Haier hw-c1460tveme-u error 7 smelt like burning rubber the machine was on spin cycle when it stopped with the error the 7 way plug has been removed then replaced the machine will fill and drain but nothing else
  • Washing Mach... Master
  • 1,525 Answers
Hello check the belt at the back it might have come off or snaped got trapped and started to burn. if ok then the motor could have burn't out or circuit board burn hope it helps
regards
shaun
Posted on Apr 04, 2011
It is not draining the water out it is a haier hw-c1460tveme-0
Hi, you can drain the water by disconnecting the grey empty hose putting the end in a bucket and lowering the pipe flat and below the tub level, the water will empty under gravity into the bucket.
When its empty CLICK HERE to follow the instructions ho how to check and empty the filter of any debris, then try the machine again, is it still does not empty then suspect pump failure.
hope this helps.
Feb 12, 2011 | Washing Machines
My Haier HW-C1460TVE-U washing m/c keeps giving (CLrF) ERROR Code
Anyway, my machine shows an error code "clrf". I just spoke to someone at Comet, and apparently this means there is too much foam in the machine. The machine will then refill with water and try to rinse it out, but if after that the machine still has too much foam in, then it will stop the cycle. Hence why my clothes are still wet (although I'd not realised they weren't rinsed properly either!).
I have not been using excessive amounts of washing powder, and usually use powder tablets or the liquid tablet sort, so they are a set amount and I don't do anything daft like stick 6 tablets in! I find it ridiculous that this would cause a problem with the washing machine, as I've used them perfectly fine with other washing machines.
Anyway, the advice from Comet was to keep trying different washing powders until i find one that foams less.
Jan 07, 2010 | Haier Washing Machines
I have a HW-C1460TVEME-U haier washing machine,it sounds af if the bearings are going at the back is there anything i can do
It is a task that you might not want to tackle. You might be better off to have it serviced to keep your sanity.
Oct 29, 2009 | Washing Machines
HAIER HW-C1460TVEME-U
Err1 : Door not properly shut
Err2 : Drainage error (clean filter check hose
Err3 : temperature sensor short circuit
Err4 : Heater error
Err5 : water fails to meet specified level within 8 mins check tap, water pressure
Err6 : motor error
Err7 : motor error
Err8 : water exceeds protective level check circuit
End : end of wash cycle
Unb : after the last rinsing cycle finishes spinning fails completelt due to unbalance of the laundry
only reason I know is i looked through the manual after getting it myself could be something to do with running a bath while washer on or something perhaps not enough water getting in if powder channel blocked
Sep 12, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Error code 7
The error code 7 is in fact a motor error.
The motor that drives the spin cycle has become faulty. The only solution now is to get an engineer in to fix it or get it sent away to get repaired.
Sep 08, 2008 | Haier XQG50-11 Front Load Washer / Dryer
Washing Machine Stopped Working
Hi Beth, sounds like you broke a belt. You can verify this by pulling the washer away from the wall and tipping it back to look underneith. Should have two belts, pump and drive. The part numbers are 211124 pump and 211125 drive. Catriver, post back.
Aug 02, 2006 | Maytag Dependable Care LAT9706
Washing Machines Logo
169 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
