Question about RCA L42WD22 42 in. LCD Television
When I turned off my L42 37HD tv with the remote last night it was working. This am when I try to turn it on with the remote and manually there is a green light that flashes at the bottom and nothing (usually there is a blue light and then the tv comes on)
  • wakefll Apr 04, 2011
    I fixed it myself....unplugged the tv for 5 minutes to allow it to reboot (kind of) then turned it on with the remote....worked fine, just had to reset up the channels etc.
  • RCA Master
  • 6,993 Answers
IS it a universal remote? If yes, remove the battery, wait for 10 seconds, fix the battery back in and re-register the remote with the TV by entering the code. But it the remote works with the TV without code, try again. If this doesn't fix the problem, please read further.
Try the remote with new batteries, ff new batteries did not fix the problem, then it means the problem is either from the remote or the TV.
Remote: Check the remote battery terminal, see if its not rust. Also, disassemble the remote, can check the connection between the terminal and the remote board, see if there is no disconnection of any kind.
If after checking and all seems well, then it means the remote is defective. To confirm, borrow a remote, test it with the TV. If it works, then it means you need to replace your remote. But if the remote you borrowed does not work, then it means the problem is from the TV and not the remote.
TV: There is a sensor in the TV that communicates with the remote. If this sensor is defective, the remote won't communicate with the TV.
The TV sensor might have loosed contact from inside of the TV or it maybe defective and need to be replaced.
So do the above troubleshooting and let me know if the problem is from the TV or remote. If problem is from the remote, you need to do a replacement. But if otherwise, let me knows as well.
I hope the above makes sense to you.....
Good luck.
Posted on Apr 04, 2011
  • Walesarumi
    Walesarumi Apr 04, 2011
    Okay! Happy to hear that your problem is fixed..... Good for you.
MITSUBISHI WS55907 Diamond 1080 TV bought in 2000 was powered off, unplugged, for a year. Turned the set on with remote last night and worked fine, had very crisp picture.
Your TV was waiting between 2000 and now to suffer power supply failure. It is very frustrating to go from everything working perfectly to nothing.
Oct 31, 2016 | Mitsubishi WS-55907 55" Rear Projection...
My olevia LT23HVX does not power on
Try unplugging and replugging after waiting.
Jun 13, 2008 | Olevia LT23HVX 23 in. LCD Television
My set is plugged into a cable box. the tv will not turn on either manually or with the remote.
Plug the power cord directly into a wall power outlet, and make sure that the standby light is lit (turn it on/off manually to see if anything changes). If there isn't any light, then it's most likely broken.
If the TV works again, being plugged into the power outlet in the wall, then the problem is with the cable box (i bet you figured that out too).
Jul 06, 2014 | Envision L32W761 32 in. LCD TV
Tv won't turn on
Are you using a remote, or try to turn on manually. If your remote does not work, it needs to be programed to your t.v. And all remotes and t.v.s have different codes. Sometimes your cable provider will help you program your remote, or reset your cable box. My remote for my cable was not programmed, so I had to read the instructions myself to get the remote to work with the cable box channels.
Apr 15, 2014 | Televison & Video
AH59-02402A REMOTE, WAS WORKING FINE LAST NIGHT AND EVEN THOUGH THE LIGHTS BLINKED ON IT I TRIED NEW BATTERIES STILL WILL NOT CONTROL BOX???
If it show it was doing updates, Thats probably why it wouldn,t work .Once it has updated ,IT will (Probaly) Work (Again)
Nov 07, 2012 | Televison & Video
Tv will not turn on
Look for any loose contacts in the power cord. Wear protective gloves, shake the power cord when the TV is on, and find out whether it is getting on/off. If not, the problem lies inside, like dry solder and/or leaky/dry capacitors.
Aug 07, 2012 | Insignia IS-LCDTV32 32 in. Television
MY REMOTE CONTROL DOES NOT WORK AFTER DARK
bdale
You may have IR interference at night because of other items you turn on at night. Try leaving everything off except your TV and receive, try your remote to make sure it functions. Then turn 1 item on at a time, try the remote to see if it works or stops working. Once it stops working, the last item you turned on is causing the interference. It is then a matter of relocating that item so it won't continue to interfere with the remote functions. I hope this helps.
Ray Calo
DISH Network
Nov 22, 2010 | DISH Network IR Remote Control
Universal remote-rcr3273
Pop the batteries out and use brand new batteries then try the code again. Sometimes its good to let the remote sit for a few hours with no batteries after locking up the codes.
Apr 30, 2008 | Televison & Video
TV won't turn back on
Dan27 = Recheck model # ........
lulu jr. = Slow to charge capacitor in relay / regulator power supply.......Model # , please !
Nov 06, 2007 | Televison & Video
RCA L42WD22 42 in. LCD Television Logo
29 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
