SOURCE: I have a Whirlpool Gold
The first thing you need to check is if you actually have 240 Volts going into the dryer. Sometimes one half of the (dual) circuit breaker opens and only sends 120 Volts down the line. If you hear a buzzing sound when you press "start" but nothing happens, it could be a stuck motor. Or the motor could be running but the belt is broke. There are more possible scenarios, but try this first.
SOURCE: My whirlpool dryer won't start. I have taken the
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Item # 686172
In Stock
The blower wheel draws air through the dryer
and pushes the air out the vent. If the dryer won't stop, the blower
wheel may not be spinning properly, which reduces the air flow. Check to
see if the blower wheel is securely fastened to the drive motor shaft.
Skill Level Skill Level
Part Replacement Video
$23.40
Quantity:
Item # 528055
In Stock
The heating element assembly warms the air
before the air enters the dryer drum. If the dryer won't stop, it may be
because the heating element assembly isn't working - which greatly
increases the drying time. Check the heating element for continuity.
Part Testing Video
$91.05
Quantity:
Item # 2659
In Stock
Dryer sheets and fabric softener can leave a
residue on the lint filter, reducing the air flow. If the dryer won't
stop, check to be sure air can flow freely, clean the filter as needed.
$38.95
Quantity:
Item # 469522
Although not as common, if the dryer won't
stop it may be because the moisture sensor is either defective or coated
with fabric softener. Clean the moisture sensor contacts inside the
dryer and th
