Question about Kitchen Ranges
My 6.5 cz will start but will not run. I have checked the sensors and they appear to work properly but I am wondering if wire #37 to all sensors and to the relay board should always sow short to ground even when I disconect the coolant sensor wiring?I also do not get voltage showing at the gauge,it starts to then shuts down,I replaced the capacitor to no effect.I have a rotor diode board but have not installed it,is there a way to test the relay board?also if i have to replace the rotor diode board do I have to remove the bolt in the end of the stator?thanks for your help!
nucklebuster
SOURCE: error codes F2 and F3
Two months ago I asked fixya about a g.e. oven with a f3 code. that evening a reply suggested I replace the oven sensor. I took the old one to the parts place, told the repairman about the code,and he told me the sensor WAS the problem. I replaced it, and WOW it fixed it! Today it faulted out again. I will pull it again and check it. It was installed correctly.The problem for a f3 fault IS the sensor.
Posted on Jul 29, 2007
SOURCE: JBP66G W1AD Oven won't get hot enough
the yellow may be the oven temp sensor?
Posted on Jul 01, 2008
  • 166 Answers
SOURCE: 2004 gto ls1 motor is running rich and dtc code is P0131
that would be your best bet it is very hard to diagnose a injected v8 with out the right equipment but speaking from experience ( due to the fact we in Australia built these cars) the oxy sensors cause all sorts of problems and swapping them over does't necercarly prove much
Posted on Dec 20, 2008
ilragatzzo78
  • 241 Answers
SOURCE: 94 dakota 5.2 - where is ''roll over'' sensor located on vehicle?
un-plug the ecm " computer module " it should be under the hood by the passengers side on top of the fender.
it's a box with three connectors to it.
un-plug them all three for 5 min or so.
and plug them back up.
see if that helps to start it.
i had a 96 and i replaced everything and still will stall or have problems starting it up.
finally i un-plugged the computer and it will run fine for 15 or even a month without any issue, so my conclusion was that the ecm was bad.
Posted on Feb 15, 2009
  • 221 Answers
SOURCE: wire connector between stator & voltage reg/rectifier burnt
your voltage/reg. can be tested in a couple different ways check ground res. check res. then revs. bias on diodes you have ac in dc out it sounds like you may have a diode gone bad allowing ac curent to flow causing the wires to get hot
Posted on Jul 31, 2009
The ignition button wont work
Hi, Ryan before testing any electrical component in the Starter Circuit it is "IMPERATIVE" that you have a fully charged battery of 12.5 volts or more and be able to pass a proper "LOAD" test because your battery may have 12.5 volts or more but little or zero amps causing the battery to be faulty and must be replaced, especially "AGM" batteries.
1. Ignition Switch not in the "ON" position.
2. Engine Run Switch in the "OFF" position.
3. Check the battery terminals for damage or corrosion check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter.
4. Bank angle sensor needs a reset or is faulty.
5. FOB battery low or dead.
6. Faulty ignition switch.
7. Faulty starter button.
8. Faulty kickstand or clutch pull in switch/sensor.
9. Security alarm needs a reset.
10. Starter relay, solenoid or starter circuit wiring faulty.
11. Starter armature or field coils have failed.
12. Main fuse or circuit breaker may be blown or faulty.
13. The electric starter is working but starter clutch has failed.
14. Check for engine trouble codes.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Ktm Duke 125 Will Not Start
HELP Starting problem KTM Duke 125
http://www.ktm.com/globalassets/product-manuals-pim-data/dok_bike_bed_13_3211963_en_om__sen__aepi__v1.pdf
http://www.partsfish.com/page/oem-parts-for-ktm
http://www.motogelnar.cz/manual/KTM/KTM125-200_1999-2003ServiceManual.pdf
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Apr 10, 2017 | KTM 2013 125 DUKE
Why does my speedometer on my 2006 Harley electra glide stop working & then start working again
Hi, Charlie the vast majority of speedometer issues is caused by the speed sensor and or the wiring, a faulty speedometer sensor and or connection will automatically interrupt proper turn signal and flasher operation. On Sportsters the sensor is located on top of the engine case behind the rear cylinder, on big twins, it's located on the right side of the transmission case between the starter end cap and the transmission top cover. Remove the bolt/screw that secures the sensor and lift the sensor out of the case. Inspect it for damage and contamination, if there appears to be no damage wipe the end of the sensor clean and reinstall, you can go for a short quick test ride to see if the speedo is working. If the issue still exists grab your test light and unplug the harness connector from the sensor, check for power (red wire) and ground (black wire) continuity coming from the speedo, there is also the connector that plugs into the speedometer, also, look for corroded, broken or loose pin/sockets. If everything checks out OK then replace the speed sensor.
