Question about HP PSC 1315 All-In-One InkJet Printer
Hello, how do I isolate the color printer cartridge HP1315? I would use only the black cartridge.
    Genius:
  • 1,044 Answers
Click on Start Select printer & faxes. Right click your printers icon. On the drop down menu select printing preferences. Uncheck the auto/color box and select grey scale printing. Click OK. All your printing now will be black.
Posted on Apr 04, 2011
Dell v305 printer allignment problem
Hello Michelle,
You are using Dell Series 9 ink cartridges, correct?
If you unplug the printer from the wall and remove the power brick for 60 seconds, this will reset any error messages the printer has. I would then plug everything back in.
Power on the printer.
Open the printer(with the power on) and take out the Dell Series 9 black cartridge and then reseat it. I would then take out the color Dell Series 9 ink cartridge and reseat it. Now close the printer and it will print an alignment page.
Any error messages?
black cartridge = black side(left side) color cartridge = color side(right side)
photo cartridge = black side(left side) color cartridge = color side(right side)
It's possible to get a Dell Series 9 ink cartridge with a bad sensor. I would take these back to the place of purchase for a replacement.
Bhautesh,
Jan 30, 2014 | Dell Computers & Internet
The copies are dirty, with black long tracks!
I would suggest either a fuser problem, If all Colors affected, or the Black Toner Cartridge. The Below chart may help isolate which component is malfunctioning. Repetitive image defects Measurement Component 24.7 mm (0.97 inch) Developer sleeve (Print Cartridge) 26.7 mm (1.05 inches) Charge roller (Print Cartridge) 32.9 mm (1.3 inches) RS roller 37.7 mm (1.48 inches) Transfer roller (ETB) 54.5 mm (2.15 inches) ETB rollers (ETB) 56.6 mm (2.22 inches) Fuser sleeve (Fusing Assembly) 62.8 mm (2.47 inches) Pressure roller (Fusing Assembly) 75.4 mm (2.97 inches) OPC (Print Cartridge)
Jan 13, 2011 | HP Color LaserJet 2600n Printer
What type of ink cartriges are used in the lexmark 5400 model
hello there
here is the lexmark ink cartridges #31 for color and #32 for black 18c0031us_sm.jpg #31 Photo Color Print Cartridge (18C0031) $ 34.99 QTY 18c0032us_sm.jpg #32 Black Print Cartridge (18C0032) $ 24.99 QTY 18c0533_sm.jpg Twin Pack #32 Black Print Cartridge (18C0533) $ 47.99 QTY 18c0033us_sm.jpg #33 Color Print Cartridge (18C0033) $ 26.99 QTY 18c0534_sm.jpg Twin Pack #33 Color Print Cartridge (18C0534)
Sep 29, 2009 | Lexmark X5470 All-In-One InkJet Printer
Color ink cartridges empty, printer wont continue to print
select print black only from the print or page set-up.
Mar 30, 2009 | HP Color LaserJet 2600n Printer
Question about ink cartridges
The printer will take a little quantity of color ink though you are printing in black in order to get good quality. Hence it is not possible to print with just black ink cartridge without color cartridge.
Thank you.
Dec 06, 2008 | Compaq A3000 All-In-One InkJet Printer
924 says that black ink cartridge not installed
Hmmm....that sounds to be an issue with the ink cartridges...
You might be using ink cartridges purchased other than Dell or Staples...since these are the two who sell Dell Ink.
If thats not true, then take out both the cartridges in the printer.
Lets isolate the issue
1. Try only Black cartridge on Color slot(right). If you get Install both ink cartridges error, then its an issue with the Black ink cartridges and if you get message that install Black ink cartridge then its an issue with the prrinter.
2. Now install only color cartridge on Black cartridges slot(left), If you get color cartridge missing then its an issue with the Black cartridges which you are using and if you get install both ink cartridges then its an issue with the black slot on printer.
3. If issue found to be with Black ink cartridge then wipe the Nozzles(bottom) of the ink cartridge with lint free cotton cloth from back to front 5-6 times.
4. Also try replacing the ink cartridges purchased only from Dell or from Staples. Purchased from somewhere else or refilled might not work.
5. If issue found to be with printer, then i would suggest you to purchase new printer then.
Hope this fix the issue
Aug 14, 2008 | Dell 924 All-in-One InkJet Printer
Lexmark z1300 printer - one cartridge
if you look at the options in the printer there should be an option to use the color cartridge to print black. How does this work? Well what the printer will do is mix all three colors to make a light black. This will eat up your color cartridge faster but is useful when you are out of black ink and you need to print
Apr 23, 2008 | Lexmark Z1300 InkJet Photo Printer
My Hp PSC 1350v
Hi, I really appericate all your efforts to fix the issue the issue usually occures if any one of the cartridge is defective or low in ink or both the cartridge are defective. We can isolate the issue only by removing the both the cartridges out of the printer and check for the expiry dates printed on the cartridges as if the cartridges are expired also leads to this message. If the cartridge are not expired and have minumial ink in it you can try the below procedure to isolate the defective cartridge Once the both the cartridges are out of the printer insert only the black cartridge in the printer and check for the message if the message is install color cartridge the black cartridge and printer is detecting fine. If the message is check right cartridge this shows that the black cartridge is defective. If the message is insert left cartridge or color cartridge remove the black cartridge out and insert only the color cartridge and check with the message if the message is insert the black cartridge the color cartridge is working fine. And when the color cartridge is in the printer and if the message prompts to check left or color cartridge the color cartridge seems to be defective so replace the defective one will fix the issue So in isolation we can find the defective cartridge and fix the issue by replacing the defective one.. Hope this will help you to fix the issue.. Wish you success. Regards, Barret.
Sep 12, 2007 | HP PSC 1350 All-In-One Thermal Printer
HP PSC 1315 All-In-One InkJet Printer Logo
Seeker5211
Seeker5211
