Question about Kenmore Elite HE4 Electric Dryer
I need to remove controle panal back modle #68932790
  • Kenmore Master
  • 8,220 Answers
He dryer dis-assembly video:
More Here
Posted on Apr 04, 2011
1999 Chevrolet Silverado power windows, How do you remove drivers side door panel
not really sure on that one but on most first you will need to remove screw around handle that opens the door that needs to be removed. also should be screws underneth handle that pulls door shut that you will have to remove and in some cases . check around edge of door panal for more screws and if found remove them also. once all screws are removed you will need to pry on door panal slightly because there are clips behind panal holding it on. in alot of cases the clips break when removing panal but dont worry the can be bought at your local auto parts store and are very easy to replace. I usually use something flat like a small stiff putty knife to help pry door panal lose. this helps insure that you dont break of crack the panal. after all clips are off simply unplug wire connections and door handle linkage and your done. .....hope this helps and good luck
Aug 13, 2012 | 1999 Chevrolet Silverado 1500
My tv is not turning on. we just moved from one house to another did the move disturb it
you need to take the front panal off to look and see if all three sockets on ctr tubes are seated all the way. the front panal is the one with the power button,vol and ch buttons and aud/vid hook up. first remove the shiny screws from the back on the sides of tv where speaker grils are. remove the speaker grills. then you have four black screws two on each side of panal and two shiney ones on top of panal. remove all six then remove panal careful not to pull too hard on wires. then making sure tv is unpluged, reach in and under the three tube assembelys, push up under the circut boards right center of where the scoket connects to the tube and make sure they are seated all the way. doesnt take much pressure to push on them so dont kill them. also be careful not to do it off center of the board or board or worse the tube will break. if all is well there, you will have to remove more panals and look a little farther for somthing lose or broken. good luck.
Oct 23, 2010 | Toshiba TZ43V61 43" Rear Projection...
My tub on my dyer has quit working-where is the belt located and it is hard to change??
first you nead to unplug the dryer.next you nead to remove the lint filter and remove the two screws that are under it.now grab the top on both sides and pull it forward and up.roll top back and let it lay on back wall.look between the drum and the frount panal and remove the two 5/16 screws one on both sides.next pull the frount panal forward 6"and pull up on the frount panal.rotate the frount panal and let it rest on the side of the dryer.you do not nead to remove the wires from the door switch.next look under dryer drum and you should see the old belt.remove the belt.next place the new belt over top of drum,next with your left hand grab the frount top of the drum and lift it about 2"and with your right hand grab the drum belt and feed it under the drum.2/3 the way back.next lay down in frount of dryer and look under the drum.you will see that the idler assembly neads to be reinastaled in the slot in frount of motor.with your right hand hold the idler assembly and with your left hand you nead to feed the drum belt thrugh the idler assembly and over the moter pully.next you nead to replace the frount panal to the two clips one on each side at the bottom.next with your left hand push back on the drum and with your right hand push the frount panal forward and set the drum with the frount panal and replace the two 5/16 screws.next lower the top panal and replace the two screws and the lint filter.plug the dryer in and test unit out.
Jan 21, 2010 | Whirlpool LER4634J Electric Dryer
Leak when in use I need to remove caseing
on the back of the control panal you nead to remove the two screws one on each side,next you nead to pull the panal forward and flip it up.unplug the door switch,next remove the two s-clips that hold the body on.pull the body forward and remove the body.next look down and you will see the water pump.if there is water under the pump than you have a bad seal in the water pump.you nead to replace the pump.you may nead a pan to catch the water that is still in the washer when you remove the hoses from the water pump.remove the two clips from the water pump and replace the pump.
Jan 19, 2010 | Whirlpool LSB6200KQ Top Load Washer
During spin cycle the washer allows water to enter the machine. If I shut the water during this cycle it spins out fine but when the cycle reaches the off position it doesn't really shut off. Sounds like...
open the door on the washer,in the middle rear just above the tub you will see the shute were the water comes in to the washer,make sure it is connected to the back panal,if is not than you will nead to remove the washer top door and cover assemble,there is a panal between the dryer and the washer,at the top of the panal on each side you will see a screw,remove them and remove the panal,at the back of the cover on each side you will see a clip with a 5/16 screw in it,remove the screws and slide the cover forward about 1 ",next lift the frount of the cover and on the right side you will see the door switch conneter,unhook the conneter and remove the cover,next you can see the water inlet shute,if is broken than replace it and hook it up to the back panal,next replace cover and panal and run a test run.
Jan 04, 2010 | Whirlpool LTE5243D Top Load Stacked...
I want to put a new pump in my kenmore washer, but I can,t get the back off. Can I change it from the bottom by tipping the washer on it;s side?
look on the corners of the control panal you should see two scres on the corners, front r back
depends on the model... if you dont see any
you may need to pell the end caps off the control panal, dont wory they will snap off and on
remove those screws, the roll the control panel up and over the back
when thats off you will see two snap clips on either side of the cabinet and a wire plug ususally with a tan and white wire but dont quote me
pull those two clips off remember how they sat
take a picture if need be.....
once3 you have the clips off and the wire plug pull the whole cabinbet forward,
you will now have acess to the pump unit
Oct 24, 2009 | Kenmore 22422 Top Load Washer
How do I properly remove the top control panel in order to remove the front cover of the machine?
there should be two screws holding the top down on the back wall
remove those and slide the top backwards
you will now see how to remove the control panal
Oct 03, 2009 | Frigidaire ATF6000ES Front Load Washer
I'm getting an F3 fault code on my Maytag Mod. # CWG3600AAB. Everything points to replace the temperature sensor probe. With electrical off I have the oven pulled out but the wiring\harnesss of the temp...
Your temperature sensor has failed. You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here. We're happy to help you with free advice and we'd appreciate your thoughtful rating of our answer.
Sep 08, 2009 | Microwave Ovens
Kenmore Elite HE4 Electric Dryer Logo
112 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