For more information about your question and valuable "FREE" downloads that you will need please click on the blue links below and for more specific information or answers at no charge please feel free to contact me at xlch@mail.com. Good luck and have a wonderful day
Speedometer stops working Harley Davidson Forums
http://www.carlsalter.com/pdfs/Harley_Davidson_FLHRC%202006%20Maintenance%20&%20Repair%20Manual-Full.pdf
http://partsfinder.onlinemicrofiche.com/ronnies/showmodel.asp?make=hdmc
http://mybikemanuals.com/harley-davidson/2006-harley-davidson-owners-manuals
Instant Tech Relief To speak with me personally absolutely "FREE"
Mar 17, 2017 | 2006 Harley Davidson FLHT Electra Glide...
My dt 125 is not starting
Hi, Anonymous and the usual suspects are:
1. Spark plugs in bad condition or have an improper gap or are partially fouled.
2. Spark plug cables in bad condition.
3. Battery nearly discharged, should have 12.5 volts.
4. Discharged battery, check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
5. Throttle controls not adjusted correctly.
6. Water or dirt in the fuel system.
7. Water or dirt in the carburetor.*
8. Intake air leak.
9. Fuel tank vent hose and vapor valve plugged, or fuel line closed off, restricting fuel flow.*
10. Enricher valve inoperative.*
11. Engine lubricant to heavy (winter operation).
12. Ignition is not functioning properly (possible sensor failure).
13. Faulty ignition coil.
14. Valves sticking.
* Carbureted models.
For more information about your issue and valuable "FREE" downloads that you will need please visit the websites below. Good luck and have a nice day.
https://yamahaclub.com/forums/topic/26695-dt125r-wont-start
DT 125 Cut out now wont start
http://www.motogelnar.cz/manual/YAMAHA/DT125X_RE-05-Service_Manual.pdf
OEM parts for Yamaha
http://www.dt125.cz/download/Owners_Manual-DT125X_RE.pdf
Jul 30, 2012 | 2003 Yamaha DT 125 R
2005 grand caravan 3.8L what is proper resistance for good fuel pump?
Fuel injectors not firing ? Did you hook up a fuel pressure gauge an check pressure ? Anti-theft system problem ! Probably not bad fuel pump. Your missing something .
Mar 06, 2018 | 2005 Dodge Grand Caravan
I have a Yamaha DT125X 2006 model which i have had for about 3 years. Its always been a good runner and since iv had a car i obviously havent used it much, but i went to start it the other day and...
Hi, Ben_paice before testing any electrical component in the Starter Circuit it is "IMPERATIVE" that you have a fully charged battery of 12.5 volts or more and be able to pass a proper "LOAD" test because your battery may have 12.5 volts or more but little or zero amps causing the battery to be faulty and must be replaced, especially "AGM" batteries.
10. Starter relay, solenoid, starter have failed or circuit wiring faulty.
Thread DT 125 won start
What to Do Check When Dirt Bike Won Start
Yamaha DT125RE 2005 Service Manual
May 11, 2017 | 2006 Yamaha DT 125 X
2003 KTM 660 SMC will not start
Hi, 660smc and the usual suspects are:
1. Fuel tank empty.
2. The fuel tank has old dead gas.
3. Fuel tank bottom contaminated with ethanol sludge, dirt, water, rust, etc.
4. Fuel supply valve/petcock turned off.
5. Fouled spark plugs.
6. Engine flooded as a result of overuse of the choke.
7. Vacuum hose to the fuel supply valve/petcock disconnected, broken, cracked, or pinched.
8. Fuel valve/petcock or filter clogged.
9. Fuel line to carburetor or throttle body pinched, kinked or blocked.
10. Carburetor float stuck.
11. Fuel injectors clogged.
12. Fuel injectors stuck open.
13. Quick disconnect check ball stuck.
14. Compression below 75 PSI.
15. A stuck-bent-burnt valve.
16. Severely discharged or a damaged battery should have 12.5 volts or more and be able to pass a proper "LOAD" test if necessary, you may have a cursory reading of 12.5 volts or more but little or zero amperage the battery is faulty and must be replaced, AGM batteries fail in this scenario more so than lead-acid batteries.
17. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
18. Loose or corroded wire connection at the coil or plug between ignition sensor and ECM module.
19. Spark plug cables in bad condition and shorting check for spark leakage in the dark, cable connections are loose or connected to the wrong cylinders.
20. Ignition timing incorrect due to a faulty ignition coil, ignition module or MAP, CMP, CKP, O2, TPS, ETP, IAC sensors.
21. Faulty neutral, clutch, kickstand safety switch.
22. Faulty fuel pump or fuse or relay.
23. Faulty or corroded run/stop switch.
24. Tilt sensor needs a reset.
25. Security system not disarming alarm needs a reset.
26. Check for engine trouble codes.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
ktm 660 smc wont start
Running KTM 660 SMC helpful tips
http://www.motogelnar.cz/manual/KTM/KTMLC4.pdf free service manual
https://www.partsfish.com/page/oem-parts-for-ktm
KTM 660 SMC 2003 Owner Manual
Jan 25, 2018 | 2003 KTM 660 SMC
Temperature gauge is broken, needle is constantly on cold
Check the obvious first!! Check the wires to the sensor on the engine are clean and price up replacing the actual sensor as well. If it's running a fan belt it'll be spinning as soon as you start the engine so won't affect the engine. It's only the more modern belt-less electric ones that depend on a sensor to work.
On a car that old it could be as simple as the gauge on the dash has died. Price up a replacement set of second hand dashboard dials and swap them yourself. It's a fiddly job but not hard.
Dec 25, 2017 | Volkswagen Golf Cars & Trucks
2006 yamaha straoliner, engine code 37 comes up
Displayed Fault Codes For The ‘Liners
  • 12 - Crankshaft Position Sensor <<Dead Engine>>
  • 13 - Cyl #1 Intake Air Pressure sensor (open or shorted)
  • 14 - Cyl #1 Intake Air Pressure Sensor (hose system) - Clogged or detached
  • 15 - Throttle Position Sensor (open or shorted)
  • 17 - EXUP Servo Motor Ckt. (open or shorted)
  • 18 - EXUP Motor Locked Up – Frozen
  • 19 - Blue/Black ECU wire broken or disconnected <<Dead Engine>>
  • 22 - Air Temp Sensor (in headlight) (open or shorted)
  • 24 - O2 Sensor – No Normal Signal Received
  • 25 - Cyl #2 Intake Air Pressure Sensor (open or shorted)
  • 26 - Cyl #2 Intake Air Pressure Sensor (hose system) - Clogged or detached
  • 28 - Engine Temp. Sensor (open or shorted)
  • 30 - Lean Angle Sensor Latched Up (Bike Laid Down) <<Dead Engine>>
  • 33 - Cyl #1 L. or R. Faulty Ignition Coil << May Run >>
  • 34 - Cyl #2 L. or R. Faulty Ignition Coil << May Run >>
  • 35 - Cyl #1 L. or R. Faulty Ignition coil << May Run >>
  • 36 - Cyl #2 L. or R. Faulty Ignition Coil << May Run >>
  • 37 - ESC Valve Stuck Open (Engine Speed Control / High Idle Speed)
  • 41 - Lean Angle Sensor (open or shorted) <<Dead Engine>>
  • 42 - Speed Sensor – No Normal Signals Received OR Neutral Switch (open or shorted)
  • 43 - Fuel System Voltage (ECU Unable to Monitor Batt. Voltage)
  • 44 - Error In Writing Amount Of CO Adjustment To EEPROM
  • 46 - Voltage To F.I. System Not Normal
  • 50 - ECU Internal Failure – Memory Check <<Dead Engine>>
  • 70 - Engine Idling Stop – After 20 Minutes Of Idling
Apr 08, 2009 | 2006 Yamaha Stratoliner S
1994 dodge caravan, 2wd, 3.0 engine
12 - battery recently disconnected. 21 - Oxygen sensor signal doesn't change (stays at 4.3 - 4.5 V) possibly bad O2 sensor 37 - Transmission temp. sensor reading low.
There are many options that can cause these problems, but loose wiring to the battery and a weak alternator would be one of the first things to check.
Sep 16, 2008 | 1996 Dodge Caravan
Kitchen Ranges Logo
37 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
