Question about PayPal Accounts
Ordered a left handed golfers glove (which is a right glove and got the right handed glove
    Scholar:
  • 85 Answers
Most companies allow you to send back the defective (or wrong) ordered item, and they'll replace it with the correct one. But, most of the time you'll have to shoulder the shipping expenses. Contact your supplier and ask the process in replacing your item.
Posted on Apr 04, 2011
Where is the . location of dianostic plug.
t should be in the center dash right under the stereo but if u cant locate it their its going to be on the passenger side under the dash its the one not connected to anything. its probably blue and it has a lot of pins since its obd2 hope u find it!
Sep 04, 2014 | 1999 Honda Accord
Where is thelocation of fuse box
Hi Lorrainesd
there are 4 fuse boxes on this car, 2 in the trunk/boot as you look at the car from the rear the fuse box in behind a panel on the right hand side, the other fues box is in the glove box open glove box look up and you should see some largish screws turn them anti clockwise and the fuse box will drop down, the other one is under the hood/bonnet, this will depend on if its a left or right hand drive, it will be in a box either on the left or the right side of the car under hood/bonnet
hope that helps
Apr 25, 2014 | 2005 BMW 740i
A BOX OF 7 GLAVES CONTAIN TWO LEFT-HANDED GLOVES AND FIVE RIGHT-HANDED GLOVES
First one, chance is 5/7
Second one, 4/6
So odds of 2 RH in succession is 5/7 x 4/6 = 20/42 or 10/21
Mar 22, 2013 | Prentice Hall Basic Business Statistics...
I get skin irritations from frequently washing my hand before I wear gloves, how can I treat it?
Glove use magnifies the irritations issue because you wash your hands frequently. In order to treat it you should make sure your hands are clean and dry before your wear the glove, and when you are not wearing gloves you should use a hand cream.
Feb 06, 2013 | Clothing Accessories
Fuse blown on cigarette lighter, what number fuse do I need ?
Fuse 47 a 15amp fuse is for the cigarette lighter..it's located behind the glove box which you can drop down for easy access.
The "glove box" is the little box that opens on the left side, under the instrument gauges near the left door.......Not the big glove box on the right hand side.
Jun 01, 2011 | 2000 Ford Focus
How do you change to a left handed golfer on the ps3 move for tiger woods PGA TOUR11
The game does not allow you to change this option, this is chosen in the settings when you first create a golfer, but unable to change later.
Apr 03, 2011 | Sony Video Game Consoles & Games
I changed the bettery in my 2003 Honda Odyssey and now the radio won't play, it asks for a reset code. How do I find this code to reset it to play ?
Inside the glove compartment on the left hand side there should be a series of numbers under 6. You punch in the order on your pre set radio station numbers and it should come right on! Good Luck!
Jan 27, 2011 | 2003 Honda Odyssey
How does glove box come off to replace air cabin filter ?
First, take a good look at what you’re doing.
Look on the right side of open glove box and locate a plastic lever. You will see grooves on the end connected to the glove box. The grooved area is the spot to place the thumb in order to press this lever off the glove box when it comes time to do that.
Look up under the glove box. You will see two brass colored screws one on each side of the bottom of the glove box. These screws go up through two square plastic hinges that are attached to the glove box and into the the dash frame.
Okay, with the glove box closed remove the two brass colored screws, and put them aside so you won’t lose them..
Open the glove box and hold the glove box with your left hand and press on the plastic lever (grooved area) located on the right side of the glove box. This lever (the lever already mentioned above) is slotted and will pop off the glove box.
Put the glove box carefully aside.
Look straight in behind the glove box. You will see a rectangular black plastic cover approximately 1.5 inches wide by 8 inches long. On the right and left side are arrows pointing in. Press the arrows and pull out on the cover. This will slide out the tray that holds the filter. Remove old filter and insert the new one, flow arrows pointing down.
Retrieve glove box, hold in place, and attach plastic plastic lever to the right side of the glove box. The reverse of removal.
Next, the two plastic hinges located on the bottom of the glove box fit underneath the dash frame.
While holding the glove box in place (the glove box latch may hold glove box in place while installing screws) re-install the two screws through the plastic hinges into the frame and tighten.
Hope this helps you.
Oct 30, 2009 | 2004 Honda Accord
Change cabin air filter in toyota camry
The answer is in your owner's manual. Just go to the parts dept of your dealer or to an auto parts store and get the filter. Next, empty out the gloove box. DIsconnect the damper (it is on the right side of the glove box that prevents the glove box from falling open too fast) Grip the top front of the glove box with your left hand and the top rear with your right hand and then push your left hand toward you and your right hand toward the front of the car, like you are trying to make the top of the glove box wider. While you are doing this, pull the glove box toward you so that the glove box is hanging down, (if it was full, it would have spilled the contents on the floor mat). Then the cabin air filter is toward the front of the car, just squeeze the two tabs on the left and right side and pull straight out towards you. You have removed the cover for the cabin air filter. Now, slide the filter out and put the new one in. Reassemble in the opposite that you disassembled.
Again, see your owner's manual, it tells you how to do it and saves tons of $$. This only takes 5 minutes or less.
Sep 19, 2009 | 2000 Toyota Camry
Can a left handed golfer
Yes, you can.
Source (in a customer review)
Enjoy :)
Apr 14, 2009 | Mad Catz Real World Golf Bundle for...
PayPal Accounts Logo
46 people viewed this question
Top PayPal Computers & Internet Experts
brian soufane
Mike
Are you a PayPal Computer and Internet Expert? Answer questions, earn points and help others
