Question about Equator EZ 3612 CEE Front Load Washer/Dryer
I'm looking for the wiring schematic for the control board.
    Brigadier General:
  • 6,277 Answers
Sorry, this forum does not supply any type of manual, installation instructions, electrical or schematic diagrams direct; it's just made up of ordinary guys and gals, probably at home and from all over the world, with experience of addressing problems and giving guidance for free on the web ;-0)
You will need to type into your search engine/web browser '(make) washer schematic' and you may be presented with a number of sources from which you can either download for free or have to pay a nominal amount. During the process you will be asked for the actual model number!
May I also suggest you try the manufacturer's web site direct? You may find, however, that it will supply only to service engineers but good luck anyway.
John C.
Posted on Apr 04, 2011
  • Heartland Ho Apr 05, 2011
    I have called the manufactures "help" desk. They were "unsure". That was their response. They didn't have the board, that's why I wanted to trouble shoot. I spent $1200 for the washer/dryer combo unit, only to discover there is virtually no support.
    Fortunately, I found a link for the service manual with schematics here:
    http://laundry.manualsonline.com/np/user...
    Hopefully, if/when someone else is looking for a service manual vs. owners manual, they will find this post and be able to figure out how to fix their machine.
  • john_cross Apr 05, 2011
    You actually posted your query twice which was what the 'other' response was about ;-0)
    Glad you managed to find an answer from on-line.
    John C
Schematic m12 circuit board
Also looking wiring schematic M12 Milwaukee charger
Sep 27, 2016 | Milwaukee tools Milwaukee Electric Tool -...
DOES ANY BODY HAVE A SCHEMATIC FOR SPEED CONTROL BOARD OF GLTF2940EE0
Thank you for your post, Gamaliet Figueroa!
Based off the information you have provided you are searching for a schematic of your speed control board for your Frigidaire washer. I was unable to locate a wiring schematic but I was able to find additional manuals that could be of better assistance. I hope this information is helpful. -Matt
Frigidaire Manual Search Results
Nov 09, 2014 | Frigidaire Washing Machines
Can anyone provide a location where is can find a schematic for the HVAC control dash unit out of a 2005 Buick Park Avene?
There won't be a schematic available for what your asking. Only electrical schematics that show wiring harness (to and from) the A/C controller. So what I suggest you do is go to a "Pick Your Part" type wrecking yard and get a replacement controller from a simalar Buick or Chevorlet model. Should be a couple different models built in '05 that use the same controller
Apr 10, 2014 | 2005 Buick Park Avenue
Frigidaire washer door catch is stuck, washer won't run
After looking at the schematic of this machine it seems that the door AND the control board have to work perfectly together in order for the safety mechanisms to operate correctly. You may have a bad control board or a loose wire. The best thing to do is look closely at a schematic and make sure that everything looks right. here is a blueprint: http://www.pcappliancerepair.com/model/index.php?id=FWT449GFS1
Jan 03, 2014 | Frigidaire Affinity ATF7000E Front Load...
Schematics for a tm1050 remote
you will not find any schematic for remote control.
I am suggest you to open the remote control, and clean the keypads, from humitidy, dirty, oxide, and dry with dryer gum, very carefully.Resolder the colder joint in a board remote
2) retigh the spring contact batteries with pliers for a GOOD contact.
3) resolder the wires contacts batteries.
4) clean the contacts batteries.
God bless you
Jun 30, 2012 | Samsung Televison & Video
My daughter plugged welder into 220 volt outlet. Nothing works: trigger. wire feed motor, cooling fan, gas valve. Bypassed the push button overload-no difference. If I manually depress the magnetic switch...
The weld wiring burning doesn't meant the transformer is good, it only means you have shorted hot to ground and thats what happens when hot touches ground it heats and melts. I would start by looking for a schematic for you welder. Check and making sure your getting good power to the power supply, relay(s) first. Also you can ohm out the transformer and check for the proper resistance but without the schematic/wiring diagram I can't say what the specs are. Normally on these the power comes in to the switch and then to the relay(s) which send power to the fan, and then splits to the trigger which allows power to the transformer, wire feed motor etc. But without the diagram your just shooting in the dark.
Jun 21, 2011 | Hobart Handler 140 Mig Welder
I changed complete sump ,main control board, display board,and fixed wires that were broken in tar now it will not power up thanks wm.
Carefully compare your wiring with the wiring schematic on the dishwasher....there usually is a schematic right inside the kickplate cover in an envelope...
If you have power going to it and it is not wiring now then the power is not getting to the right plaes inside...
heatman101
Dec 09, 2010 | Dishwashers
Does anyone have the schematic for LCD control
Tom,
I don’t believe you will find a schematic for the control board. I have a FAV6800AW all I have be able to find is the wiring schematic found in the FAV6800AW/FAV9800AW Service Manual.
Is your machine out of the 5yr warranty period for the Control Board? I got Maytag to send me one.
Saw this on e-bay
NEW - Maytag Washer LCD Control # 25001189
Good luck … Rich
Oct 08, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Equator EZ 3612 CEE Front Load Washer/Dryer Logo
145 people viewed this question
Top Equator Washing Machines Experts
Heartland Ho
Level 1 Expert
Dan Webster
Dan Webster
Are you an Equator Washing Machine Expert? Answer questions, earn points and help others
