Question about McCulloch Garden
My 7-10 doesn't have a spark any suggestions?
  • McCulloch Master
  • 2,239 Answers
Try dissconnecting the earth cut outwire from the ignition unit and try again, this will rule out the wire and the switch, if there is still no spark with a new plug, then it has to be an ignition unit replacement
Posted on Apr 04, 2011
1995 v-10 Dodge turns over but wont start
There are usually three things necessary for your 1995 Nissan Altima (or any car) to start. Air, Spark, & Fuel. So first you check to see that there is gas, second you check the air filter, third you check your spark plugs.
if it doesn't help you i think you should make a diagnostic and you can found some good tools to help you here: chinasinoy.com
Nov 12, 2012 | Dodge Cars & Trucks
I have a 97 s10 just swaped 2.2 motors both ran going in to the shop now it cranks and i have spark and fuel going to the rail but wont start if you spray starting fuild it starts on it then dies
If you have fuel at the rail, and a spark, then your problem is either a clogged fuel rail or clogged injectors. Try cleaning or replacing the fuel rail first, then the injectors if that doesn't work.
Jun 19, 2012 | 1997 Chevrolet S-10 Pickup
Mazda mpv cranks but doesn't start
For car no start problem,click the link below :----http://howtobyme.blogspot.com/2011/10/car-wont-start.html
---------Thanks.
Jan 26, 2012 | 1994 Mazda MPV
I have an older Honda HRA214 lawnmower. The spark plug doesn't spark when the starter cord is pulled. I have replaced the spark plug, still no spark. What do you suggest?
Well, if you have no spark, and you replaced the spark plug, that leaves two basic posibilities. One is a failure of the ignition module and the other is a failure of the spark plug wire. Of the two, the most likely is the failure of the ignition module.
I hope this helps.
Jul 29, 2011 | Honda Garden
Doesn't start has spark @ plug fuel @
try starting meaning pull the rope 6 times and then check the spark plug if its wet clean it or try a new plug, if its dry your not getting fuel in the cylinder which means carb problems. if you have a seringe or something to put some gas into the spark plug hole then install spark plug and try it. if it runs for a couple of seconds then you need to focus on the carb. only put a small amount of fuel in the plug hole if you try it otherwise youll be pulling on the rope for awhile before it will start. hope this helps.
Jul 06, 2011 | Echo CS400 18" Chain Saw
Car runs great for 10 minutes then shuts off and has to set about an hour before restarting and will only spin over yet has spark and fuel pressure
This sounds like a bad control module, run the car until it dies then remove a sparkplug wire from a sparkplug and stick a screwdriver into it and place it near a ground then have someone spin the key as you watch for spark, if theres no spark then i would say its a bad ignition control module. this is common, when it gets hot is dies out, you can even remove it and have it tested at an auto parts store just make sure they test it a few times to get it hot. good day.
Jun 27, 2011 | 1989 Chevrolet Celebrity
My Toro model 20018 won't start. I've changed the plug, air filter and put in fresh gas. Doesn't seem to be getting any spark.
Check if there is spark. Take out the spark plug again and hold against cylinder head with screwdriver. Start motor as usual, see if there is spark on plug when starting. if there is no spark replace ignition module .The next thing is there fuel getting to engine. My guess is that you have a plugged carb. jet. Clean out and reassemble. Be careful not to lose the small parts. Good luck
Jun 10, 2011 | Toro Personal Pace CARB Walk Power Mower
My 1991 Honda Accord will turn over but will not start battery light flashes on but doesn t stay on. It has been suggested that it might be the alternator and the distributor. Is this right?
is it turning over normally or slower,have u got a spark,fuel ,if turing slow poss battery/poor connection in the earth,if turning ok check spark if none then check distirbutor,if ok check fuel.
Mar 04, 2009 | 1991 Honda Accord
Garden Logo
29 people viewed this question
Top McCulloch Garden Experts
Jim Parker
Jim Parker
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
