Question about PfaFF Tiptronic 2030
I have a pfaff tiptronic 6230 and the thread keeps bunching up under the material when i try to sew could you tell me what the standard settings should be to do a straight stitch. I have the G button down the wheel below the reverse stitch button is on 3 and the dial above the neddle area I don't know what that is supposed to be set on. It goes from 0-9. Please help if you can. I'm trying to make a baby quilt for a friend and it's over due. Thanks Kathi
    Scholar:
  • 89 Answers
Hi Kathi it soulds like your not geting the thread in the tension unit.
Try this, thread the machine all the way to the needle but not in the eye.
Lift the presser foot up and down and pull on the thread at the same time.
You should feal the thread tension when the presser foot is down and not tension when it is up.
If this is the case then try and sew, if not then its not threaded right or your machine needs adjusting.
For were the tension dial should be set, I would put it on 4-5 for straigt and 3 for satin/button hole.
Posted on Apr 04, 2011
My Pfaff grand quilter 1200 keeps bunching up the top thread on the bottom side of my quilts. I've replace the needle and thread. It won't pick up the bobbin thread. Could this be a timing problem?
Remove the thread from the machine. (Always raise the presser foot and pull the thread up, NEVER down!).
Install a brand new needle.
ALWAYS RAISE the presser foot when threading.
Rethread from the beginning and verify the thread pathway is correct.
Set the upper tension to midway between High & Low numbers--you may need to tweak this for your particular machine, but this is a standard starting point.
Confirm the bobbin is loaded and threaded correctly in the bobbin case.
Begin sewing slowly. It helps if you begin sewing with the needle in the uppermost position.
Test on medium weight woven cotton.
If it is still not picking up the bobbin thread, then it most likely is a timing problem. You can search the internet for web sites and videos regarding sewing machine timing or take it for service.
Sewing Machine Thread Bunching Up Here Why
Birds nest under the fabric big loops of thread top side looks good...
What causes Bird Nests Superior Threads
Nov 21, 2016 | PfaFF Sewing Machines
Help trouble-shoot jammed machine
Try these suggestions
1. Change the needle--use a needle that's for the fabric being sewed
2. Rethread the machine--top --make sure to use every thread guide
3. try a different bobbin--make sure bobbin is inserted correctly into the bobbin case, & make sure the bobbin is turned the correct way in the bobbin case
4. make sure the thread has not come off the thread take up lever
5. Clean under the needle plate & in the bobbin area for lint or threads
6. Also could be a timing problem, and the machine would need to be checked.
Sep 08, 2013 | PfaFF Tiptronic 2030
Foot and threading for tiptronic 6230 Pfaff
an all purpose foot which can straight stitch & zig zag is what I use with double needles
when using double needles,,you thread the first needle the regular way,,then you add the second spool & thread the second needle the same way as the first
Feb 19, 2012 | Sewing Machines
I was just gifted a Pfaff Tiptronic 6270 for my charity quilting.I have no manual,and cant figure it out.How do I use it? How do I thread it? I just want to sew a basic chain stitch,nothing fancy..help!...
there a bunch of sites selling this manual but i'd suggest you try the manufacturer first
ContactSVP Worldwide
C/O Husqvarna Viking
P.O. Box 7017
LaVergne, TN 37086-7017
Toll free assistance - 1-800-446-2333
Monday-Friday 8:00 am - 4:00 pm CST
Email:
info@pfaff.com
(Please allow 72 hours for response
Mar 24, 2011 | PfaFF Sewing Machines
I inherited my mother's Tiptronic 2040, and needed to sew a simple seam. I admit to not having much experience. I have re-threaded it several times,; re-worked the bobbin but the top thread keeps getting...
Deep breath. Ohmmmmm.... ok now.
Few things you need to know.
1. Try to remember TTN when you run into problems like this it stands for Thread, Tension, Needle. Contrary to popular belief, there is no such thing as universal thread and needles. You'll need to determine what kind of thread and needle is best for your application.
2. When things gets bunched up under the fabric it Usually means that the tension for the top thread is too loose. However, a bad, bend or just plain wrong needle will cause these problems too.
3. Always grasp the threads (both top and bottom) and pull gently backwards when starting a seam. Some old school seamstresses and seamsters say to make sure your needle is at its upper most position (just before it starts to move down) before you begin sewing.
4. since you've had a couple instances with this issue... you might have to clean the bobbin race area. I'm a bit reluctant to tell you about this but remove the bobbin and look carefully for other stray threads, dust bunny's etc.
I hope this helps some. ;o)
S
Mar 12, 2011 | PfaFF Tiptronic 2040
I have a pfaff 2040 tiptronic and the bobbin thread keeps bunching up and stopping the machine
Here are a couple of solutions to try.
* Re-thread your machine, it may be threaded incorrectly.
* Raise your feed dogs if your machine has this feature.
Note: When you start to sew a seam, hold the upper and bobbin thread tails back and out of the way as you sew your first couple of stitches. This will keep them from getting caught in your machine.
Hope this helps.
Dec 22, 2009 | Sewing Machines
When trying to sew with my PFAFF 2030 (NEW) the thread bunches up under the material. I have tried ajusting the tension many time but still does it.
The thread bunching under the fabric is generally an indication that the upper thread is not seated properly between the tension disks.
  1. Completely remove the thread from the machine/threading path.
  2. Raise the presser bar lifter to the up position. This releases the tension disks, ensuring that the thread will seat itself properly when you again lower the presser foot.
  3. Rethread the machine, including the needle.
  4. Grasp the thread at the spool and where it comes out of the needle. Give it a little tug and "floss" is through the thread path - as you'd floss your teeth back and forth. You should feel tension on the thread.
  5. If you feel no tension/pressure on the thread, double-check to make sure the thread is between the tension disks (not outside of them).
  6. If thread is seated properly between the disks and no tension, there may be a mechanical issue that is causing the tension disks to not close properly.
  7. Also make sure the bobbin thread is turning in the proper direction and that the thread tail is under the tension of the bobbin case.
Hope this helps - don't hesitate to respond with further questions. We're always happy to help.
Happy stitching,
Kim & Linnette
www.sewingexpressions.com
Oct 21, 2008 | PfaFF Tiptronic 2030
Threading the machine
what is the setting to hem
Feb 21, 2008 | PfaFF Tiptronic 2040
Sewing Machines Logo
354 people viewed this question
Top PfaFF Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
