Question about HEWLETT-PACKARD Hewlett Packard 459566-001 - HP Pavilion dv9500, dv9700, dv9800, dv9900 Series Full-Featured (FF) Laptop Motherb... Motherboard
I had graphics problem,after resolved by an exprt the power problem starts within a day. Now it is not starting. Do i have to change motherboard?
  • David Petry Apr 04, 2011
    What was the problem with the graphics and what did they do to repair? Will system start at all ie; in "safe mode"? Are you getting beep codes?
  • rohan azam Apr 14, 2011
    can i remove my graphics card from my laptop's motherboard? it seems like it is attached with motherboard with some kind of red thing.
  • 2,427 Answers
Not yet,,
remove the graphics card, remove the pc memory remove the battery from the board, press and hold the power button for 12 seconds release put back, battery and memory and graphics card turn on, load default values and contine, should be fine.
Posted on Apr 04, 2011
  • Rishi Roshan Ali Apr 16, 2011
    yeah you can if its jacked in, if itrs hard wired (soldered in) you cant you will need a new board.
Motherboard problem
I would suggest buying a cheap Graphics Card, You will have more control over the graphics output and the system memory will increase. By using the onboard graphics you are eating into the System RAM and if you have only the minimum system Ram then your system will be slow.
Jan 21, 2012 | ASUS M2N68-AM SE2 Motherboard
I have Intel DG33FB motherboard, 2gb DDR2 RAM, Nvidia 8600GT graphics card.In few days my computer start with something Different Pixel color.After 5 to 10 miniuts letter my screen color blink with yellow...
The problem can be possible with RAM's print and with graphic chip so when you change the ram but problem will be remain same then you should change your graphic card. I hope you will fix your issue easily.
Thanks
Sep 23, 2011 | Intel D865GBF Motherboard
CAN NOT PLAY GAMES
I would start by upgrading the video card, because it is most likely the problem. Also try lowering the quality settings within the games themselves to increase performance. RAM also plays a factor in games, these days 2GB of RAM and up is ideal for gaming.
May 06, 2009 | Intel Motherboard
Graphic Card Problem
there could be many things besides the graphics card. To start however, make sure your laptop recognizes your card and its drivers installed. Make sure your card is compatible with your motherboard. what is the model of your graphics card?
Dec 12, 2008 | Intel D101GGC Motherboard
After 15 -20 min my monitor goes blank
This could indicate a problem with the graphics card. Take the card out and clean it, then clean the slot that it fits into. (I normally use a small dry paintbrush).
Replace the card, making sure that you push it down gently but firmly and ensure that the plastic clip has gone back correctly that hold the card in place. Rescrew the card back to the casing correctly and reboot.
Hopefully this will resolve your problem. If it does not, to determine whether or not your graphics card is faulty. Change the monitor lead over to the onboard graphics port instead of the agp/pci port and reboot. If the monitor works properly with no problems, then you have a bad graphics card.
I hope this helps.
Nov 13, 2008 | Intel Motherboard
Power drops aprox 1 minute after start
Good day!
It's the power supply, usually the fan of power supply run once it start normally, Replace the power supply. And try to turn on the unit.
Feel also some part of the mother board if they are hot like the heat sink the power supply casing do it when the power is off.
Thanks.
Nov 06, 2008 | Foxconn (945G7MA-8KS2) Motherboard
Orange Light permanently on motherboard. PC won't start
If all you did was change hard drive
I suspect the hard drive has been installed wrong
Ensure blue or red stripe goes to the number 1 pin on M/board and the stripe goes next to the 4 pin power supply on hard drive
Sep 23, 2008 | Computers & Internet
My Dell Inspiron 5160 won t turn on
Hello viceaddict6,
That model is known for this problem and Dell is aware of it. I believe they will replace your motherboard and AC adapter free of charge. Tell them your problem with the lights, and that motherboard is most likely not getting the powere it needs.
Below is the information to contact them; they are open 24/7. The express code they are referring to is a sticker that is taped to the laptop. My personal experience with them is good, they usually have someone drive out or come by within the same day or next day and replace the hardware with a smile.
Technical Support
(Please have your Express Service Code ready when calling) 1-800-624-9896
Regards,
Chester
Jan 12, 2008 | Dell (0N5370) for Inspiron 5160 (64MB) (64...
Power On trouble with Computer
If don't you have any beeps check maybe the power button stack.
If the power button pressed for four seconds then the computer normaly shut down.
Jan 11, 2008 | Abit KV7-V Motherboard
HEWLETT-PACKARD Hewlett Packard 459566-001 - HP Pavilion dv9500, dv9700, dv9800, dv9900 Series Full-Featured (FF) Laptop Motherb... Motherboard Logo
196 people viewed this question
Top HEWLETT-PACKARD Computers & Internet Experts
Bilal Ahmed Qureshi
Michael Vincent Cruz
Are you a HEWLETT-PACKARD Computer and Internet Expert? Answer questions, earn points and help others
