Question about Ovens
Hello, we just bought Gorenje EC2000P2 Pininfarina oven, I connected the special cable myself. When it is plugged in, it greets us with "Gorenje". The heating pad responds to "buttons", but doesn't seem to heat up. Oven and it's display don't work at all, even power "button" . What are we doing wrong? Or is it the oven itself?
  • 537 Answers
SOURCE: Convection/Conventional in same unit SC302ZS
f the oven doesn't heat and the on-off light works, test the appliance controls, motor,
and heating element .
Posted on Nov 15, 2007
  • 213 Answers
SOURCE: GE JRS04BOW3BB Will not turn on.
turn the broil on high by itself wait a couple min. and see if it comes on. if it does the your bake element needs to be replaced or you may just have a burned wire where the bake element plugs in. just remember to turn the breaker off to the oven before trying to pull out the element
Posted on Nov 25, 2007
SOURCE: bottom oven of dacor double oven
I found the lower circuit breaker had been tripped. That didn't fix the problem but upon further inspection whoever had worked on the unit years ago had dropped a screwdriver that had lodged between the oven wall and the rear casing and shorted out the lower heating element. I removed the screwdriver and oven works fine now. I don't think that will solve the cmmclow problem but maybee the curcuit breaker is tripped.
Posted on Mar 12, 2008
  • 492 Answers
SOURCE: My GE Oven heating element and timer clock went
Try unplugging the oven and let sit for 10 min. This will reset the curcuit board and reboot the electronics. You may have to pull out the stove o get to the cord.
Posted on Apr 30, 2009
  • 65 Answers
SOURCE: All the lights, display, etc. work on the oven but no heat
First and foremost check the breaker box. Ovens use 240 volts which is a double breaker in the box. Just to be safe I would click both breakers off and then back on together. If this doesnt work turn off the power and have someone help you pull the oven out and check your plug or connection. You may be dealing with a broken wire in the junction box due to the power outage. If you have a volt meter turn the power on SAFETLY and test if your getting 240 volts. If the connections are good (including the one from the juction box to the stove itself) and you are getting proper votage, unfortunatley you are going to have to get a new control. What happens is with only 120 volts going to the oven everything runs but your elements (they utilize the 240 volts to heat). You can tell time or use the timer but without your full 240 your turkey aint gonna cook. There is 120 volts coming coming from each of those breakers you checked in the garage. Bottom line is the chances of both elements going out at the same time are slim to none and I feel you are probably dealing with a broken wire.
Posted on Jan 23, 2010
Testimonial: "very Helpful, thank you!"
Getting Flashing FC oven locked code. Oven won't work Dooor opens and closes easily
If your oven has the control panel in the door, try this...
Open the top door and in the bottom right you'll find a flat cable that goes from the top door into the unit. It'll be just at the hinge.
Pull up on that cable and push it up into the top door. It will likely move just a little. Whilst holding that cable up into the top door look at the control panel and see if it begins behaving normally.
GE had a design problem with the connector on that ribbon cable that is inside the door with the control panel. There is no lock on the connector to hold the cable into the plug. It comes loose (just a little) and can give "probe light" error, "overtemp error" (on a cool oven), and any and all sorts of other unusual errors. The plug will even appear to be connected properly when only one or two terminals of the cable aren't making good contact.
It is poor design for a sliding card / cable configuration. The fix is to come up with a way of holding the cable into the plug. Since one or more connectors in the cable lose connection, some of the controls will be OK and others won't.
If you can "fix" the problem by wiggling that cable then you can have a repairman come out and rig something to hold the cable into the plug.
I took my double oven apart and used duct tape and it lasted a year. I used velcro and it seemed to work better. If it fails again I'm going to cut a couple of cable ties and glue them to the cable and plug to create a semi-permanent connection.
good luck
Feb 23, 2016 | GE Profile JTP56 Electric Double Oven
Wiring up
  • If it is a single oven attaching a 13amp plug and connecting it to a socket is fine. If it is a double oven it needs to be connected to a dedicated cooker circuit from your fuse board via a cooker control switch with 6mm twin and earth cable.
Apr 02, 2014 | Ovens
Oven locked !
You will need to press and hold the clear or stop button for at least 3 seconds, if it is locked due to a cleaning function you will have to wait for it to cool down until it allows you to open it. You could do a hard reset and flip your circuit breaker for your kitchen off and then back on a moment later and try again.
Nov 21, 2013 | Ovens
Gorenje EI44A1-T34 or EI44A2-T44 Dear Sirs,we have the oven for quite a while,but never used the oven part of this induction oven. And therefor didn't bother too much with the blinking light showing...
I hope you have found already solution for this... Anyway this may help others: press buttons 1 and 2 together and release. Then use jog wheel to adjust time. Wait 5 seconds and you're done. Gorenje manual sucks, no info about oven controls. I managed even to set on oven child lock (key symbol), only way to take it off was to remove fuses from electric board of our house!
Jun 24, 2011 | Ovens
Whats the difference between a hard wire and a plug in for a oven
A "hard wired" oven means the 10 gauge (3 conductor with ground) cable from the main service panel (breaker box) is connected directly to terminals on the oven. A "plug in" oven means there is a wall outlet into which plugs a cable connected to the oven terminals. The plug on the cable would be very similar if not identical to the plug on the cable used on a clothes dryer.
Charlie
Mar 13, 2011 | Ovens
Our GE Advantium oven is Flashing F-3
F3 is the error code for control panel failure. A replacement costs~$200. In reading the literature, some people have had temporary success by depowering the unit, removing the ribbon cable to the control board, and cleaning the connections with a pencil eraser. This has bought some people several months of time, some none.... Once ordered, the part usually arrives in several days, and swapping it out isn't hard, once you get to the card.
Hope this helps, --W/D-- please feel free to rate this solution.
Jul 30, 2009 | GE Ovens
I need a handbook for a gorenje gas hob and fan oven
Hi
You need o call Gorenge and they will send it if they have it.
0845 050 8555 UK
please leave feedback
Feb 11, 2009 | Ovens
Bosch hba34b520
Yes, it is o/k to have a single oven connected to a 13 amp power supply supplied with a 2.5mm cable.
A lot of single ovens already come with a 13 amp plug fitted, so you can plug it straight into a 13 amp socket.
If there is no covenient socket nearby, then you can wire the 2.5mm cable srtaight into the oven terminal block.
I must stress that this only applys to a single oven and not a double one.
Plz rate my solution.
Thanks.
Jan 13, 2009 | Bosch HBL 442 / HBL 446 Electric Single...
Gorenje B3350E
Briefly press the first two buttons simultaneously (the button that says Timer with a picture of a bell and button with a picture of a steaming pot). You should now be able to set the time with the jog dial. It automatically starts the time a few seconds after you release the jog dial.
I have a Kleenmaid TO400 in Australia and it's the same as the Gorenje B3350E. Thankfully I have the manual as this would be impossible to guess
Aug 03, 2008 | Ovens
Ovens Logo
138 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
