Question about EuroTech EWC177 Front Load Washer / Dryer
My daughter was using the machine, we believe she overloaded it. At the beginning of the cycle, it was very loud trying to turn the load and then there was a smell like thing was burning. We stopped it, powered down, unplugged it, emptied the clothes, and drained it from the front filter door and tilted it forward to drain a bit more. Then waited fifteen minutes and plugged it in, powered up and the front panel lights flashed four times, fast, then all the lights went out, even the power light. We went through the same procedure and the lights flashed once, then nothing. We have had it unplugged since. We called local appliance shops none were interested, called the number in the manual for nearest repair shop, two in a city 2.5 hours away. One was out of business, the other was on holiday for a week; we left a message with second. They called back last week, said they do not work on Eurotech and suggested we try your online service and may have to order parts from your site. Does it sound like a blown fuse? Will the parts available at our local hardware store?
  • EuroTech Master
  • 1,525 Answers
Hello, if it's total dead then it could have blown the fuse. it will be a glass type in the washers power supply. that smell could be the motor burnt out. which can cause a short to ground cause the fuse to blow check the belt at the back might have come off or snaped hope it helps
regards
shaun
Posted on Apr 04, 2011
Whirlpool cabrio model 6300sw1 won't aggitate and gives ol code
It is overload error.
"oL" (Over Load)
Is the washer overloaded? The washer has attempted to fill •
and begin the wash cycle. If the washer is overloaded, it will
drain any water and detergent that was added during the fill.
To correct the overload, remove several items and add
detergent. Close lid and press START.
Also try to download user manual from this site and check page 19.
Download WHIRLPOOL CABRIO WTW6300SW1 Use Care Manual
Sep 03, 2014 | Whirlpool Washing Machines
How can I get My Affinity6000 washer to drain out all the water?
I suggest taking half of the load out and starting it over from the beginning.
Jul 19, 2014 | Frigidaire Affinity ATF6000F Front Load...
Machine screeches loudly when wash and rinse cycle begin
does it do it on a spin cycle ? if so your bearings may be shot. also try running it empty if it doesn't do it then you may of just had an unbalanced load. if it dose then you probably had shot bearings.
Nov 18, 2010 | Maytag PAV2300 Top Load Washer
In the Spin cycle, after 9 minuts, it will stop with a "UL".
"UL" means "Unbalanced Load" - make sure the washer isn't overloaded first or if you are doing rugs, blankets, or lots of jeans, split the load. You can also try running an empty or light load and see how the machine behaves.
If you still have the problem, you may have some issues with the drum bumpers, etc., but try the easy things first.
Jul 12, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Loud knocking sound when in wash cycle GEWDSR2080
After taking off the front cover, look up at the top of the tub just under the lid. there should be a thick rubber strap at each corner of the machine tying in the tub to the top. These are called dampening straps. One or more may be broken. I usually replace all four if I do one.
Nov 13, 2009 | GE WDSR2080D Top Load Washer
Turn off ALARM - Whirlpool washer
This sounds like the imbalanced load alarm. This can occur with large heavy loads like blankets, bedding, lots of diapers (cloth), jeans etc. The best solution is to wash lighter loads and not overload the machine. If overloading continues, the machine could be damaged.
Apr 11, 2009 | Whirlpool Ultimate Care II GSW9650LW Top...
Washing machine very loud and machine moves during spin cycle
Normal these mean unbalance load of clothes. Try to balance it with heavy clothes opposite each other. The fabric that hold more water tend to be heavier during the spin cycle. Also try not to overload the machine by washing clothes just half to 3 quarters full
Jan 05, 2009 | Amana ALW480DA Top Load Washer
Kenmore 80 series. RUNS LOUD, THEN TURNS OFF AND RESETS...
you have something gotten into your pump ,,, it trys to drain and spin but overloads the motor and shuts down till the motor switch resets .... remove the pump and take out whatever gotten in it and if that not possable replace the pump.
Nov 24, 2008 | Kenmore 24032\24036 Top Load Washer
Loud clicking noise - wont agitate or spin
I had the same clicking noise. Turned out to be the coupling between the motor and transmission. A $15 plus 1 hour labor fix
Nov 10, 2007 | Kenmore 22422 Top Load Washer
Series 70 Kenmore Washer Won't Agitate or Spin
baseball, sounds like a broken coupler, check out this post and post back, Catriver http://www.fixya.com/support/t144580-kenmore_8series_washer
Apr 26, 2007 | Kenmore 22422 Top Load Washer
EuroTech EWC177 Front Load Washer / Dryer Logo
126 people viewed this question
Top EuroTech Washing Machines Experts
shaun taylor
richie46
Are you an EuroTech Washing Machine Expert? Answer questions, earn points and help others
