Question about ASUS G71G, G71V, G72G, G72Gx, G72Gx-A1 (A19150M3100153B00)
Laptop does not boot. I guess no bios reaction. how to reset bios? only instant keys light up. drive activity indicator lights up very shortly aswell as touchpad lock indicator.
    Sergeant:
    Champion:
  • 277 Answers
You need to take out the small battry from the mouther board to reset the bois
Posted on Apr 04, 2011
My Asus X553M laptop is not booting up. Any ideas how to fix this problem?
Temitope, Hard reset. Open computer, remove battery,hold power button down (((1 minute))), reinsert battery, reassemble laptop, push/hold power button a couple seconds.
2nd fix, try to boot laptop without hdd.(hard drive). Remove the hdd, then turn on the laptop.. then it can get into the bios.. reset the bios to the default setting, turn off the laptop, and then turn it on again with hdd reinstalled. This seems to be what works in the forums with this issue found in Asus laptops. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Asus Laptop unable to boot black screen no bios
How to Fix Laptop that Won Turn On Asus X551M
Laptop Won Turn on Fix How to Hard Reset Laptop
Asus laptop not booting
Aug 21, 2016 | ASUS Computers & Internet
Laptop hp cq62 not start, black screen. after pluging ac cord he start itself, and after that, it is impossible turn it of.
You can generally only flash a bios if you can get the machine to boot up into some operating system. Do you get ANY on-screen logos or messages when you apply power to the laptop? Can you get into the bios when you power up the laptop and press Esc (or F2 depending on your model)? Do you hear any sequence of 'beeps' when you power up the laptop? A series of short/long beeps when powering up indicates some kind of error detected by the Power On Self Test (POST) routine. Do you have the HP recovery CD for your laptop? Have you put it in your CD Rom drive and tried to boot up? Check the manual at HP Support for a hard reset procedure- you could have a bad power button board or other hardware problem-it is not usually a BIOS problem.
Jan 28, 2015 | HP Computers & Internet
Laptop wont turn on, got green pwr and amb bat but will not fire up
Systems covered: All failing to boot without lighting up display.
Goal of this Solution: Try to determine whether system is (a) booting successfully while failing to light its display (indicating hardware failure in the display), or (b) failing to light the display due to failure to successfully transfer control to ROM BIOS (indicating a motherboard failure).
The fact that the Green power LED, and Amber Battery LED are lit seems to exonerate the laptop power supply (brick) circuitry. Even with a nearly dead battery, a Toshiba Satellite 1135-s1552 should work while plugged into a properly functioning brick.
Here's Toshiba support's (244 page) online PDF version of your laptop manual:
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=SB&os=&category=&moid=434997&rpn=PS113U&modelFilter=1135-S1552&selCategory=2756709&selFamily=1073768663
If the HDD (hard disk) activity indicator LED is active after power-on, then your system has actually got past BIOS and is booting - your LCD monitor inverter circuit or Backlight may have burned out - and to use the system, you'll need to connect an external monitor to the RGB monitor port on the back of the system (see illustration on page 32 of User's Guide) to view system activity.
Alternatively, one may attach an analog TV, using the S-Video port on the back of the laptop (see illustration on page 32 of User's Guide).
Once an external monitor is working to display the ROM BIOS part of the boot sequence, you may find that the ROM BIOS is good enough to run a few BIOS-based diagnostics. Run them all - something may indicate the source of the boot failure. Ofttimes, enough of the motherboard remains good to provide interaction with the ROM BIOS, but some motherboard failure will subvert a full boot to Windows/Linux. An example of this type of failure would be a failure of the PCMCIA bus controller, which is vital for booting a disk-resident OS, but unaccessed (except by BIOS diags) when the user interacts with BIOS. Another common failure of this type is main memory (RAM) failure.
A working external monitor/TV also provides a chance to backup important laptop data to a flash drive, sky drive, or CD-RW discs.
If no HDD activity is seen after power-up, then either your BIOS is hosed (in which case you'll need a new motherboard), or another motherboard component is hosed (in which case you'll need a new motherboard).
You may want to transplant the HDD into a working PCMCIA-bus system (any laptop) to recover/backup your important data.
If someone recently attempted and failed to update the motherboard's ROM BIOS, then you know why the system is failing to boot and also failing to light the display.
