Question about Dell 946 All-In-One InkJet Printer
How do I change the toner in my printer? and where is it located at?
    Sergeant:
    Champion:
  • 277 Answers
Yhere is a clip on the side that will pop it open the top will pop opan the cartige is in there
Posted on Apr 04, 2011
My machine is poblam out of toner change toner poblam change tha toner poblam as tis
Out of toner problem often happen when the sensor is blocked with waste or toner-dust-spill and recycled toner cartridge. If you can manage to air-dry-clean (using vacuum cleaner) the housing where the toner is inserted please do so. But it is advantageous to locate the toner sensor location for efficient cleaning. I may know the brand and model of the machine to help you locate the toner sensor. Goodluck!
Jan 05, 2015 | Office Equipment & Supplies
Tip
How to change toner in laserjet printers
First Turn the printer's power off. Some power button is located on the control panel on the top of the printer, on the right side. Open the printer's top cover by pressing the top cover lever, which is located on the bottom side of the top cover. Lift the cover all of the way open. Locate the toner cartridge. It will be right in the center of the printer and has a handle on the top of it. Grab the handle and pull the cartridge out. Hold the replacement cartridge at its side and gently rock it back and forth. This will help to distribute the toner equally throughout the cartridge.Remove the paper cover from the top of the cartridge.Insert the replacement cartridge into the printer and close the printer's top cover.
on Mar 31, 2010 | Office Equipment & Supplies
How can i settle the problem of magenta developer finishing so fast. Magenter developer for Konica Minolta Bizhub C550 is getting finished so fast.
If the message Change Imaging Unit Magenta displayed refer to imaging unit with contents a developer.The Imaging unit life is 80.000 copies.
The imaging units located after front door when is located the waste toner box.
If the message M toner end/change the M toner displayed refer to toner cartridge
The toner cartridge life 15.000 copies 5% saturation.In full color mode the color saturation is 80% and the color toner life is 6.000-8.000 copies.
I think your problems is a toner not the developer.
Apr 11, 2013 | Konica Minolta Bizhub C550
Waser toner betlle
The waste toner bottle comes with new toner cartridge and should be changed when the toner is installed. Here is a link to the Kyocera web site document that shows where the waste toner bottle is located and how to change it.
http://www.kyoceradocumentsolutions.co.uk/index/products/consumable/toner_installation.-cps-12303-files-13964-File.cpsdownload.tmp/Toner%20FS-1920.pdf
Aug 21, 2012 | Kyocera Mita Office Equipment & Supplies
Brother HL-2140 laser printer, where is the toner located
The toner cartridge is inside the printer's drum unit. To change the toner, make sure that the printer is on and then open the front cover by pulling it down. Then pull the drum and toner cartridge assembly out of the printer. (Take care not to touch the electrodes on the sides of the drum.) Push down on the green lever (on the left side of the drum unit). Then you can remove the toner cartridge from the drum unit.
Open your new toner cartridge and then shake it gently and remove the protective cover. Put the new cartridge into the drum unit and push down until it clicks (the green lever should come up automatically). Slide the green tab along the corona wire back and forth several times. (Return it to the home position when done).
Then return the drum and toner assembly to the printer and close the front cover. Wait until the Ready light is lit before turning off the printer or reopening the front cover.
For pictures of the HL-2140 drum and toner assembly (and the toner replacement procedure), see page 60 and subsequent pages of the manual here: http://welcome.solutions.brother.com/BSC/public/files/dlf/doc002308/cv_hl2140_usaeng_usr_d.pdf .
I hope this helps.
Dec 26, 2011 | Office Equipment & Supplies
How to change the toner
This unit does not use toner. It uses ink cartridges, hence it is called an OfficeJET All-in-One INKJET Printer. To change the ink cartridges, you lift the latch located on the front of the unit above where the paper comes out.
Aug 26, 2010 | HP OfficeJet 9120 All-In-One InkJet...
Change ink???????
the top part of the printer lifts up from the front, then on the inside where the toner is there is a handle, then pull up and out
Jan 06, 2010 | HP LaserJet 1022n Printer
Toner does not adhere to paper
You have got a warped fuser this is the hot thing that cooks the toner onto the paper. Your best trying to locate a fuser unit for the machine this will solve your problem.
May 06, 2009 | Samsung SCX 4200 All-In-One Laser Printer
No toner message
The control panel display will indicate which toner is out;
K = Black
M = Magenta
Y - Yellow
C = Cyan
Also, the orange indicator light will flash.
Generally, each toner will provide about 1,500 copies depending on the intensity of the specific color. The toner drums, on the other hand, generally provide more than 20,000 copies each and need not be changed that often.
When you change a toner, included with the toner is a little alcohol wipe that you use to clean the toner sensor. This is a small LED located along side the toner holder. Make sure ALL toner waste/dust is cleaned off the sensor before installing the new toner.
Also, while I hate to state the obvious, make sure you removed the tape from the new toner before inserting it. Last, make sure you lock the toner in place with the blue lever. And it never hurts to shake the toner a little side to side before inserting it just in case the toner has gathered at one end.
Last, there is a utility included with the printer that lets you access the printer's information via your computer. This will tell you exactly how much toner is left in each cartridge and the life remaining on the drum.
Feb 04, 2009 | OKI C3200n Led Printer
Dell 946 All-In-One InkJet Printer Logo
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
