I have a Phillips magnavox it powers on then shuts off in seconds????
    Sergeant:
    Champion:
  • 277 Answers
Its the power supply it going to protect you need to take it in
Posted on Apr 04, 2011
Phillips/Magnavox tv shuts off after a few seconds led stays lit model # 32PS55S321
SDA [Serial Data] line should be checked. It is a skilled job. Best is to contact any expereinced service technician.
Sep 04, 2013 | Televison & Video
Magnavox ZV450MW8 shuts off within 10 seconds of being turned on
The problem is in the power supply, one or two capacitors fail and sometimes have a slight puff at the top, need to be replaced.
Mar 18, 2012 | Magnavox ZV450MW8 DVD Recorder VCR
We have an older Phillips Magnavox tv. The tv will turn on & we will see the picture for a short time but then the screen turns grey. We still have sound, just no picture. Also, the green power light...
Hello, the grey screen could be due to a missing 220Volt source which feeds the color (RBG cathodes)inside the CRT(picture tube). When this happens the beam current inside the CRT goes high in a matter of second, thus triggering the beam current protection circuit(blinking green light)shutting down the TV. Repairing the secondary voltage source is necessary to get the TV working normal, a good technician should be able to repair it for between 80 to 100 dollars parts included, except a picture tube, which could be also the cause of the problem(K-A shorts).
Nov 06, 2010 | Philips Magnavox 27MS343S 27" TV
I have the Phillips/Magnavox 3 CD Rotary Changer System and when I try to power down, it shuts off for a few seconds and then goes into Demo mode. How do I power off completely?
without the model number i cant be exact, but if memory serves me you either hold down the demo or display switch for about 5 or 6 seconds
Sep 07, 2010 | Audio Players & Recorders
Magnavox 19" TV shuts itself off.....won't stay on
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
Jun 04, 2009 | Philips Magnavox 27MS343S 27" TV
Phillips Magnavox Model 20MT1331/17: It shuts off
The poster, Jim K, is probably in possession of at least a layout of the power supply and the 'location' is likely derived from a grid used to physically find parts on a board.
220 uF is a common value for an electrolytic capacitor and the 200V is the rated sustained DC voltage it can tolerate.
The 130 volts could be caused by a capacitor that is failing and not smoothing the rectified voltage as it should.
In other words, you kind of need a tech.
Apr 13, 2009 | Philips Magnavox 42MF521D/37 Television
Magnavox 15inch lcd shuts itself off
Solutions?
Hope this helps
Mar 15, 2009 | Philips Magnavox 15MF400T 15 in. LCD...
Phillips projection tv wont turn on and power button flashes
There is no Code for tuning power off/on You may have bad STKs. If 1 of these ics goes bad it will shut set off so replace them both,.
Dec 23, 2008 | Philips Magnavox 51MP392H Rear Projection...
Phillips/Magnavox 9P5544C102 white raster and shuts down
This denotes a problem called blooming the horizontal lines you see are called retrace lines this is caused by the increase in anode voltage which could be caused by an increase in HV section current which trips the overcurrent protection dircuit and turns the TV off.If you do not have electronics experience I would suggest taking the set to a TV repair shop.
May 29, 2007 | Philips 9P5544C 55" Rear Projection...
Televison & Video Logo
12 people viewed this question
Top Televison & Video Experts
