My unit has error 7 and error 5 on the front display. hopefully these are service codes.if we could find out what the codes mean and how to clear them..........Thanx for any help ,Will
  • 760 Answers
Please include make and model of your set. This will help in diagnosing your problem.
Posted on Apr 04, 2011
GE error E61
E61 means you have the neutral and the L2 wire either reversed or in the wrong position. ENTER TEST MODE SEQUENCE by doing the following . 1.Disconnect thepower for 30 seconds.2.Reconnect the power and within 30 seconds press the sequence of buttons listed below.3.Press the "SIGNAL"button.4.Press the "DELAY START"button.5.Press the "SIGNAL"button.6.Press the "DELAY START"button. Now after you have fixed the reveresed wiring problem you will need to remove the fault code fromt he memory otherwise the machine will not work. To remove the fault code do the following ENTER TEST MODE
SEQUENCE (cont.)
You will notice "t01". To choose the test mode that you want toverify, turn the knob to the desired test mode setting.
Push the start/pause button.To cancel the test mode, press on "power".
You will be able to choose another test mode and again press on "start/pause".
The display error codes test allows the service technician to examine and clear the fault log.
DISPLAY ERROR CODES TEST
(t02)
The control shall display the most recent error in the fault logupon entry into the display error codes test. If there are no errors in the fault log, the no error code "E00"shall be displayed on the 7-segment display.
The control shall clear the displayed error from the fault log if the start key is pressed during the display error codes test. After clearing thedisplayed error from the fault log, the appliance shall display the next most recent error from the fault log.
After clearing all errors from the fault log, the control shall display the no error "E00"code on the 7-segment display.
The control shall log the last 8 error codes in the non-volatile memory stored in a circular list.
The control shall avoid logging multiple instances of the same error code. now unplug the appliance for about 30 seconds and replug and everything should be fine
credit to the original author of this solution rcadieux4444
Jun 30, 2012 | Computers & Internet
My LG display is reading ER FF what does this mean and what can I do to fix it?
Error Code Er FF
This code is not to be confused with the O FF or demo mode error message. The "Er FF" error code indicates a problem with the unit's freezer fan. The freezer fan controls the temperature in the freezer. The source of this error is most likely ice buildup. As with the Er IF error, allowing the unit to thaw should resolve the issue. Contact customer service if the error code continues to be displayed after having thawed the unit.
Hope helps.
Apr 03, 2011 | Refrigerators
New g.e. Dryer displays a fault code e61 on screen and will not power on or clear...this dryer is brand new...straight out of box with this fault code...
Sorry to read about your problem, I hope this helps you out.
you should have a electrician work on your wiring, with luck no further damage has happened, E61 means you have the neutral and the L2 wire either reversed or in the wrong position.
ENTER TEST MODE SEQUENCE by doing the following . 1.Disconnect the power for 30 seconds.
SEQUENCE (cont.)
(t02)
The control shall avoid logging multiple instances of the same error code. now unplug the appliance for about 30 seconds and replug and everything should be fine.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Jan 02, 2011 | GE DBVH512EFWW Dryer
E000 IS DISPLAYED IN THE MACHINE
E000:
The main thermistor reading does not reach 40ºC 14 sec after the fixing
heater goes ON. (fixing low temperature error).
First you need to try reset the error code and the procedure for that is:
SERVICE MODE entry: MENU and #
If E000 through E004 is indicated, the RAM on the image processor will
retain the error memory of the fixing assembly after the power switch has
been turned off an then on. Execute the following in service mode, and turn
off and then on the power switch to clear the memory: #7 PRINTER>#4
PRINTER RESET>YES=(*).
If the error is still present after clearing, you need to dismantle fixing unit and check with universal voltmeter the lamp, by putting the DVM to buzzer mode and each ends of dvm probes put on ends of lamp, if it buzzs that means that there is connection and lamp is OK, so you need to focuse on thermistors and thermofuses or ... call service.
Hope that helps!
Aug 19, 2010 | Canon iR 1600 Laser Photo Printer
ROL services code
Press the "mode" button until "off" is displayed. Remove the screws on the control panel and tilt the panel out exposing the back of it. On the back of the board is a small square component with a button in the middle of it. Press and hold this button until SETdef is displayed on the lcd screen (about 5-7 seconds). Now push the MODE button on the front until RESfl is displayed. Now, at the same time, press the UP and DOWN buttons until two dashes -- appear on the screen (about 5-7 seconds). Now the fault history has been cleared.
ROL is an error for the Roll Out Safety Switch. This is usually caused by flames coming out from the burners to the front of the unit. NOT GOOD! Make sure you have remedied the problem and replaced the switch. Never bypass a safety switch. I am sure you knew this last section, just wanted to put in a reminder.
Jul 27, 2010 | Raypak 130,000 BTU Propane Gas Pool...
I keep getting the F21 code on my kenmore HE3t washing machine. What does it mean other than call for service?
The f21 code means that you need to clean the filter.
EXPLANATION AND RECOMMENDED PROCEDURE
F21 LONG DRAIN
If the drain time exceeds 8 minutes the water valves turn off.
NOTES:After 4 minutes the “Sd” error will be displayed, then
4 minutes later the “F/21” error code will be displayed. Press
PAUSE/CANCEL two times to clear the display.
Possible Causes/Procedure
1. Check the drain hose and make sure it is not plugged or
kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and make sure
the pump is running.
4. Check the drain pump filter for foreign objects.
5. Plug in washer or reconnect power.
6. If the above does not correct the problem, go to step 7.
7. Unplug washer or disconnect power.
8. Replace the pump.
Sep 23, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Code f 11 and f 20
its not called f-20 its caled f-02 Long Drain ----- means -------
If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed.
NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later the F02 error code will be displayed.-----------
to resolve the code ---------- Press PAUSE/CANCEL twice to clear the display. Press PAUSE/CANCEL twice to clear the display. globul1a.gif Check the drain hose and make sure it is not plugged or kinked. globul1a.gif Check the electrical connections at the pump and make sure the pump is running. globul1a.gif Check the drain pump filter for foreign objects. globul1a.gif If the above does not correct the problem, replace the pump.
code f-11 means --------
Serial Communication Error
Communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly.----------------- to resolve the problem ------------- Check Wire Harness connectors to the MCU, the motor, and Central Control Unit (CCU) globul1a.gif Check the Drive system for any worn or failed components globul1a.gif Check MCU globul1a.gif Check CCU globul1a.gif Check Motor globul1a.gif Check Wire Harness
Mar 30, 2009 | Whirlpool Duet GHW9150P Front Load Washer
E000 sYSTEM eRROR
Solution: Unplug unit for 3-5 minutes, then plug the unit back in
Unplug unit for 3-5 minutes, then plug the unit back in.
OR
I hope it helps!!!
Dec 12, 2008 | Canon ImageClass MF5770 Laser Copier...
AL 1530 Sharp
The E-7 code is a laser unit code. The laser unit is bad, the cost to repair it maybe $250.00 to $400.00 depending on the service company. Hope this helps. Let me know if you need any more help.
Chuck
Dec 22, 2007 | Office Equipment & Supplies
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