Here's a link to a site with disassembly instructions for Toshiba laptops:
http://www.irisvista.com/
Most dead laptops (even those whose power supplies have been burned out by a nearby lightning strike with the system on 120 VAC power) will still have perfectly usable HDD module(s), and RAM memory cards, so that at the very least, these removable components may be recycled into memory reserves for your next laptop or sold (Ebay.com) to help defray the cost of a new system.
Dec 14, 2011 | Toshiba Satellite Computers & Internet
Hello! Please help in the following situation: Laptop Qosmio G45 AV-680. When you turn on the indicator disk is lit and extinguished seconds 2. Next is the proprietary screensaver Qosmio then black...
If you have nVidia video card in your computer it is going bad. If you still have warranty it is about time to use it.Oh, and if you have Intel video chipset-same thing. I am sorry, but there is no solution for this kind of problem - except new computer with ATI video card.
Feb 19, 2011 | Toshiba Qosmio G45-AV680 Notebook PC
Laptop just beep for few seconds and goes off when put on
Check the battery. Remove and re-install. Also try booting with AC power and no battery. It the battery is shorted It can draw all the load and cause the thing to hang. Its also possible a keybd button is stuck or mashed down. Try pressing and rubbing all the keys and then rebooting. You should be able to boot and see your normal Bios boot prompts. Try tapping F2 or F8 when you hear the beeps. Check the hard drive activity light, does it blink and flash. What about the power light? Does it come on. There are beep codes that do different things and help tell you codes. But you'll have to count the number of beeps and pattern, Long short long pattern. Then somewhere on the Dell web site the list what beeps mean what. Good luck, every detail is a clue.
Jan 21, 2011 | Dell Computers & Internet
When i switch on my laptop, the bios is unable to load, usually the activity light will flicker but now there is no response. then it will auto shut down by itself. i have already tried to power my laptop...
IT may be the hard drive has failed. If the drive fails to boot, the operating system will not function and thus, no activity. From all indications, your power supply and battery are OK.
Feb 17, 2018 | Acer Computers & Internet
Laptop won't boot, not even into BIOS. Screen stays blank it'll turn on for a bit (black screen) then switch off. Hard drive seems active, the only error indication is the caps and scroll lock flashing. It...
You need to launch the Last know good configuration to get this fixed.
Follow the steps below,
Step 1: Shut down your PC completely.
Step 2: Turn on the Power button.
Step 3: As soon as you turn it on start hitting the F8 key on your keyboard until you get to a black screen called "Windows Advanced option". (If you don't get to that that screen but you end up reaching the blue screen than that means you have delayed in hitting the F8 key. start again from step 1.)
Step 4: As soon as you reach "Windows Advanced option" use your down arrow keys to choose an option called "Last know good configuration".
Step 5: Select that and HIT ENTER.
Step 6: you PC will boot to the windows. If this fails then you need to perform repair install using the Operating system CD.
Dec 10, 2010 | Computers & Internet
Laptop powers on but screen does not light up. A
knowing the model i would be inclined to say that your graphics chip has got a BGA issue, this commonly happens when the board is flexed and is rampant in all sorts of laptops. alternatively try removing your ram,it'll be under a cover on the bottom of the laptop. if with the memory removed your getting the same issues your best getting it to a shop and saying its got a vga chip problem, just make sure they dont charge you for telling you what you already know
Sep 26, 2009 | HP Pavilion DV6700T Notebook PC
Toshiba Satellite P200 doesn't boot
Try pressing FN/F5 keys simultaneously, or the key that toggles internal/external Display. Look for the double screen Icons on the keys.
Tap the Pause Key.
Restart and press and hold F8 key when Toshiba logo appears. When the boot Menu appears, select Last Known Good Configuration.
If all else fails ther should be a reset button on the side of the LT. Consult owners Manual for location
Aug 15, 2008 | Toshiba Satellite A100-S8111TD Notebook
Processor issue? bios/motherboard?
First, Pull the hard drive. If the hard drive shorts out it can cause all sorts of problems. Generally it detects Hdd before mouse and keyboard.
Apr 18, 2008 | Averatec 3200 Notebook
ASUS G71G, G71V, G72G, G72Gx, G72Gx-A1 (A19150M3100153B00) Logo
417 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
