Question about Hardware & Accessories
It's been a long time since I have had to re-set my Intermatic Pool timer. The label on the inside of the box says it is a T104P3 model but it is not. It has no wheel time setter. It's digital with three possible components that can be programmed. We use Circuits 1 and 2 , for our pool filter and solor heater respectively. I can't find the instruction book that came with the timer so do not know how to go about it. I have taken a picture of the device and could send it to you if you provide me an email address so we can identify the timer and I can download an instruction manual. Thank you.
1) Send photo:
http://www.fixya.com/support/r6568559-post_photograph_fixya_questions_answers
2) Open following link to identify timer and download manual:
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#P1353
3) Add a comment with specific question if you need help programming P1353.
If each circuit is independent and can be turned ON at same time, then set Mode 1
If you have 2-speed pump, set timer to Mode 2.
Mode 2 makes sure that both circuits cannot be ON at same time.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Apr 05, 2011
What position is lever on intermatic pool timer t104p3 for timer to work?
Lever automatically moves back and forth as trippers pass.
Move lever to ON position, move to the right.
If timer dial is not rotating, then check wiring, or replace clock motor:
If timer worked before and stopped working, but dial still rotates, the trippers are worn down, replace trippers:
http://waterheatertimer.org/How-to-operate-and-set-T104-timer.pdf
http://waterheatertimer.org/Buy-T100-series-timers.html#pool
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#T104
Gene
h
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
May 20, 2014 | RTO Intermatic Inc Ej351c Timer Night...
Need instruction manual for pool/spa Intermatic timer model RC 2343PT
Intermatic does not post that product manual, or the door label for that specific product. Nor is the door label clear when viewing images of timer.
Copy following links for possible assistance wiring timer, and then setting timer:
http://waterheatertimer.org/pdf/RC2403RT-Door Label.pdf
http://waterheatertimer.org/How-to-set-timers.html
Apr 20, 2012 | Intermatic Hardware & Accessories
I have a T104P3 timer for my pool pump. It has already been replaced once by the pool installers. However, they are not helping me again with my problem. The time is set correctly as well as the turn on...
Sounds like the ON tripper is worn down.
Check that dial is rotating correctly each 24-hours. If not then wiring might be wrong.
Open following links for troubleshoot:
http://waterheatertimer.org/How-to-troubleshoot-Intermatic-timer.html
Upvote the help.
And take advantage of fixya expert assistance live.
May 28, 2011 | Intermatic Inc. ST01C Digital In-Wall...
Intermatic t104p3 pool timer will turn pump ""ON" with Manual Switch but will not shut "OFF" using Manual Toggle. Pool store showed me how to remove and look at the contacts on...
Thank you for including model number so answer can be accurate as possible.
T104P3 timer works with manual override so timer is basically sound.
Clock dial rotates and keeps good time, so WG1573 240Volt clock motor is good.
Trippers do not click on-off lever, so trippers are suspect.
Trippers are made to wear down so that timer mechanism lasts years longer.
Order extra clock motor and trippers at Grainger
http://www.grainger.com/Grainger/timer-accessories/timers/electrical/ecatalog/N-8hi
See wiring diagram:
Add a comment for more free help.
For a price, expert works with you via e-mail while you work on timer or any do-it-yourself project.
Feb 18, 2011 | Intermatic & Indoor/Outdoor Rain Tight...
I have an intermatic T104P3 timer for my pool and now it won't turn on. I have to start the pool on manual. I have tryed to remove the screw to start and it goes right by it and does not set the pool on....
Hi Dianna, I am timer expert at Fixya
1) When you say screw, I believe you mean tripper?
2) Trippers are placed on dial using thumb screw. Clock motor located on back of mechanism rotates dial. So dial rotates as time passes.
On-off trippers rotate around on the dial and push a lever back and forth that turns pump on-off.
Trippers are designed to wear down so that timer mechanism lasts longer.
You can buy replacement trippers for T100 series timers at Grainger:
3) You posted under T104 timer.
Notice that grainger also sells WG1573 240Volt clock motors for the T104.
Clock motors slow down and burn out.
Clock motors are replaced by tipping mechanism out of box using thumb spring located inside box at top. Clock motor is attached with 2 small star screws. Buy star screwdriver at auto parts or hardware.
When ordering trippers, you might want extra clock motor on hand for when the dial stops rotating.
4) Open following link to see manual and wiring instructions for T104.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Feb 10, 2011 | Intermatic T104 24h 208-277v Mechanical...
How to set Intermatic T104P3 - Pool-Spa Mechanical Time Switch... I believe this is the correct model. There are no instructions or data left on the gray metal box to verify what it is.. I got the model...
The T-104 is a 240Volt timer that will not work for 120V circuits
The above link gives you information about the T104 T103 T101 in case you need to buy another timer
The difference is the voltages on the lines and voltage of the clock
1) How to sort out what you have:
-Which circuit breaker operates the timer and pump? If your circuit breaker is 240, then the pump is 240 and the timer is 240 so you most likely have the T-104
-To double-check: turn off the power and look at the name plate on the pump >>> the name plate will show voltage of the pump
-If breaker is 120, then you have T-101 that has three terminal screws inside the timer, or you have T-103 with 5 terminal screws inside the timer.
OK that's the basic information:
You say your trippers don't work.
Does the manual override work?
2) If the manual override does NOT work when you click it back and forth, and the unit has electricity, then the timer is probably bad. You can buy a new timer, and swap out the insides with old timer without replacing box.
3) If the manual override DOES work, then best news of all ... you may need new tripper pins
http://www.grainger.com/Grainger/INTERMATIC-Timer-Tripper-2E054?Pid=search
Oct 19, 2010 | Intermatic T104 24h 208-277v Mechanical...
Clock for pool pump intermatic timer Model T104P3 stopped ticking
TO INSTALL THIS MOTOR REMOVE SCREW ON LEFT AND JUST BACK SCREW ON RIGHT A FEW TURNS, TIMER WILL ROCK UP OUT OF BASE THIS WAY . UN-HOOK WIRES ONE AT A TIME AND INSTALL WIRES FROM NEW MOTOR ONE AT A TIME.. THESE TWO WHITE WIRES GO TO LINE 1 AND 2 THESE ARE THE WIRES THAT GO TO THE 220 VOLT BREAKER ... NEED MORE HELP JUST GIVE ME A BUZZ.. JAY ..LOOK EBAY FOR .. Intermatic Timer Motor WG1573 / WG1573-5 clock POOL FIX
May 15, 2010 | Intermatic & Indoor/Outdoor Rain Tight...
LOOK HERE ON EBAY .. Intermatic Timer Motor WG1573 / WG1573-5 clock POOL FIXTO INSTALL THIS MOTOR REMOVE SCREW ON LEFT AND JUST BACK SCREW ON RIGHT A FEW TURNS, TIMER WILL ROCK UP OUT OF BASE THIS WAY . UN-HOOK WIRES ONE AT A TIME AND INSTALL WIRES FROM NEW MOTOR ONE AT A TIME.. THESE TWO WHITE WIRES GO TO LINE 1 AND 2 THESE ARE THE WIRES THAT GO TO THE 220 VOLT BREAKER ... NEED MORE HELP JUST GIVE ME A BUZZ.. JAY
Mar 28, 2010 | Intermatic & Indoor/Outdoor Rain Tight...
Hardware & Accessories Logo
60 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
