Question about Home
Does a danfoss Tempress II shower Cartridge stop working if water is to hot
  • 374 Answers
SOURCE: Not enough hot water
Some higher end models do have an adjustment that is behind the face plate. You would have to remove the handle and the screws in the faceplate to expose them. If you have adjustments they will be located on the brass valve body facing you. You will need a flashlight and a flathead screwdriver to make the adjustment. If your model is not equipped with adjustments you could have a faulty valve stem. The stem is comprised of a rubber band like gasket that separates port holes into which the waters flow. There could be some piece of trash blocking the port not allowing adequate water from the hot side into the valve.Some valves stems are also able to be installed upside down causing the same issue as the ports do not rotate fully to allow adequate supply. However you say that you have adequate pressure on the hot side but not warm enough. There is another possibility also based on the way the shower supply was plumbed but there is no need to go into this unless this does not resolve your issue. I hope this is of assistance and thanks for using Fix Ya. Please let me know if I can be of further assistance.
Posted on Oct 21, 2008
  • 4 Answers
SOURCE: replaced a moen cartidge and now the water is not hot in shower
make sure when you turn on the hot and cold shut off valves all the way and turn the moen on after that. Some times I would get that problem if I turned one(either hot or cold) off then tried the shower.
Posted on Feb 26, 2009
  • 297 Answers
SOURCE: Does a 062N1285 valve replacement fit a Danfoss
if it looks the same it may work,some valves may be interchangable must look the same.
Posted on Jul 24, 2009
  • 297 Answers
SOURCE: Insufficient hot water from Gledhill pulsacoil 2000
changing the shower head will not do anything.to do what you want,you would need more BTU's or a bigger unit to supply more water,someone may be hogging the water also.
Posted on Jul 26, 2009
SOURCE: Leaking Danfoss Tempress II.
The valve cartridge needed to be gently pried/wiggled free. It actually has two plastic pins that seat into the brass body. All fixed!
Posted on Oct 28, 2009
There is no hot water
Hi Marshall,
Do you mean that no hot water is reaching the shower, or do you mean that no hot water is coming out of the shower. The answer to this will determine where the problem is.
If no hot water is reaching your shower, then there is probably a problem with the boiler or the pipe is blocked. You can easily test this. You can turn on other faucets in the bathroom to check whether any hot water is reaching those.
If the problem isn't with the boiler and the shower is in fact receiving hot water, then the problem will be with the shower mixer valve, specifically the thermostatic cartridge. The cartridge controls water temperature. The inner workings of the cartridge move up and down to adjust the amount of hot and cold water entering the cartridge. If it has seized up, the moving part can get stuck in a certain position. It sounds like this could be the case with you and therefore replacing the cartridge should in theory fix the problem.
Hope this helps. Shower Thermostatic Cartridge Spares
Nov 14, 2015 | Home
Shower valve making banging noise pressure balanced even after changing cartrige
turn hose water off. open facet at lowest level to drain out lines. open a few faucets around the house to let air in. then close everything up. turn water back on. repressurize system by turning some faucets back on. see if it still happens. this is letting air back into any anti-water hammer devices that might be in system. sometimes they loose the air in them that makes them work. this should add air back in. good luck.
Mar 10, 2015 | Grohe Danfoss Tempress ll Tll Shower Valve...
Water not warm enough comming from shower. Very hot comming from tap. I think it is a problem with the mixer unit in the shower
Replace your Tempering valve cartridge.
Should do the trick.
This will cost a couple bucks for that cartridge.
Dec 23, 2010 | Dmm Symmons Temptrol II pressure balancing...
I just replaced a cartridge in my hot water shower handle to stop a leaky faucet, now the hot water pressure is less. It seems once cartridge is in place it doesn't have the range of motion it had when it...
you need to go back in and check your work it seems that it has been installed in a lower setting look at the directions, most shower assembly's have energy settings.usually just have to move the stopper to the farthest point to the left (counter clock wise).good luck.
Nov 14, 2010 | American Standard Home
I have a thermostat mixer shower but hot water has become minimal recently, even when water is piping hot from the taps? The shower is fed from cylinder tank on 1st floor, and cold water tank is in the...
The thermostatic mixing spool cartridge may be worn out. The low water pressure may indicate sediment in the cartridge as well. This can be easily removed by hand tools
Feb 17, 2010 | Grohe Integrated 1/2'' Shower Thermostatic...
When i turn the hand valve to the hot side the flow of water stops. I checked the water line from the hot waterheater and hot water goes to other faucets.
This sounds like a bad cartridge motor. Turn off the water and remove the cartridge from the valve. You will have to remove the cap, knob, screw and cartridge clip. Pull the cartridge out (carefully) and inspect it for loose parts, plugging, or if the spool valve is blocking the hot water port. If it is, it's defective and will need to be replaced. You should be able to get a replacement at most home improvement stores.
Dec 12, 2009 | Moen & Posi-Temp Single Handle Shower Or...
Oct 14, 2009 | Grohe Plumbing
No hot water flow from faucet/shower
change the cartridge it is bad or defective.
Jul 20, 2009 | Delta & Single Handle Shower Faucet
Jul 15, 2009 | Plumbing
Replaced a moen cartidge and now the water is not hot in shower
Feb 23, 2009 | Moen & Posi-Temp Single Handle Shower Or...
Home Logo
248 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
