Question about Maytag Washing Machines
I have a maytag heavy duty/supersize capacity/3 speed select/ 10 cycle washer that sounds like it is washing rocks in the wash cycle what could this be?
SOURCE: admiral mega 22 plus heavy duty 2 speed washing machine
I think my set i just got today used is a 3 speed.Seems to be alright for now.There is a thing i was told called a harmonic balance it might be off or messed up.Tina.A(nc)
Posted on Apr 27, 2008
Lumpy816
  • 246 Answers
SOURCE: location of filter on maytag performa heavy duty washing machine
I'm sorry Hilda, most washers that have been put out over the last several years don't have a filter per se. When the wash cycle agitates and lint is released from the clothes, the outside of the basket (the area where you put your clothes) is very sharp where the holes are. Lint collects on these holes as the linty water flows through them. When the rinse and spin cycles dis-lodges it and send it down the drain.
There are some availibkle aftermarket kits availible at some appliance parts stores. They are generics and not produced by the manufactues, but if you wanted a lint catcher n a washer, it would be an option.
I hope this helps with you questions. If you have any other quiestions or concerns, please feel free to write me back.
Posted on Jul 23, 2008
SOURCE: won't spin or agitate
coupling.between motor and gearcase.
Posted on Nov 14, 2008
  • 423 Answers
SOURCE: washing machine won't spin dry
If this is a top load clothes washer, almost all units will not spin if the door is open during the cycle time when it should be spinning. If the door is closed, check if the door safety interlock is broken (on most washers, you will see a pin on the door pressing into a little depression)
If these things check out, you probably have a failed transmission deep inside the clothes washer. Fixing that is non-trivial.
Posted on Aug 20, 2009
  • 1218 Answers
SOURCE: I have a heavy duty large capacity Whirlpool
Good day,
Common problem. The top of the agitator is driven by what are called "dogs", and are worn out.
Here is an excellent tutorial on how to replace them.
The cost should not exceed $10.00.
http://www.youtube.com/watch?v=V5wIN1J70-Y&feature=player_embedded#
Thank you for using FixYa
Posted on Dec 29, 2009
What is the capacity of a front loading whirlpool washer MO#GHW9150PWO
Whirlpool GHW9150PW 27 Inch Duet Front-Load Washer with 3.8 Cu. Ft. Capacity, 8 Wash Cycles & Triple Dispenser.
whirlpool ghw9150pw0 capacity Google Search
Nov 25, 2017 | Whirlpool Washing Machines
Kleensmaid heavy duty washer by speed queen, washes but shuts down on what seems to be overspeed on the spin cycle
Amazon.com: Customer Reviews: Speed Queen 3.3 Cu. Ft ...
www.amazon.com/Speed-Queen...Washer/.../B004ZO...
Amazon.com, Inc.Find helpful customer reviews and review ratings for Speed Queen 3.3 Cu. ... If you need more water in the tub you can hold down the reset switch until the machine ... I tried the delicate wash and spin cycle, but the clothes retain too much water and ..... It takes time to correlate the number of turns and the direction to turn it.Missing: overspeed
Commercial Washer and Dryer Problems
www.affordablelaundry.com/commercial-washer-and-dryer-problems
The water should shut off once it reaches wash level, if it doesn't, and water level hasn't... (these are the glass type fuses) be sure to turn power off before checking them. ... If you have the voltage in, but not out, it's the contactor. .... We repair: Speed Queenwasher, IPSO washer, Milnor washer, UniMac washing machines.Missing: overspeed
[PDF]View document in PDF
Dec 19, 2015 | Speed Queen Washing Machines
Fix rinse cycle
That sounds like a failed mechanical timer. Replacing that should solve your problem.
Dec 13, 2014 | Frigidaire Washing Machines
What is the capacity size of washer model fws1339ac1
Dimensions/Weight/Electrical Height: 43 5/8" Width: 27" Depth: 27" Approximate Shipping Weight: 180 lbs. Electrical Requirements: 120V/60Hz. Features Control Location: Top Console Capacity: Super Capacity Tub Size (cu. ft.): 3 Agitator Style: Twin Spin Cycles: 13 Wash/Rinse Temperature Combinations: 3 Motor Speeds: 2 Heavy Duty Motor (Hp): 3/4 Total Front Serviceability: Yes
Aug 30, 2012 | Frigidaire FWS1339A Top Load Washer
Maytag centennial washer not working properly in Normal cycle. After it shuts off there is still water in the bottom of the tub. I can move the dial to another setting such as Casual cycle or Heavy Duty...
We have the same problem. The Normal cycle still works, but after the final spin cycle, water is again added (1 gal est.) and the machine stops. Problem occurred after washing an old 25 x 30 inch rug which partially disentegrated when washed. We were seeing particles of the rug in subsequent wash cycles during drain into laundry tub. Don't know if something is plugged in the washer or if it is something else. In another load after the rug wash, the top of the washer was lifted during the wash cycle. The water problem occurred immediately after lifting the lid as the wash load went through remaining cycles. Maybe this affected the timer? Maytag customer service suggested unplugging power cord to re-set timer. This didn't make any difference. We need a technician to tell us if this is a timer problem or something else?
Oct 03, 2011 | Maytag Centennial 3.2 cu. ft. SuperSize...
Just trying to find out drum capacity of my maytag heavy duty super capacity 7 cycle washer. Please help
Check the tag where you find the model and serial number, they often list it there. Your owners manual should tell you as well. You might have to call whirlpool (maytag), I cannot find the capacity listed on the tech info. Good luck.
Sep 23, 2010 | Maytag LAT2600A Top Load Washer
I have a Whirlpool Heavy Duty-Super Capacity Plus, 7cycle/2 speed. Model LSR7200EQO , the agitator stopped working
My whirlpool heavy duty 2 speed 7 cycle washer machine stopped working, It fills up and aggitates for the first cycle then when it should drain and spin it doesnt drain nor spin
Jun 05, 2010 | Whirlpool LSB6200KQ Top Load Washer
Amana Heavy Duty Extra Large CapacityTop Loading Washer 2 speed - 10 cycle Mod. LW8413W2 Mfg. No. PLW8413W2A S/N R-9504056772 Occasionaly,At the end of a wash cycle it will continue on to the next...
my heavy duty 7 speed motor cut off because of over heating and the belt was changed can you suggest a suitable model of fan belt for it. ?
Jul 07, 2008 | Washing Machines
Washing Machines Logo
302 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
