Question about Dell Inspiron 1420 Motherboard - KN548
Hi , I am facing the issue of display i think my mother board having Nvedia card has been damaged . Can you please let me know how much i need to pay .
  • David Petry Apr 04, 2011
    What kind of damage? Did you drop it, or did it get wet? Will system start up at all?. The mother board for you Dell is around 200.00
  • Dell Master
  • 27,725 Answers
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electic extensions or just replace them they are probably faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error or it could be a problem with your graphics card
Click start control panel administrive tools computer management device manager scroll to display adapters + to expand you might see a yellow question mark ? or exclamation mark ! red x right click select reinstall drivers http://majorgeeks.com/SiS_UniVGA5_Graphics_Driver_For_Vista_d5611.html
http://majorgeeks.com/SiS_UniVGA5_Graphics_Driver_For_Windows_7_d6264.html
http://majorgeeks.com/SiS_UniVGA3_Graphics_Driver_d4401.html
hope this helps
Posted on Apr 04, 2011
I have 945gcr mother board i bough one graphice card for my pc but its not working i have faceing some issue with my graphic card (nvidia 9500 gt) the probleme is whene i was insert card in to board then...
Hi
Try and do the following:
Have a look at the back of your graphics card there might be a 6 pin plug it provides extra power to the graphics card which will need to be plugged in before your PC will boot. If not try and get hold of another graphics card and insert that into your PC. Switch on the PC and see if you get a display. If the PC still does not want to boot up then the pci-express slot on your motherboard might be faulty. If it boots up then your graphics card might be faulty.
Mar 08, 2011 | Computers & Internet
All supply are ok on mother board but dont display
check your memory and other PCI cards... check it one by one.. take it all out and try it one bye one..
i think there's a pci or a memory damage..
Oct 22, 2010 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Mercury pi845g mother board restarts again and
The problem you are facing is generally caused by Defective rams please remove the rams clean the copper contacts by a soft cloth and then reseat them.
Feb 10, 2010 | ASUS P5LD2-VM Motherboard
Unable to boot up
The problem is of the display side so if possible connect the pci
display card or can repaire the mother board, If not then only solution is to change the mother board.
Thanks
Sep 08, 2008 | ASUS P5B-E Motherboard
Sound card
This this the guide website for HP computers contains the instructions needed to install a sound card
and also why I wanted to know the HP model of SKU model of the computer....
Just keep me posted if you still have problems.
Aug 20, 2008 | Intel Premier Resources 4-Channel 32-Bit...
Toshiba A205-S4707 Display issues
This happens when the Mother board, which is the place were all the cables meet inside the computer might not be working correctly. This process needs to be handle by a professional to change the Mother Board.
Thank You!
Jul 23, 2008 | Toshiba Satellite A205-S4617 Notebook
Intel D101GGC Motherboard PCI Express compatibility issues........
i'm using NVIDIA GEFORCE 8600 GT on my d101ggc board and its working fine
Jun 30, 2008 | Intel D101GGC Motherboard
No display when i turn on pc
so..let me see..you have 2 mainboards,two video cards.one preocessor and rammsso you have quite some possibilities.
fisrt of all I have to say that just clearing the bios is not a solution..would be better to update it,by downlaoding it from the manuufacturers site and after you made a bootable cd than under dos mode re write the bios..
however you cant see anything without a propper signal with new motherboard.
take the new mother board..
so..chech the rams.if you have more ramm dimms let only one in the board but be sure is the one near the proccesor slot and check it to be well inserted.
-put the video cards first the 8500 one,see what it happends.like an observation:if the hdd is damaged the computer runs showing you the dos mode/you are able to reach the bios
processor damaged-computer can run/blue screen with some infos/it is note  a rule that you can reach the bios
ramms distroyed or put wrong..computer starts/dos mode/able to work in bios
video card damaged -NO SIGNAL AT ALL
moather card damaged-No signal at all.
so think and pay attebtion to the details of the errors.
You can make different tipes if combinations and by elimination youll discover the faulty component.
from now I can only presume is the new mother board
good luck .its a booring work but is nothing you can do more
bye bye
Feb 06, 2008 | Abit IN9 32X-MAX Motherboard
Dell Inspiron 1420 Motherboard - KN548 Logo
63 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
