Question about Lucent Lands Phones
I have Lucent Partner - 18D, Calls and dial tones keep cutting out and coming back on. I have ruled out phone lines and have unplugged phone box. What is the problem?
  • Lucent Master
  • 2,460 Answers
If the processor sits in a 2 or 5 slot carrier, double check that the card is seated firmly in its slot. There's a plastic clip on the bottom of the card that keeps it locked into place and sometimes it comes loose. When you lose dial tone, check the lights on the face of the cards. You could have one card causing the rest to fail or just not secure.
If that doesn't fix it, it's probably time for a repair technician or start swapping card positions. You could start with pulling everything but the Processor and see if the trouble goes away, then add cards into the system.
Carl
Posted on Apr 04, 2011
Lucent 18D line 1 drops calls that were on hold
Did not get a solution to my problem but will keep it like it is. We like the phones but just had a simple question and could not get to talk to a person to explain it.
Mar 03, 2014 | Avaya Lucent / Partner Euro 18d Phone -...
I have a lucent Partner 18d telephone. I want to be able to have a button programmed so that the secretary can transfer incoming calls to outside phones ( call comes in, secretary presses a button, dials...
That is not possible on the Partner ACS. The oONLY thing that would be close to what you want is Remote Call Forward.
As long as you have a Partner ACS release 6 or higher,
You need to set the permissions on a phone, then set that phone to forward out to teh external number. Then when calls come in, you transfer to that phone, which will forward to a cell or external number....boom, done!
Thats it though.
Oct 14, 2010 | Avaya Corded Phone avaparp18d
Lucent Partner 18D cant fully reboot itself
That one doesn't sound too good.
You could perform a reset through programming which should clear the scratch pad.
Thats done by entering programming on either ext. 10 or 11
Press feature 00 then the left hand intercom twice.
Next enter # 728, the display should say reset save all then reboot the system.If the problem is still there, then the processor is malfunctioning and will need to be replaced.
Dec 04, 2009 | Avaya Corded Phone avaparp18d
Lucent Partner 34D phone system with 18D extensions
That doesn't sound good at all. I would first try powering down the system and waiting about 15 seconds or so before powering back up. If the problem remains, the processor was some how damagedand would be best if it was looked at by your vendor.
Sep 25, 2009 | Avaya Lucent Partner 616 Phone
Ayaya Lucent Partner 18D Cordless call waiting.
The cordless will not work that way. If you hit flash, that will put calls on hold, etc....
The only thing you can do is have the flash button on the 18D itself.
Aug 28, 2009 | Avaya Lucent Partner 616 Phone
I HAVE A LUCENT partner 18D PHONE AT MY OFFICE.
What voicemail do you have currently?? When you dial into voicemail, what does the voicemail lady say? "Welcome to Partner......."??????? Need to know that first.
Jun 04, 2009 | Lucent PARTNER18 Corded Phone
Avaya 18D unable to make outgoing calls
Sounds like you changed your line selection. Changing line selection on a Partner system is done on either ext 10 or 11.
At one of those ext's press the feature key and "00"
Next press the left hand intercom twice
The display should say system programming
Press the right hand intercom once. The display should say Centralized Programming.
Enter in the extension number that you want to program.
enter **
press the lit line in the order you want the to be used, i.e. line 2 then line 3 then line 4 etc.
enter ** when finished with line selection
Press feature "00" to logout
Hope that helps
Mar 20, 2009 | Avaya Partner 18D Display Phone (315807BA)
Static in phones
Static on Partner systems is not too uncommon and more likely as the system ages. These systems use relays (electric switches) to connect to outside lines and extensions. The static is usually from a faulty relay, but sadly these are not really repairable by end users. A power outage is sometimes associated with spikes - short high voltage conditions that occur as the power comes back on. Any vulnerable component may fail at that time. The solution is to replace the bad circuit pack. These are available used - just use your search engine. Prevention can be as easy as installing a good surge and spike protector power strip between the system and the outlet.
Dec 31, 2007 | Avaya Lucent Partner 616 Phone
Lands Phones Logo
101 people viewed this question
Top Lucent Lands Phones Experts
george  peters
george peters
Paul C.
Level 1 Expert
tfelton3
Are you a Lucent Lands Phone Expert? Answer questions, earn points and help others
