Question about Garden
Need to order a replacement pump Part # C878-A1 for a Garden Treasures Accent Cast Aluminum/iron Fountain Kingston, Model C878-62
4 Suggested Answers
SOURCE: Parts for Garden Treasures 2 tier fountain
Call the company 1-800-446-9092, this is the number on my papers from the 3 tier fountain i just purchased today
Posted on Jun 16, 2009
  • 3 Answers
Bought innova fountain at Lowe's a couple of years ago and just bought the Kingston one. They are basically the same. Phone number 1 877 556 0886. Part came within a week and easy to fix. Customer support was very helpful. I saved my manual, but they will send you a new one if necessary. Now working fine! Hope this helps
Posted on Apr 27, 2010
kjhbwetrgwkj
You can find replacement parts on amazon. click here Amazon com tier fountain parts and search for your part. Hope this was helpful. cheers
Posted on Nov 24, 2014
What Kind of Steel Shot Is Used In Shot Blasting Machine?
Steel Shot Blasting
Usually, the hardness of steel shot can be improved to HRC40 ~ 62. It can be used in processing hard metal. It is more widely applied in shot blasting machine because of its excellent toughness and long service life.
Cast Iron Shot Blasting
The hardness of cast iron shot is HRC58-70. Cast iron shot is too brittle to be broken easily, so the service life is short. It is mainly applied in those processing of high shot peening strength requirements.
Glass Bead Peening
The hardness of glass bead is less than the previous two steel shot, which is mainly used in processing stainless steel, titanium, aluminum, magnesium, and other situation excluding iron pollution. Also, glass bead can be used in secondary surface treatment after steel shot blasting in the purpose of removing the iron pollution and reducing the roughness of workpiece surface. http://www.jxabrasives.com/
Jan 13, 2017 | Coffee Makers & Espresso Machines
Can I use a cast iron pan on glass cooktop range
Yes you can, magnetic induction stoves are working with anything metalic.
Mar 17, 2015 | Kitchen Ranges
What is the head bolt torque setting
Briggs and Stratton repair manuals are available at all location ware B&S parts are sold except lowes and Home Depot. I have one in my garage the cast iron motors are different then the aluminum ones I will need the model number for the exact torque spec 60000-130000 is 140 170000-280000 is 165 Aluminum and cast Iron is 190 IN.LBS. THIS IS ALL IN IN., LBS.,
Oct 09, 2014 | Briggs & Stratton Garden
Engine aluminum or cast iron?
it appears that the 2WD drive LT's have the iron block while the 4WD trucks have the aluminum block
Jul 12, 2014 | 2011 Chevrolet Silverado 1500
Knocking compressor
really depends on the model of compressor but if it is an oil less compressor best thing is to junk it and buy a oil lubricated with a cast iron pump dont get one with aluminum if you want a compressor to last you for many years.
Mar 19, 2014 | Hitachi Air Tools & Compressors
Sounds like valve is stuck. is engine cast iron or aluminum?
Get a magnet and check it. That's the easiest way int determining the difference between aluminum and some other type of metal
Feb 08, 2011 | Garden
Fountain pump motor runs but no pressure to push water
You can try to force prime with a garden hose. Put the hose in ether side suction or discharge.
Jul 07, 2010 | Little Giant Submersible Fountain Pump
Need replacement pump with light
I have the same fountain and same problem. You need a 10 watt 12v halogen bulb. Just wiggle the tube cover off and pull the bulb out. You can buy replacement bulbs at Lowes or 10 for $7.00 on ebay.
Jun 20, 2009 | Garden
Apr 05, 2009 | Garden
De-icer must have a short
The best solution to ice in garden ponds is to keep the water moving as moving water will not freeze. Depending upon the size of your garden pond you may try adding a fountain. All major pump brands carry small fountain pumps that include various fountain spray nozzles/heads or you can buy the pump and then purchase a Fountain Head Kit separately. The fountain will provide 1 - movement of water at the surface, 2- aeration for the pond, 3- pleasing sounds year round, not to mention the 4- aesthetic value. The added bonus is that you will not have to worry too much about shorts if you use a submersible pump. So try dumping the deicer and go for a fountain.
Dec 29, 2008 | Beckett Water Gardening Water Garden...
Garden Logo
537 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
