Question about Electric Superwinch LP8500 Series Utility & Off Road Winch LP 8500 12 Volt DC Electr
I have a 14 volt source but when I try the winch in either forward or reverse the voltage drops to 4 volts. The drum is not seized because you can pull the cable out easily by hand.
  • 3,287 Answers
Not only do you need a 12 volt supply (13.8V) to operate this winch, but you also need a.) wire large enough to carry the electrical load, and b.) a power source that has the necessary current (amps) to turn the motor.
If you have wires that are too small, they will heat up and not be able to deliver the current (amps) required by the motor. If your power source is to small - it can not supply the current required. The result of either conditions is "voltage drop". This can be explained the same way your car needs a 12 volt car battery to start. If that car battery was dead, you couldn't connect eight "D" cell batteries (8 x 1.5volts = 12 volts) together and attach to the car's battery cables and expect it to start. This is because the amount of current available in the car battery is hundreds of time greater than eight "D" cell batteries - even though when the D cells are connected in series - both systems deliver 12 volts.
If neither of the above conditions is present, then there could be an electrical problem with the drive motor itself. This could be a shorted / melted winding or other electrical connection that is not right, even if the drum spins freely.
Posted on Apr 04, 2011
How test circuit diode schottky
Take your digital volt meter. Place meter on the diod setting. Place your probes on each leg. You should read .7 to .2 in the forward position and infinity or high megs in the reverse position. You'll need the data sheet to find out spec.
May 30, 2014 | Electronics - Others
Tip
Xantrex inverter error codes
This information expands upon the error code information contained in the Link 2000 Owner?s Manual.
E-01 Inverter high DC/Battery voltage shutdown Battery voltage has risen above 15.5 VDC for 12-volt models or 31 VDC for 24-volt models.
E-02 Inverter low DC/Battery voltage shutdown Battery voltage has dropped below 10 VDC for 12-volt units or 20 VDC for 24-volt units.
E-03 Inverter or Charger overtemp shutdown Unit will reset automatically after it has cooled sufficiently.
E-04 Battery overload Caused by excessively discharged batteries. See section in inverter owner?s manual titled ?Charging overdischarged batteries.?
E-05 AC Backfeed AC power from an outside source has been fed to the AC output of the inverter. Potentially damaging to the unit. Disconnect incoming AC power and correct the situation.
E-06 Electronic Overload Inverter overload caused by too large a load or a short circuit. Reset by cycling power switch or connecting incoming AC power.
E-07 Triac control error Triac has overheated. Shut down unit and allow to cool.
E-08 High battery voltage shutdown during charge mode Check all charging sources for proper voltage. Reset by cycling the power switch.
E-09 Spare
E-10 Link 2000 de-powered This indicates that power was removed and restored to the Link 2000.
E-11 Spare
E-12 Battery #1 voltage sense leads open Blue wire is not connected to battery #1.
E-13 Battery #2 voltage sense leads open Violet wire is not connected to battery #2. E-14 Inappropriate Charged V selected for sensed voltage This value defaults to 13.2 for a 12-volt system, 26.4 for a 24-volt system. If this setting is above the voltage limits of the charging source, this error code will be displayed. Please refer to page 9 of the Link 2000 Owner?s Manual
E-15 Incoming AC polarity reversed Check incoming AC wiring for a reverse polarity condition.
CCC Indicates battery being charged. Displayed when Time remaining is selected. LO BAT More than 50% of declared capacity of battery 1 or battery 3 has been consumed.
OL Meter reading out of range U xx Designates a user setup CEF. Please read the sections pertaining to CEF on pages 19?22. A Designates Alternator output current on a Link 2000-R. is a number from 1?200. P Indicates Percent of charge mode selected. is a number from 1?100.
on May 14, 2015 | Xantrex Technology Electronics - Others
Clark vision l 38 auto floor scubber how can i test a 36 volt solenoid
The best way is to put a voltmeter on the forward motor leads first, if no voltage appears or a very low voltage appears when foirward is engaged, the contactor contacts will be the problem,
The contactor windings can be checked with an ohm meter. The resistance should be less than 3000 ohms, Use the reverse contactor windings as a reference for a better idea of the resistance you should see in that unit.
