Question about LG 50PK550 50 in. TV
My LG 50PK550 50"
  • 140 Answers
SOURCE: LG RZ42PX11 PICTURE PROBLEM.
I do not know who was helping you before but the problem you are having can be caused by three boards in the tv each by themselves or in combination. Those are the control board with part#6871QCH053G, the Y- board part #6871QYH036D or the Z-board part#6871QZH041B. Without being able to do voltage and signal measurements directly for you, the Z-board is likely the culprit here. But I will tell you that even experienced tv technicians find themselves swapping one or more of the boards until they fix the problem. I am assuming here of course that you have not had problems with your tv before. The part #s I have given you are for the improved boards that LG has assembled to take care of future similar problems and come with their latest training manual for technicians. God bless and good luck.
Posted on Jan 15, 2009
SeanAnthony
SOURCE: 50 inch plasma blank screen
I bought my Philips Magnavox 50" plasma in June of 2007. In february of 2009, I noticed increasingly longer delays in the video coming on after turning on the power and then the audio began to delay coming on. After a few weeks of this problem the audio and video then stopped coming on at all. However, there was power going to the unit because the green power light was working. I noticed over 50 other consumers on this website had the same problem. WITH THE HELP OF OTHERS ON THIS WEBSITE, I HAVE FIXED THE PROBLEM FOR $40. YES, FOR LESS THAN $100.00 I HAVE A WORKING HDTV AGAIN, BUT WITH NO THANKS TO PHILIPS - MAGNAVOX. THEY WERE USELESS.
HERE IS THE FIX:
1. Unplug your power supply cord.
2. Remove back panel on your HD.
3. Look for capacitors that have a bubbled or slightly raised and rounded top. This indicates the capacitors have overheated or leaked and need to be replaced. The normal look is a flat surface with no raised features at all. (I had two bad capacitors that were side-by-side and identical: 3300uf 10v. Also, they should be located on the power supply board. My power supply board is in the middle of my 50" plasma.)
4. Go to an electronics repair store or Radio Shack and see if they carry your capacitor type and size and replace them yourself if you are comfortable with removing the capacitors and soldering new ones to the power supply board. The capacitors will cost you $2.00 each or less.
5. I was not comfortable replacing the capacitors myself so I removed the power supply board by removing the screws and unplugging several wire connections. This was not difficult at all. I then brought the power supply board to a local electronics shop that did repairs on HDTVs and simply asked them to remove the bad capacitors and solder two new capacitors onto the power supply board. They did it for $40, which included cost for the 2 new capacitors, while I waited and it only took about 10 minutes.
6. I replaced the power supply board and back panel of TV and it worked!!!
Some people on this sight suggested replacing the capacitors with some that have higher temperature ratings. Based on that advice, I wanted to replace my two that were bad (3300uf 10v) with two rated at 4700uf 35v, but my electronics guy suggested against it. Instead, I replaced mine with 3300uf 50v, with the only difference from the original parts being the higher voltage (50v instead of 10v). I figure if the problem occurs again, I now know I can get it fixed for less than $50.00. Philips - Magnavox should be ashamed for such poor customer service and not telling people about this simple fix. When I called their customer service support number I was simply directed to a repair place --over two hours away!!!
Posted on Mar 05, 2009
  • 10 Answers
SOURCE: 50 inch plasma full hd shuts of for no reason lg
is the sleeper set on it?
Posted on Jul 19, 2009
tvservice306
  • 458 Answers
SOURCE: 50'' plasma LG 2009 no picture
IN WARRANTY TRY CALL BESTBUY IN HOME SERVICE FOR FREE......
Posted on Sep 14, 2009
  • 8457 Answers
SOURCE: LG 50 inch plasma has trouble powering up. have
Power supply board have dead capcitors.Know how to solders?These capacitors usally bulge or pop open,replaced these capacitors will solved this problem.Or tries websites Shopjimmy.com,Ebay.com to buy a Whole reburbish power supply board for the replacement.
