Question about Xerox 6180MFP/D Printer
Xerox 6180 MFP makes copys that are blurry and have yellow streaks. Prints fine, what could cause this. the glass is clean.
  • 85 Answers
I think attracting scanne(copier) be cleaned is probably dusty inside
Posted on Apr 04, 2011
  • Techpub Apr 04, 2011
    Sorry, that did no good. Interior of scanner is clean. all bulbs and mirrors look good
Xerox 6505 printer
lunch the cleaning function from your device utilities.
Apr 06, 2016 | Xerox WORKCENTER 6505N COLOR LASER MFP,...
Laserjet pro black vertical lines using adf
Do regular prints look ok? If so, then try copying something from the flatbed glass. If that copy has no line then you have something on the glass where the paper passes over when fed through the adf, clean the glass well, you may need to use some rubbing alcohol because often fine bits of adhesive from things like sticky notes will cause the lines but are not obvious to the eye when you inspect the glass.
Jul 31, 2014 | HP LaserJet Pro 400 Color MFP M475DN...
Phaser 6180 streaking
If it's just one colour, it's usually THAT colour Toner cartridge that's the cause .
Jun 23, 2014 | Xerox Phaser 6180N Laser Printer
Connect 6180 MFP scanner to Toshiba laptop
Press the document to be scanned on the Platen glass. Press the Scan button, an Utility will appear. Select required size and resolution. Upon scanning document, save it in compatible format and attach it to email.
Jan 08, 2014 | Xerox Phaser 6180 MFP/N Letter-Size Color...
Do you have any instructions on how to clean a Xerox Workcentre 4150. It is leaving a dark streak down the right hand side of the page on everything it prints, not just copies.
First the to do is a "stop test." You will induce a jam before the paper reaches the fuser (which the the hot thing near the exit). The PN for the fuser is 002N02557.
If the defect exists already then the drum or transfer roller or laser may be causing it.
There are very few things that you could clean except the glass on top or the pick rollers.
Whit
Item, Inc.
Aug 23, 2010 | Xerox WorkCentre 4150 Black and White...
Horizontal streak
Clean the scanner strip glass. This is the small strip of glass that is just to the left of the large main glass. This is the only cause for black line (s) when copying using the ADF(top feed). If prints or copies fine from the glass then it is this strip glass needing to be cleaned.
May 04, 2010 | Ricoh Aficio 450 Copier
Xerox 6180 MFP N error 016-782 Windows 7 x64
did you get a solution to this problem. i have the exact same situation.
Feb 16, 2010 | Xerox Phaser 6180N Laser Printer
Blurry Scanning/Copying
Are you scanning both black and white and color the same way? The ADF (automatic document feeder) uses a different scanning area than when you place the document on the scanning glass. If you open the scanner cover, look to the left of the main scanner glass to the narrow strip used for the ADF. Make sure this narrow strip is clean -- no ink or white-out or scratches. This can make your copies look dirty or smudged.
Jul 26, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Xerox 6180MFP/D Printer Logo
260 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
