Question about SanDisk 2GB microSD Memory Card
When i insert sandisk 2gb SD memory card(new one) to my phone,it is displaying that the memory card is password protected..how to unlock it?
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 332 Answers
Are you sure its asking for a password or is it saying the card is locked. I think the card is locked, look at the card closely either on the front or the back of it there will be a small black square that can be moved either up or down or left or right. Slide that square over to unlock the disk and you should be able to use it now.
I hope this helps you out and if it does please leave me some positive feedback.
Posted on Apr 04, 2011
I forget password of sandisk 2gb micro sd memory card
you can unlock your sd card by formatting*.
formatting memory card will delete all datas
formatting method*
use a softtwaer phone for formatting.. (example nokia 6120c, 5800etc )
insert your sd card into the softwaer phone.. select SETTINGS > DATA MGR > MEMORY > OPTIONS > FORMAT MEMORY CARD
Oct 15, 2011 | SanDisk 2GB microSD Memory Card
Tip
Unlocking SD Memory Card of Nokia 2690
Nokia 2690 is a mobile phone made by Nokia Corporation. Nokia 2690 have 25 MB internal memory, microSD memory card slot with hot swapable. Many user faces problem in unlocking the password of SD memory card. As the SD memory card contains valuable data like songs,images, files, etc. To protect the SD memory card from the unauthorize use, its is protected by secure password or lock code. Some time the password gets forgotten or it gets blocked technically resulting in faliure to unlock the SD memory card. To unlock the SD memory card password you need the utility called FE Explorer. After installing the FE Explorer in the phone, insert the card in to the phone but do not access it. After running the FE Explorer open the path C:system. There is a file called mmcstore. Rename the mmcstore file to mmcstore.txt. Transfer the mmcstore.txt to the pc or laptop and open it in notepad. After opening the file there is a password to unlock the SD memory card of Nokia 2690. Using FE Explorer we can remove the password of other micro SD memory card like Kingston, SanDisk, Verbatim.
Please download the software from the link provided below :
http://fexplorer.en.softonic.com/download/25347
Also visit the help link provided below :
http://www.mobiclue.com/recover-memory-card-password-from.html
on Jun 14, 2011 | SanDisk 2GB microSD Memory Card
Hi i have my memory card password forget
you can unlock your 2gb sd card..
1. Insert the sd card into a software phone. (eg. Nokia 6120c, 5800, 5233 etc..)
2. Select settings > data mgr > memory > options > format memory card..
Note- formating memory card will delete all datas in your sd card
Sep 24, 2011 | SanDisk 2GB microSD Memory Card
Sir i have a problem. i have a memory card which protected with password. but i have forget exact password. plz sir tell me how can i unlock my 2GB memory card.
SD and micro SD cards have a small slide switch on the edge of the card to protect the data stored on the card. To unlock the write protection move the slide switch to the write position.
Jun 13, 2011 | SanDisk 2GB microSD Memory Card
I have 2gb sandisk memory card i dnt giving password.but appear password plz giving common password.
Hello Ayca,
To Unlock the SanDisk 2GB microSD Memory Card password you will require the Nokia 2690 or Nokia 2700 Classic phone.
Download FE Explorer from the link http://fexplorer.en.softonic.com/download/25347
Insert card into your phone but don't access it through phone.
Run FExplorer and Open the path C:\system.
You will find a file called mmcstore ,rename the file mmcstore.txt
Copy that file(mmcstore.txt) to your pc and open that file in notepad.
You will find your password in that file to unlock the memory card password.
Also visit :
Jun 06, 2011 | SanDisk 2GB microSD Memory Card
When i open my digital camera with the card inserted (4GB micro sd HC) then, it is displayed as WRITE PROTECT and cannot proceed further. Please provide solutions.pleaseee
SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
If that doesn't work, try another card.
Oct 24, 2010 | SanDisk 2GB microSD Memory Card
Micro sd memory card lock password forgotten
Having 2 ways: 1. Insert the Card into any Nokia s60 OS mobiles having Microsd card, Nokia n95 Like then check this to unlock
http://www.mobiletipstricks.com/how-to-unlock-the-password-protected-memory-card-of-your-mobile-phone/
or Simply Put in Motorola Razar Mobile handset and format to have a fresh memory card
May 06, 2010 | Nokia 3110 Cellular Phone
My computer does not recognize my SD 2GB SD Flash Card which I insert into my camera and take pictures. I have a slot on my computer for SD cards. Can I just put the card in the slot and access the...
yes you can directly use the SD card slot, make sure you unlock the write protection before inserting it into the slot if you wish to modify or copy the contents from or to the card.
Jun 24, 2009 | SanDisk 2GB microSD Memory Card
Open a password..
I think you have a SDHC sd card have a look at the card and see if it says 2gb SDHC if it does then you need a new SD card if it doesnt have SDHC then it will be a fault with your card reader.
Feb 10, 2009 | SanDisk 2GB microSD Memory Card
SanDisk 2GB microSD Memory Card Logo
57 people viewed this question
Top SanDisk Electronics - Others Experts
k24674
Piyal Perera
Piyal Perera
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