A nonconductive stick can also be used to push the contactor closed, but make sure the scrubber is up abainst the wall with someone at the handles when you do this, as you will be applying more pressure on the contacts with the stick than the windings will when energized and it will likely want to lurch forward and possibly to one side.
Otherwise out of circuit, use a variable power supply with a voltmeter attached and slowly raise the voltage until the contactors close- which should be in the area of 32 to 34 volts. and starting from 36 volts, slowly lower the voltage and the contactor should drop at about 30 volts, maybe as low as 28 in most cases.
IMHO, the forward contactor is the likely source of the problem.
Sep 19, 2012 | Welding Tools
Relays click constantly in forward and reverse and unit does not run.
If the relays constantly click, your motor is shorted out and bad causing your thermal breaker to trip and open the relays. You will have to replace the motor.
Feb 20, 2011 | Electric Superwinch LP8500 Series Utility...
My winch won't work anymore...there is a clicking noise and winch wont turn....I check the connection and its good.
Take your voltmeter and verify your voltage at the switch. If it is 11.5 or better, try reversing the motor. Reverse direction requires less ampreage to run and should work fine, then try forward or wind.
Nov 04, 2010 | Electric Superwinch LP8500 Series Utility...
MAY NEW ALTERNATOR PUTS OUT 14 VOLTS WHEN I START THE DIESEL 5.9
the voltage regulator is in the computer,check you battery with volt meter with engine off it should say 12volts then check it again with engine running and it should say 14-15 volts. if not the you will have to take it to a dealer to check the computer,hope this will help you!!!
Apr 19, 2010 | 2002 Dodge Ram 3500 Truck
Shop rider mobility vehicl, forward speed less than reverse speed
Hi. The black boxes on these machines are quite reliable. Where are you measuring the voltage from?
How are you testing the batteries? I have seen fully charged batteries do this, because the batteries are not able to supply enough current. The batteries will charge up properly, but they ready for the scrap heap. If you want the batteries tested take them to your nearest auto electrical store and they can test them. Good luck. Neil.
Feb 21, 2010 | Health & Beauty
My heat and AC fan wont come on and all the fuses are fine
What I would do is pull the fan blower motor speed switch, plug the wires back into it while you're holding it in your hand, run the car, and check with a multitester and see if you are getting voltage at the switch. Should be something like:
High=12-14 volts
MHi=8-10 volts
MLo=4-6 volts
Low=2-4 volts
OFF=no voltage
If you get voltage but the fan still doesn't work, then it's either a bad ground, or the motor is bad. If you can access the blower motor wire connections(sometimes its easier to try this with it removed from the vehicle), then you could try jumping the blower motor at the wiring connection with a known good 12 volt source, and if you STILL can't get the motor to spin then it's seized up or it's just a bad motor. If you have the motor removed, try spinning the squirrel cage by hand. Is it stiff? Seized? Probably need a new one if it doesn't spin freely by hand.
Hope this helps!
Nov 08, 2009 | 2003 Saab 9-3
Unit will not pull up the anchor
First, put a volt meter across the winch's power terminals to verify that the voltage is not dropping several volts when comanded to run, indicating a bad cable connection somewhere. Anchor winch's pull alot of current from a battery.
For a test, use car jumper cables from a good battery to the winch to see if it runs better.
Oct 18, 2009 | Boating
Amp not getting sufficent voltage
Does the car start with the voltage dropping like that? Sounds like a bad battery. A battery can show 12.6 volts and as soon as you put a load to the battery the voltage will drop. I would change the battery and see if that helps. Also check your alternator. Get a DMM set to DC volts connect it to the battery and see how far the voltage drops when the cars running. You should see something like 14 volts or so. If it drops below 11 volts you may need to upgrade the "big 3" wires...hope this helps
Mar 18, 2009 | Kenwood KAC-9152D Car Audio Amplifier
Electric Superwinch LP8500 Series Utility & Off Road Winch LP 8500 12 Volt DC Electr Logo
191 people viewed this question
Top Electrical Supplies Experts
ashburton
Steve
Mike Carew
Are you an Electrical Supply Expert? Answer questions, earn points and help others
