Question about Kenmore 25512/ 25513 Progressive Canister Vacuum
I have a kenmore vacuum, Series 116-23613300. four years old. It is emitting a high pitch squeel. I have checked and the hose is not clogged, I have put in a new bag and I have washed the foam filter. Any suggestions?
  • 3 Answers
If the squeal is coming from the canister portion of the machine, then you most likely have a fairly serious motor/fan problem. There are no moving parts on that machine other than the fan/motor assembly in the canister.
A local service center could confirm that. You can try to get a free quote if they offer such a service. Many may charge a fee even for diagnostic work.
If the noise is coming from the power-head, then there are multiple possibilities ranging from bad brushroller bearings to failing power-head motor.
Posted on Apr 04, 2011
High pitched sound when power on
I had a vacuum cleaner that did the same thing. My vacuum had three suction levels. The noise level would decrease as I lowered the level. I also noticed that when I turned the vacuum off the sound didn't stop instantly, it wound down/faded off as the motor slowed down. I found the problem to be the bearings in the main motor. I've been told that the motor that powers the carpet brushes can also make the sound if the motor bearing fails.
Dec 29, 2012 | Kenmore Progressive Bagless Upright with...
Making loud high pitched noise and no suction. Belt seems fine
Sounds like something is clogged/blocking the intake hose. Pull off your bin & see if you can feel/see anything blocking that hose that everything goes thru.
Jul 08, 2011 | Bissell Vacuum - Momentum Cyclonic 1 ea...
When vaccuming with the hose it has a high pitch whistleing when using attachments and does not ****
try taking the hoses off, first. Check and see if their is a clog. Ususally if their is one, its in the unit itself and not the hoses. TO get at the clog, try using a metal cloths hanger. Its the only thing i have found around the house that works at getting at clogs.
Oct 23, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Burning smell from vacuum, but not from the belt
Possibly motor is going bad like that stator wearing out.
Aug 26, 2009 | Vacuums
My Kirby G3 makes a loud, high pitch whistle with the hose
I would say you either have something stuck on the impeller or there is a piece of paper or something stuck inside the hose. its not clogging the hose but when the air passes by it. It is making that noise. If you find nothing you may need a repair. May have a bad bearing in the motor. Actually you can also try inspecting the brush on the head. It removes easily from vacuum and should spin freely and quietly.
May 04, 2009 | Kirby G5 Bagged Upright Vacuum
No suction. filter and hose clear. motor high pitch. don't know how to remove cover to check motor.
something is clogged somewhere start from bottom and foolow suction path all the way through. wht kind of vacuum?
Apr 14, 2009 | Vacuums
Noise
The high pitched noise could be because the vacuum is loosing airflow. does the red light come on on the top? if it does ot emptythe vacuum, replace the cone filter, the secondary filter, and the batting in the top of the machine. also hook the hose to the top of the vacuum to make sure there are no clogs in the hose.
Aug 23, 2008 | Filter Queen Majestic Canister Vacuum
Kenmore Cannister Vacuum Model 26312
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=109396&thid=552260
Kenmore Canister Vacuum Model 26312
Posted by Alecia Rojas on Apr 28, 2008
Kenmore 23612 Progressive PowerMate Canister Vacuum
Vacuum is not sucking. It is just over a year old.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
It sounds like you have a clogged hose or a full bag, or dirty filter. The best way to check your electric hose id to run a marble or steel ball thru the hose and if it goes thru all the way then check the bag and filter, most times it is the vacuum hose. If it id the hose you can try to pull apart the clog from both ends using another central or canister vacuum. If not and the ball stops mid way thru the hose then you can use a broom handle with a round hook on the end so that it does not puncture the hose is any place and the round hook can loosen or break up your clog and then your suction will return, if you poke a hole in the vacuum hose there are repair kits that go on the outside of the hose that will slide over the hose and then you use a heat gun and shrink the hose repair kit down to size therefore plugging the leak. (Hose repair kit). So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.sears.com/shc/s/home_10153_12605
National Customer Relations 1-800-549-4505
Home Services & Repairs 1-800-4-MY-HOME
1-800-469-4663
Parts Orders & Inquires 1-800-366-PART
1-800-366-7278
Thanks, Don – The Vac Man
Go Ahead. Use Us.
Apr 28, 2008 | Kenmore 23612 Progressive PowerMate Bagged...
Kenmore 25512/ 25513 Progressive Canister Vacuum Logo
378 people viewed this question
Top Kenmore Vacuums Experts
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
