Posted on Apr 04, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Will using Non-Lexmark ink cartridges screw up the printhead?
Anonymous
Level 2:
Sergeant:
Champion:
  • Expert 277 Answers
  • Posted on Apr 04, 2011
Anonymous
Expert
Level 2:
Sergeant:
Champion:
Answers
277
Questions
0
Helped
53458
Points
818
1helpful
Why is printer saying printer head not there when i put all new ink cartridges in it?
PDF]Cleaning the printheads - Lexmark
www.lexmark.com/publications/pdfs/lexmarkj110/.../clean.pdf
LexmarkThe carrier moves to the load position at the center of the printer. 6 Raise the ... If this does not solve the problem, a printhead may be plugged with dried ink.
Lexmark ink cartridges with print-head, not recognized ...
? 6:48
https://www.youtube.com/watch?v=v2wMm4uMWpg
Sep 16, 2013 - Uploaded by PrintingExperience123
Lexmark ink cartridges with print-head, not recognized, missing, damage, chip problem, .... The error reappears when you try to use the printe
2answers
Printhead error 2
Oh boy,
the last time this happened to me, I lost a rather good HP printer.
I was not able to save it due to the ink drying on important componets.
Sorry I have no constructive info for you, but I do wish you luck.
My Lexmark Impact S305 will not print in color.
If you're using a remanufactured/refilled cartridge, the printer will not be able to recognize those cartridges after the firmware update. The firmware update restricts use of refilled/remanufactured cartridges. That's to prevent damaging the printhead.
If you're using genuine Lexmark cartridges, please contact our technical support for assistance.
Generic Ink cartridge causing printhead errors
It's not a guarantee that the remanufactured cartridges will work the same way as our cartridges. Remanufactured cartridges also voids the warranty of your printer.
For best results, always use genuine Lexmark cartridges. We do have a Smart Supply program where you will always get 10% off each cartridge purchase and free shipping every time. Check here for more info: http://bit.ly/HNG1M9
Printer would not print. Says see error #1203 in users guide.
By any chance is your printer a Lexmark?
1203 Error Message indicates a problem with an ink cartridge. Can be a communication failure between the printheads (cartridges) and the printer or a short in one of the printheads.
Commonly occurrs with refilled ink cartridges and indicates the cartridge has been overfilled.
If powering off and restarting the printer does not correct the problem, to remedy, remove the ink cartridges, check for leaking or excess ink on the cartridge contacts; clean the cartridge contacts using a water dampened q-tip. See for illustrated instructions:
http://support.lexmark.com/index?page=content&id=HO2322&locale=EN&userlocale=EN_US
If the problem is with over-filled cartridges, to avoid a repeat, you may need to wick out some excess ink by placing cartridge on a damp paper towel.
If these steps do not resolve your issue or your problem is not with a Lexmark printer, please reply with the make and model number of your printer for an alternate solution.
Thank you for using FixYa!
1helpful
Epson wont recognize black refill cartridge.
I'm assuming that you are probably using Non-Epson Ink Cartridges, because those are what normally cause that problem, with a printer not recognizing an installed ink cartridge. Unfortunately, there is no way to make your Epson Printer use or accept that Non-Epson Ink Cartridge, if it cannot actually recognize it. Its even possible that some Generic or Third-Party brands, may not always be recognized by the newer models of Epson Printers, because of the inexpensive [cheap] and or incompatable Electrical Chips that are mounted on the actual ink cartridge. Sometimes you will even get Error Messages up on your Monitors screen, telling you that you are actually using a Non-Epson Ink Cartridge, or that your printer cannot recognize the cartridge that you installed. Sometimes the Ink Level Indicator, on your Status Monitor, will not show an actual ink level, but may indicate a cartridge error or problem instead. Not all Generic or Third-Party ink & ink cartridges are made the same and none of them actually contain the right formulation of ink, for the Epson Printers [formula is patented by Epson Company]. Some are probably close and seem to be better than others, but some simply can clog-up or even damage the Printhead Assemblies on Epson Printers, or simply won't be accepted at all. Epson Ink Jet Printers are one of the few printers on the market that seem to have so many problems with non-manufactors inks, especially the newer models made in the last couple of years. Its because the Epson Printers use a completely different printhead inking system than most other brands of printers. Most, if not all of the other manufactors, use thermal or bubble jetprint heads and because the other brands use a totally different system, they don't seem to have as many problems using refilled inks or non-manufactor's ink cartridges. Printer manufacters do not make available their ink formulation and in most cases, the formulation is patented. Any difference in the ink formulation can actually cause clogging in the small printhead nozzles or damage other critical components. One individual printhead nozzle is so tiny, that it will not accept a human hair, so you can see why they can get clogged so easily, or even why the nozzles can be so easily damaged...Even if you were actually using a New-Epson Ink Cartridge, its always possible that you got a bad cartridge. At this point, the only thing I can suggest is that you try a different New-Epson Ink Cartridge, or at the very least, a different brand of Non-Epson Ink Cartridges and see if that helps.
