Question about Samsung DVD-VR375 DVD Recorder/VCR
Won't load/ play discs...keeps opening loading door even when no disc is in player.
  • 760 Answers
Sounds as if you have a bad switch.
Posted on Apr 04, 2011
  • jim_tuck Apr 26, 2011
    I'm having the same problem, how difficult is it to replace the switch ?
  • David Duncan
    David Duncan Apr 27, 2011
    If you can solder not hard at all. You will need to take the front cover off and pull the board out of the cover. Your best bet is to cchange all the switches. They run about 10 cents a piece. Just unsolder the 2 legs, pull the switch out and solder the new switch in.
Help!!!!
  1. No disc. - Load a disc into the tray.
  2. Disc has been loaded upside down. Place the disc with the label side up.
  3. Disc region code does not match region code of the player.
  4. Disc type is not the correct type to play.
  5. Disc is damaged or dirty. Clean the disc or try another.
  6. Moisture may be condensed inside the unit. Remove the disc and the leave the power on for one or two hours.
follow the steps and fix it.
God bless you
Jun 04, 2013 | Audio Players & Recorders
My dvd player door keeps opening and closing and will not hold a disc of play it.
my dvd on my combi is not loading it just says loading when you press the close button please advise thanks
Nov 07, 2011 | Samsung DVD-V4600 DVD Player/VCR
Disc won,t play it just keeps spinning it says loading but it won,t play
how long have you been using this player and when did this begin?
The lens is weak such that it cannot load data on discs. Its spinning, trying to load, but can't because of the weak laser.
Get a lens cleaner, use it to clean the lens. If that doesn't solve the problem, get a screw driver, open the player's cover so that you can gain access to the lens, use a cotton board to clean the surface of the lens. This should clean dust or dirt that might be on the lens.
If non of the above solves the problem, then know that you need to replace the laser to a brand new one.
To replace the lens, remove the bad laser, use it as a sample to get exactly the same type and do the replacement. Note that replacing a laser (lens) needs a professional touch, so if you cannot replace the laser, get it to a repairman to fix it for you.
Once this us done, your player will play all discs again.
Good luck.
Jan 12, 2011 | Amphion Mediaworks V101 DVD Player
Says loading disc then no disc pops up and it just won't play. Tried the phillips lense cleaner still does same message (loading the no disc)
The reason the player keeps loading and showing no disc is simply because the lens of the player is weak.
To fix this,
  1. Open the cover of the player with the appropriate screwdriver,
  2. Open the disc tray,you will see the lens, like a crystal or diamond like object,
  3. Replace the lens by removing it with the mechanism that supports it and fixing the new lens,
  4. Test it with a DVD disc.
  5. Cover the player back.
Take care
Jun 21, 2010 | Televison & Video
Why won.t the disc go to load. it keeps opening after inserting disk .when play is pushed it shows stop then ejects disk.Whats up with www.rca.com/customersupport
check the type of discs that are recognized with your dvd player. Some machines recognize dvdr- some dvdr+ some dvdrw+/- you may be using the wrong formated type of disc.Look at disc and see what type it is in the ring surrounding the hole especially if it is a copy
Sep 29, 2009 | RCA Televison & Video
Discs won't play.
please change laser unite then solve your problem
Jul 16, 2009 | Sony DVP-NS575P DVD Player
Player won't read cd's keeps opening door
This model has a belt used for loading the cd mech, after you push play if the belt is slipping or gone,the door will open, if you take the cabinet off eith power off and traopen, look at cd mech you see a belt, it may be loose or gone
Oct 25, 2008 | Yamaha CDC-565 5-Disc CD Changer
Player won't load any discs
I don't have a solution at this time. I have the same DVD player and mine stopped working this past weekend. It is doing the same thing as yours. I opened the case and loaded a disc and watched the mechanism. The disc won't spin. if you tap the disc it will start spinning and load and start playing. I thought I had fully fixed it. It will load most times but now the video and audio stutters as if the discs is spinning at varying rates.
Apr 06, 2008 | Sony DVP-NC85H Multi-disc DVD Player
Cd player won't play discs
Maybe you should try cleaning the lens by opening the shelf TOP, and cleaning the lens? I had that problem. Take a Q - Tip with alcohol on it and it will do the job. Careful to not touch any components, and unplug first! The system can electrocute you even if unplugged, so don't touch any electronic component else than the lens inside.
Nov 28, 2007 | JVC MX-K30 CD Shelf System
Samsung DVD-VR375 DVD Recorder/VCR Logo
150 people viewed this question
Henry  Thomas
Henry Thomas