Posted on Mar 10, 2010
Sinotec TV, I'm trying to connect dvd or Ps it says no signal
Check your AV cables. when the AV cables are connected to the TV, select AV mode on your TV. Remember you might have more than one AV mode ie AV1, AV2, AV3.........
May 21, 2016 | Televison & Video
Tip
SERVCIE MODE
Panel Check
You have to check Panel Maker Because of different adjustments as follows. First of all, Check the label rating!
1) Label Rating File
- LCD PANEL MARK
A:ACER(AUO) S : SEC C : CMO
* If not printed you could consider S(sec) panel mark.
Method of Color Calibration (AV)
1) Apply the NTSC Lattice (N0. 3) pattern signal to the AV IN 1 port
2) Press the Source key to switch to "AV1" mode
3) Enter Service mode
4) Select the "Calibration" menu
5) Select the "AV Calibration" menu.
6) In "AV Calibration Off" status, press the " RIGHT ARROW" key to perform Calibration.
7) When Calibration is complete, it returns to the high-level menu.
8) You can see the change of the "AV Calibration" status from Failure to Success.
Method of Color Calibration (Component)
1) Apply the 720p Lattice (N0. 6) pattern signal to the Component IN 1 port
2) Press the Source key to switch to "Component1" mode
5) Select the "Comp Calibration" menu.
6) In "Comp Calibration Off" status, press the "RIGHT ARROW" key to perform Calibration.
8) You can see the change of the "Comp Calibration" status from Failure to Success.
Method of Color Calibration (PC)
1) Apply the VESA XGA Lattice (N0. 21) pattern signal to the PC IN port
2) Press the Source key to switch to "PC" mode
5) Select the "PC Calibration" menu.
6) In "PC Calibration Off" status, press the "RIGHT ARROW" key to perform Calibration.
8) You can see the change of the "PC Calibration" status from Failure to Success.
Method of Color Calibration (HDMI)
1) Apply the 720p Lattice (N0. 6) pattern signal to the HDMI1/DVI IN port
2) Press the Source key to switch to "HDMI1" mode
5) Select the "HDMI Calibration" menu.
6) In "HDMI Calibration Off" status, press the "RIGHT ARROW" key to perform Calibration.
8) You can see the change of the "HDMI Calibration" status from Failure to Success.
FOR MORE DETAILS CHE THE FOLLOWING LINK
www.electro-medical.blogspot.com
google.com/+AjinGopakumar
USE SEARCH TAB FIND MODELS OR USE DROP DOWN MENU
on Jun 30, 2015 | Samsung LA32A450 32 in. HD-Ready LCD TV
Picture adjusts from bright to dark every few seconds and with scene changes. Very annoying
The TV may be in Dynamic Mode - which would cause the screen to change brightness.
To change this you have to go to the picture settings and change it to Normal mode or cinema mode etc.
Dec 14, 2010 | LG Televison & Video
I hvea 42 plasma tv. I have bought a cinema
Please checked Sound System with your remote menu it should be B/G,D/K,I,M which is not proper.
Dec 08, 2009 | LG 42LC2D 42 in. LCD HDTV
Jan 13, 2009 | LG 42PC3D 42 in. Plasma Television
Audio sync issues between my stereo and my new LG 42PG20.
i have samsung home cinema and a lg 42lc2d.
the samsung has 6 speakers but all i can get to work 1 front speaker.
when i trythe speakers on test mode they all work with the test sound
could you please help me
best regards ron mcneill
Dec 25, 2008 | LG 42PG20 42 in. Plasma HDTV
Overscanning
On your remote control there should be a button that lets you change the screen mode, IE. Auto, Panorama, Cinema, Full, Normal, Zoom, etc...
Jan 23, 2008 | JVC AV-27D305 27" TV
Home cinema/Viera link problem
Turn everything off and disconnect from mains.
Wait a few minutes.
Disconnect HDMI cable.
Turn on TV and DVD.
Connect cable.
If this does not work use a cable of different spec.
I had the same problem and now mine works .
Good luck.
T.P.
Oct 06, 2007 | Panasonic VIERA TH-65PV500 65 in. Plasma...
LG 50PK550 50 in. TV Logo
145 people viewed this question