3helpful
Does not reconize non epson ink cartridge. I remove and reinstalled and it printed but now its back to not reconize cartridge.
You did not say if you were using "New-Epson Ink Cartridges", or actually using "Non-Epson Ink Cartridges" [Generic or Third-Party ink cartridges] in your printer. I'm assuming that you are probably using Non-Epson Ink Cartridges, because those are what normally cause that problem, with a printer not recognizing an installed ink cartridge. Unfortunatly, there is no way to make your Epson Printer use or accept that Non-Epson Ink Cartridge, if it cannot actually recognize it. Its even possible that some Generic or Third-Party brands, may not always be recognized by the newer models of Epson Printers, because of the inexpensive [cheap] and or incompatable Electrical Chips that are mounted on the actual ink cartridge. Sometimes you will even get Error Messages up on your Monitors screen, telling you that you are actually using a Non-Epson Ink Cartridge, or that your printer cannot recognize the cartridge that you installed. Sometimes the Ink Level Indicator, on your Status Monitor, will not show an actual ink level, but may indicate a cartridge error or problem instead. Not all Generic or Third-Party ink & ink cartridges are made the same and none of them actually contain the right formulation of ink, for the Epson Printers [formula is patented by Epson Company]. Some are probably close and seem to be better than others, but some simply can clog-up or even damage the Printhead Assemblies on Epson Printers, or simply won't be accepted at all. Epson Ink Jet Printers are one of the few printers on the market that seem to have so many problems with non-manufactors inks, especially the newer models made in the last couple of years. Its because the Epson Printers use a completely different printhead inking system than most other brands of printers. Most, if not all of the other manufactors, use thermal or bubble jetprint heads and because the other brands use a totally different system, they don't seem to have as many problems using refilled inks or non-manufactor's ink cartridges. Printer manufacters do not make available their ink formulation and in most cases, the formulation is patented. Any difference in the ink formulation can actually cause clogging in the small printhead nozzles or damage other critical components. One individual printhead nozzle is so tiny, that it will not accept a human hair, so you can see why they can get clogged so easily, or even why the nozzles can be so easily damaged...Even if you were actually using a New-Epson Ink Cartridge, its always possible that you got a bad cartridge. At this point, the only thing I can suggest is that you try a different New-Epson Ink Cartridge, or at the very least, a different brand of Non-Epson Ink Cartridges and see if that helps...Good Luck!
Full cartridges and it won't print. lexmark z611
A friend uses methyl alcohol to clean printheads but I don't know how. Perhaps he fills an empty cartridge...
I watched a guy professionally filling cartridges and he used steam to clean those with a printhead.
Printers that have the printheads in assembly instead of integrated into the cartridge can be difficult. Epson are like that and if not in regular use and always with a good supply of ink the printheads dry out and become blocked. The Epson service engineer told me it would be completely uneconomic to dismantle the printer and repair.
I expect it is a similar story with many printers that make a cheap ink claim. Cartridges that have the integral printhead are more expensive but seem less trouble overall.
Lexmark x4850. swapped oem with non-oem black cartridge. will not print black now. message says warranty does not support non-lexmark and prints blank pages.
“Lexmark does not support the refilling of its ink cartridges. Refilling the ink cartridges can cause them to leak, thus clogging or even damaging the print head. Any damage to your printer caused by refilled ink cartridges may not be covered under warranty”. Please use genuine Lexmark cartridges for best results.
Problem with ink refills
Yes these two should work with your model. Here's also a link to the cartridges for this model for your reference.
http://www.lexmark.com/lexmark/product/home/999/0,6970,204816596_653293766_1113019367_en,00.html?tabId=7'
"Lexmark does NOT support the refilling of its ink cartridges.
Refilling the ink cartridges can cause them to leak, thus clogging or even damaging the printhead.
Any damage to your printer caused by refilled ink cartridges may not be covered under your warranty."
Top Lexmark Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
