Question about IOGear GPSU21 Print Server
Bind error the segment of the print server you select is different from your computer
5 Suggested Answers
SOURCE: Does IOGEAR GPSU21 work with Vista?
before running the PS Wizard in Vista, right-click on the icon for PS Wizard and select "run as administrator". This will clear the bind errors and wrong segment errors many times - this only applies to vista.
Posted on Sep 28, 2008
SOURCE: HOOKING UP A PRINTER TO NETWORK USING PRINT SERVER
firesnake09
  • 2923 Answers
SOURCE: The segement of the print server you select is
Meaning that the IP Address of the print server is different from the computer's IP Address.
If you're computer has a static IP Address, you need to assign a static IP Address for your Print Server. To assign a static IP for the print server, you need to open the PSAdmin utility on your computer, locate the TCP/IP and click the plus (+) sign. Double-click the IP Address and you may change it from there.
Make sure that the IP Address of your computer, router and print server are in the same IP range. And make sure that you could ping the IP of the print server.
Then configure the printer port settings and you should be able to print.
Have a great day!
Posted on Jul 03, 2009
drifterK
  • 4924 Answers
SOURCE: i purchased an epson stylus photo 1400 printer for
http://www.pcguidebook.com/downloads/printserver.pdf
Here you have instructions about how to set a print server in the router ..and all conflicts that may appear ..Please read carefully cause some of teh steps are needed just in conflict conditions ...and you do not have to run them all ..
The actually first step is to access the server by its IP address and make teh settings for the printer ...after that you should install the printer driver in the computer ..and take the printer and faxes wizard to make the default printer settings ..(choose it from the list after it is correctly connected to the prin server and this one connected to the router )
To connect it to the router you should get into its setting and basically its the same as connecting a computer ..
Posted on Dec 30, 2010
The segment of the print server you select is different from your computer
TROUBLE SHOOT GO TO DEVICES AND PRINTER THEN YOU WILL SEE PRINTER WITH YELLOW MARK ON IT RIGHT CLICK IT THEN ITS GOING TO ASK YOU TO TROUBLE SHOOT IT THEN IT WILL ASK YOU TO FIX IT.
Feb 07, 2011 | Zonet ZPS2102 Print Server
Tip
Wireless Bridging is used to connect two LAN segments via a wireless link. The...
Wireless Bridging is used to connect two LAN segments via a wireless link. The two segments will be in the same subnet and look like two Ethernet switches connected by a cable to all computers on the subnet. Since the computers are on the same subnet, broadcasts will reach all machines, allowing DHCP clients in one segment to get their addresses from a DHCP server in a different segment. You could use a Wireless Bridge to transparently connect computer(s) in one room to computer(s) in a different room when you could not, or did not want to run an Ethernet cable between the rooms. Contrast this with Client Mode Wireless, where the local wireless device running DD-WRT connects to the remote router as a client, creating two separate subnets. Since the computers within the different subnets cannot see each other directly, this requires the enabling of NAT between the wireless and the wired ports, and setting up port forwarding for the computers behind the local wireless device. Segments connected via Client Mode Wireless cannot share a DHCP server. pictoral In the case in which we are interested, a wireless device running DD-WRT such as a WRT54G is configured as a Wireless Bridge between a remote wireless router (of any make/brand) and the Ethernet ports on the WRT54G.
on Jul 16, 2010 | Computers & Internet
My lexmark x7350 won't scan, it says failed to retrieve application, what should I do?
Try launching the scan from the computer. You may not have the monitor program running properly or you may need to reinstall the full feature software from http://support.lexmark.com/index?page=recommendedDownloads&locale=EN&productCode=LEXMARK_X7350&segment=DOWNLOAD&userlocale=EN_US#1 (select your OS). Uninstall and then reinstall; this will cure problems with the driver/software missing dlls.
Try a new data cable and a different port. Try a direct connection if you use a USB hub or print server. (Two-way communication is needed for the scanner to work.)
I hope this helps.
Jun 14, 2010 | Lexmark X7350 All-In-One Printer
My print server is working with a Epson DX4400. It is all setup correctly (according to Netgear) but when I print wirelessly, it only prints half the test page and then the printer stops with an error...
U need to manually add the Printer ports ..
Install the printer driver to the computer first and make sure that we are able to print directly. Follow the steps below after putting the printer and computer back to your network.
  1. Click on Start, then Control Panel, then Printers and Faxes. Right click on the Printer and select Properties.
  2. On the printer properties window, select Ports tab and click on Add Port.
  3. Select Standard TCP/IP Port and click on New Port
  4. This will bring the Add Standard TCP/IP Printer Port Wizard, click Next
  5. In the field for Printer Name or IP Address, type the IP address of the print server and click Next
  6. Select Custom and click Settings button
  7. Under Protocol field, select LPR. For Queue Name, type P1 depending on what print server port is the printer connected to.
  8. Click Ok, then Next, and Finish.
And this will resolve the issue
Feb 06, 2010 | NetGear WGPS606 (WGPS606NAR) Print Server
Receive communication error when attempting to print to an Epson Stylus Pro 7600 via IOGear usb print server
Try disabling bi-directional support in the printer properties to see if that helps. This can be done by going to the Printer and Faxes window then right clicking on the printer icon and selection properties. The go to the ports tab and at the bottom of that windows there is a check box for bi-directional support. If the box is check try disabling this selection, apply the change and then try printing again.
Sep 02, 2009 | IOGear USB Print Server, 1-Port [ GPSU01 ]...
The segement of the print server you select is different from your computer" on Vista,
Have a great day!
Jul 03, 2009 | IOGear GPSU21 Print Server
My wGPS606 wont print on my Windows Vista laptop!
I just found a way to enable the HP P1006 with a different print server (Liveprint on Orange Livebox router). Perhaps this might work with the WGPS606 wireless print server?
I set up the P1006 via the print server as instructed (I'm using Vista 32 Home Premium) but no test page would print.
BUT!! (with thanks to another another forum):
I selected printers, then right-clicked on the wireless printer I'd just installed and selected 'properties'.
Under the 'Ports' tab I deselected 'Enable bidirectional support'.
Problem solved.
Hope this helps.
let me inform you that this printer is not compatible with any wireless print server. The drawback is that it is not possible to network such printers. A printer needs a steady flow of data, which is easily accomplished when it is connected directly to a PC, but cannot be guaranteed when the printer is connected via a LAN. Also, these technologies require intensive handshaking between the driver and the printer.
The host-based software uses the computer's resources to process print commands and rasterizing data, taking advantage of the computer's memory and processing power."
Sorry I can't be more upbeat - but its probably useful to know that someone at HP thinks the job's imposible - unless someone out there has a fix?
May 11, 2009 | NetGear WGPS606 (WGPS606NAR) Print Server
Error E000733-0001
There is a poor contact between the DC control PCB and main controol PCB .
to clear this error press * 28 * and select copier &select function & select clear and press OK
((*)means additional function button on display).
Jul 29, 2008 | Canon (6981A002AA) for imagerunner 2200,...
Jul 25, 2008 | IOGear GPSU21 Print Server
May 09, 2008 | IOGear GPSU21 Print Server
IOGear GPSU21 Print Server Logo
419 people viewed this question
Top IOGear Computers & Internet Experts
Greg Cann
Greg Cann
John Anderson
John Anderson
Are you an IOGear Computer and Internet Expert? Answer questions, earn points and help others
