Question about Panasonic SA-XR30 5.1 Channels Receiver
Have a Panasonic SA-XR30 that emits about 15 beeps as soon as I power it on and then shuts itself off again. The beeps are short and high pitched. Any ideas on what it's problem is?
  • Panasonic Master
  • 6,993 Answers
I think your Panasonic SA-XR30 is having a power problem or there is a bridge on the between the speaker wires. With the receiver turned off and removed from the wall, disconnect every wire, including the speaker wires and connecting cables connected to the receiver. Plug back the receiver into the wall and turn it on again. (I mean without the wires).
Observe if the receiver is going to turn off again, if it still turns off, then its actually having a power problem. It might have worked fine in the past, but that's electronics for you. Power surge, irregular power supply, excess power supply, etc can affect the unit thereby not making it to power on.
This unit has a power supply board in it where power enters from the mains. A capacitor, fuse, diode, etc may have been defective on the power board and maybe that's why its not making the unit turn on. There might also be some disconnection or something, inside the unit which is not making it to power on.
To actually find out what's wrong, you need to disassemble the unit with a screw driver and check what's wrong. You will be needing a meter in order to test the components on the power board, once you detect any bad component, you can make necessary replacement at any electronics accessories store within your vicinity. This is the only way by which you can detect the problem.
Of course, testing the power board with a meter will require someone that has the ability. So it you can't, then you might be needing the help of a repairman or you can call a friend that has the ability to help you out.
I wish you the best of luck.
Posted on Apr 04, 2011
Power shuts off when i turn on switch
There can be two possible reasons for this to occur. The first would be that the pitching machine might need more power than that which is available at home, or the machine might be working for a long time and may have got heated up.
Jun 19, 2014 | Jugs Small Ball Pitching Machine
High pitched noise/beep on emachine e440 laptop
In Windows 7 ,Try the Power Options in Control Panel. Set to High Performance, select Change Plan settings, set Sleep to never, select Advanced Power settings, scroll through the Advanced Power settings, set Sleep and Hibernate to Never and Power Buttons and Lid to Shut down. Always shut down and unplug the Laptop when not in use to prevent damage due to a power surge and a possible Fire hazard IF the battery malfunctions. Not to mention unnecessary wear on the components.
Apr 16, 2013 | eMachines Computers & Internet
After a power problem, tv just emits a high
hello there's a couple of things that could have happened 1. of the capacitor may have blown and 2 the convergance ic have blown which could have taken out the resistors in front of the ic
regards
shaun
Apr 03, 2010 | Sony Grand WEGA KF50XBR800 50" Rear...
Panasonic TX32POL1 high pitched noise
The high pitch sound is comming from a power supply transformer that will resonate (or vibrate) at the operating frequency (12-14KHz).
This is usually affordable to repair -at least worth the estimate.
Oct 14, 2009 | Televison & Video
High pitched noise regardless of power on/off
Hello... I would say that your power supply is going bad. But it does sound like the little muffin fan in the unit is.
May 10, 2009 | Panasonic DMR-E85H DVD Recorder
Panasonic sa-ht700
same bro and its happening when there has no bass
Jul 29, 2008 | Panasonic Home Theater System System
High pitch sqealing noise
This is caused be a bad record switch. As a temporary solution, incert a blank tape, push the record switch, then stop. Repeat about 10 times. This may clean the contacts of the record/Play switch but it will probably need to be replaced.
May 20, 2008 | Panasonic RR-830 Desktop Cassette...
Problem with GE Profile Dishwasher
My delay start switch does not work and the dishwasher beeps periodically throughout the day. Also, I have it set for a 109 minute cycle and after about 20 minutes it says that I only have 35 minutes left in the cycle! Any suggestions?
Mar 04, 2008 | GE 24 in. Profile PDW9280JSS Built-in...
High pitched whine
I have the same problem. Replaced the module and still a continous beep....
Dec 28, 2007 | GE 24 in. Profile PDW9880JSS Built-in...
Panasonic SA-XR30 5.1 Channels Receiver Logo
115 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Michael Kovalik III
Michael Kovalik III
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
