over the edge of the surface. Note: Extreme care should always be used when removing the pedestal stand to avoid damage to the LCD panel.
2) Remove the jack pack cover on the back of the TV to expose the pedestal stand screws. The jack pack cover can be removed without tools.
3) Remove the five screws. This will allow removal of the pedestal stand.
4) Once you have removed all five screws holding the pedestal stand in place, remove the pedestal stand from the TV by sliding the pedestal stand away from the TV.
Sep 28, 2009 | Toshiba REGZA 32WLG66 32 in. Television
How do I remove a plasma panasonic mounted on a wall.
if it is a swing bracket 4 screws on back bracket holding it in need to be removed, if it is flat wall bracket lift strait up the wall to remove.
hope this helps
daniel
Jan 11, 2009 | Panasonic TH-50PX75U Plasma HDTV
I want to take off the base of my flat screen tv.
lay tv down on a flat soft surface remove 4 philips screws on back on either side of signal brd inputs base will pull out of bottom
Oct 15, 2008 | Westinghouse LTV-40w1 HDC 40.02 in. LCD...
Akai PDP4294 42 in. EDTV-Ready Plasma Television Logo
52 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
