Steveandpam2011@yahoo.comOur Payne propane heater blower turns on then the ignitor ignites then flame goes out. Intermittent problem Help, Service people have been out twice. Circuit board and pressure switch replaced. problem continues.
  • 40 Answers
The flame rod is dirty and needs to cleaned or replaced.
it is a thin metal rod that sits in front of the flame.
remove one screw and it will come out try cleaning it
with some steel wool. This should solve yoyr problem
Posted on Apr 04, 2011
Testimonial: "The heating company was out again, he said the drain level was not leaning down far enough to drain. Will try what you suggested. Thanks"
Solid diagnostic light, fan comes on, ignitor works, furnace lights, then goes out after 2-3 seconds---help
Hello, sounds like a dirty flame sensor, this is a metal rod on the oppsite side of the hot surface igniter. All you need to do is remove the flame sensor and clean it with some steel wool and reinstall.
Dec 02, 2011 | Mr. Heater Propane Heater - 60,000 BTU
I have an H 300 propane heater showing an HF code, cleaned all gas orifices and replaced the ignitor. Still comes up with the HF code any ideas.
Here is an answer written by Stephen Dorje. I think it should help.
This means the flame sensor/ignitor has failed. You are either not getting spark or the burners are not igniting if you are getting spark, I would recommend replacing the sensor/ignitor. Pretty inexpensive and a fairly easy fix. Here is the owners manual for the unit (not Lo Nox)....
Hayward Heater Manual link
Answered by 8c79505.jpgStephen Dorje Over a year ago
Sep 03, 2011 | Hayward H Series Pool & Spa Heater 400k...
I am getting an ignition lockout code on the digital readout. what would be the cause? it sparks and calls for heat and will fire for about 2 seconds and then the ignition lockout code is displayed as the...
Ignition Lockout on this unit means #1 that it is set up on propane. If you are low on propane, or were low on propane and just refilled, low/no gas pressure could be the issue. If you ran out of propane, thre is now air in the gas line that needs to be fully blead out.
If propane level is not the issue, replace the ignitor.
The ignitor on these units is also the flame rectifier (flame sensor). If the unit is firing up, but the computer thinks that it is not, then it is not sensing a flame. Replacing the flame rectifier/ignitor will fix the problem in this case.
Jul 07, 2011 | Rheem M206A 206K BTU Pool and Spa Propane...
I HAVE PROBLEM WITH HEATER IS SWOING 1F IN THE SCREEN
YOur 1f code is actually a IF code which stands for "ignition failure".
This can be caused by many things, but the most likely is either the ignitor has failed, or the flame sensor has failed.
Make sure the gas manual gas valve is open. Remove from panel so that you can see the ignitor.
Turn off power, then turn back on. After 90 seconds, the ignitor should start to glow red hot. If this is not occuring, then it is likely the ignitor or ignitor wiring.
If the ignitor does glow, then the heater ignites, but still goes off showing the IF code, then it is the flame sensor.
If the ignitor glows, and the heater does not ignite, it is likely the gas valve or ignition control.
As stated above, the ignitor is most likely.
Dec 30, 2010 | Hayward H Series Pool & Spa Heater 400k...
I have problem with the heater is swow in the screen f1
Dec 30, 2010 | Hayward H400fdp Low Nox Propane Swimming...
Does anyone know if the igniter also works as a flame sensor on a hayward h200 pool heater its an electronic ignition heater without a pilot light
Yes it does. Flame rectification is carried back through the ignitor assembly ground. Be sure all the points of contact are rust free between the ignitor assembly and the chassis.
Aug 10, 2009 | Hayward H Series Pool & Spa Heater 200k...
Coleman evcon furnace
is the air filter clean afc could be dirty
Dec 22, 2008 | Coleman Propane Forced Air Heater...
Ignition failure code on
Sounding like a flame proving device is failing to sense flame. Try to clean the device with some steel wool. It is located right next to the last burner looks like a thick wire. Take the steel wool and gently rub the carbon that has built up off. Should only take 4 or 5 strokes. Let me know it that did it. Ken
Nov 30, 2008 | Coleman Propane Forced Air Heater...
Payne Heater
The flame will not start, but the blower runs...
Oct 16, 2008 | Heating & Cooling
Heating & Cooling Logo
103 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
