Question about Soleus Heating & Cooling
The air conditioner does not turn off when the tank is full and it causes the water to leak out of the unit and it soaks the floor.
    Sergeant:
    Champion:
  • 277 Answers
Is it a split unit
Posted on Apr 04, 2011
Whers does water evacuate from portable ac unit
there is a holding tank in the bottom of the unit, on the front right by the floor is a rubber cap that plugs this tank. water evaporates from there, if the tank gets too full, the power button will flash red and the unit will not turn on. put pan under, pull plug and drain if this happens. if it doesnt happen, don't worry about exhausting the water as its not a problem.
Jun 10, 2014 | Maytag Portable Air Conditioner M6P09S2A
Water leaks under portable air con unit
Look for a crack on the water tank or a dried up gasket on the tank. Loose hose clamps can allow a leak as well.
Jan 04, 2014 | Heating & Cooling
Water leaking in the inside of home.
Air conditioners take the moisture out of the air. When the air passes through the coils on the evaporator, they are cold. This causes the air to condense and water to form on the coils. It then drips off into a pan. When the pan is full if it is not drained, you will have an overflow and things get wet. How much water the unit collects depends on how much humidity is in the air, how much air you are moving through the coils and the temp of the coils.
Jul 22, 2013 | Royal Sovereign White 1200 BTU/12,500...
Unit is leaking water from somewhere
Upper drip pan drains clogged, water overflowing onto the floor.
Remove the rear cover of the unit and clean it thoroughly wit a vacuum. Let the unit fully defrost. Use a can of Air duster (for pc's) with the little hose on to clear the drain holes in the upper drip tray. Clean dirty evaporator fins with windex and toothbrush, flush with water. Excess condensate should now drain into the bottom tank instead of overflowing ontot he ground. Be sure to drain the bottom tank thoroughly. With the unit cleaned it should now vent condensate out the warm air duct rather than letting it build up in the unit.
Jul 06, 2012 | Windchaser PAC9 Air Conditioner
We've had two of thee units for a couple weeks now. Then suddenly they started leaking a LOT of water. How do we fix this problem asap?!
If you haven't been draining the water collection tanks regularly, that could be the problem. With that said, the units should shut down automatically, when the tanks are full. If they are not doing that, the water tank full sensors are faulty. The drain plug is on the rear of the unit, just above floor level. To drain it, place a low sided pan or bowl capable of holding 1 quart water, under the drain plug. Unscrew the plug and allow it to drain in the pan. Or disconnect the unit and roll it to a floor drain or outdoors and drain it/them.
In addition, check the exhaust hose(s) for obstruction r drooping to much. Either will trap moisture that should be exhausting out the window.
Hope this helped you to troubleshoot and solve the problem. Thanks for choosing FixYa.
Aug 19, 2011 | DeLonghi A120E Air Conditioner
My unit is leaking tons of water only when a/c is on for a while. It leaks out of base and I have to drain tank every day. Help!!!
It is supposed to "leak" water into it's reservoir and it needs to be dumped when it gets full. That water is the humidity that the a/c is pulling form the air inside your home. As long as it's going into the reservoir and not leaking onto your floor then it is working properly.
Jun 24, 2011 | Windchaser PACR10 Portable Air Conditioner
LX-140 SOLEUS A/C DUMPED WATER ALL OVER MY WOODEN FLOOR........THE TANK ALWAYS GETS EMPTIED AND CONVINCED THAT THE WATER IS COMING FROM THE BOTTOM OF THE UNIT, I TURNED IT OVER AND WATER CAME POURING OUT...
I would recommend that you manually fill the tank so you can watch it and see when it is completly full. If tank full sensor does not work then I would replace it. I think it is probably bad as it should not only tell you the tank is full it should also shut it off. Thank you.
Apr 29, 2011 | Soleus KY-34 Portable Air Conditioner
Unit is leaking all over floor
Can you connect a pipe from the drain pan to a drain? This would get rid of the moisture within the room instead of just recycling it.
Jul 20, 2010 | Haier HPM09XC5 Portable Air Conditioner
MODEL CPRD12HX7-Q THE UNIT WILL NOT TURN ON AND...
I have the same model and if you have been running the dehumidifier the internal water tank will fill with condensate water. You will need to unplug the black plug (in back of unit) to release the pints of water it has accumulated in the tank. Be sure to have a pan under the plug as it will drain immediately. Do not tip the portable unit if you need to put in a shower stall to drain, as water will leak out of the internal water tank into your unit. Hope this helps.
May 21, 2010 | Haier CPRD12XH7 Air Conditioner
Air conditioner is leaking but lights not blinking
Make sure the drainage port is closed as per the instructions. If you continue to have leakage you may have a leak in the tank.
Jun 15, 2007 | Sharp CV-P09FX Air Conditioner
Heating & Cooling Logo
427 people viewed this question
Top Soleus Heating & Cooling Experts
Coss
Dennis Boxerman
Harjeet Singh
Are you a Soleus Heating and Cooling Expert? Answer questions, earn points and help others
