Question about Toro Power Lawn Mower
Where is the oil plug underneath the mower? - Toro Power Lawn Mower
    Novelist:
  • 111 Answers
Depending on what engine is on your Toro lawnmower, there may not be a oil plug under the mower deck. A briggs and stratton engine will have one, but if the unit has self propel then you will have to move the guard over the self propel cable. This is a 1/2 in bolt, you will also have to loosen the other bolt to swing the guard around.
On a Kawasaki or Honda, and even if you have a Tecumseh engine then just start the mower up for a few minutes and let the engine oil get warm, then shut the engine off and then lay the mower on the side that has the oil filler cap and put your drain pan under the oil filler cap. You can then drain the oil out of the oil filler tube. You can also do this with the briggs and stratton engine. I find this to be a very convenient way to change the oil.
Then put fresh oil back in the unit. I always suggest to put the engine manufacturer's oil back in the unit, or if that is not available then use another oil from another engine manufacturer. IF you use automotive oil, the oil will break down faster since the heat level for the engine on car is less than that of the engine on your lawnmower. The engine has a water cooled design, that keeps the engine temperature from raising over about 250 degrees F. The engine temp on your lawnmower can get as hot as 400 degrees F in the summer heat and being run for 30 minutes or longer.
A longer answer than you had hoped but I hope the information keeps your lawnmower running well for many summers to come. :)
Posted on Apr 05, 2011
Testimonial: "Thanks!"
  • maro_lover Apr 23, 2011
    many of them incl kawasaki have a drain plug on the side of the block not the bottom. the older mowers are underneath
Is their an oil cap under neath lawn mower that can be used to empty oil?
Good question. Unfortunately is varies. Some mowers have a Plug underneath ( look at motor casing , past the blade). Some have a metal tube or a small plug on the side of the engine very close to where the Engine mounts to the deck.
Some just want you to pour the old oil out the Fill.
Sep 10, 2015 | Craftsman Garden
How to change oil on Power Mower
Hi bob--
The link at the bottom here has a good picture of what you should be looking for underneath the mower as far as drain plugs on power mowers go. At that website, just scroll all the way down to the photo of oil changes.
Please be sure you disconnect the spark plug before you do anything else to the mower. Also, once you locate the drain plug underneath the mower and you have it open, open up the dipstick or the oil fill caps on the mower and LEVEL the mower as best you can over whatever you're using to collect the used oil. This allows the most amount of used oil out of the machine. I like to add new oil to the fill cap until I see new oil pouring from the drain plug--but that's a little overkill!
After you've reinstalled the drain plug. Put the mower on level ground and start filling SLOWLY. Check the dipstick often--it is easy to overfill the crankcase, and then you will have to empty the excess oil and go back to fill again. Just take your time. Good luck.
--Hope this helps. If it does, please vote and comment. Thanks!
http://floridagardener.com/misc/tuneup.htm
Oct 08, 2010 | Troy Garden
Oil change
Most push mowers, you just take out the filler plug and turn it on it's side to drain.Set the mower up on blocks so it rests 6-8" off the ground, place a large catch pan underneath for the oil.
Apr 09, 2010 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Need oil plug for a 1988 toro mower - discontinued
If you have the pieces of the old plug, take them to a hardware store. Use the thread to find the one you need in their inventory. There are a number of thread designs that you have not mentioned, you can find it there. Good luck...Lee
Nov 22, 2009 | Toro Lawn Mower With Toro Power Tools
Where is the oil drain plug for a craftsman mower model 917376460
The drain plug is underneath the mower where the blade is. pull the spark plug wire, take the blade off, then take a 3/8" ratchet with small extension and you should find a plug in the bottom of the engine to take out and drain the oil.
Make sure when you fill it back up it should only take 20 ozs. of oil to fill it back up.
Sep 28, 2009 | Craftsman Garden
HELP, 2007 Toro walk behind mower
There is a drain plug on the block of the motor usually it looks square. if its not behind the blade on the under carriage, then it will be on top above the blades were the motor is visible. you may have to tip the mower on its side to completely drain all the oil. but the plug is always going to be on the motor either on the side or on the bottom. if the plug is on the bottom were the blade is remove the spark plug wire first. a mower can start if you turn the blade by hand and that would be vary bad news so always take the spark plug wire off and make sure it can not come in contact with the spark plug before going underneath the mower.
Jul 30, 2009 | Garden
I've been given a Craftsman Eager 1 6.5hp mower (front wheel drive)and I can't locate the oil drain plug.
On a walk-behind mower, the oil drain plug can usually be found on the underneath side of the deck. The drain plug usually has a square head.
Jun 23, 2009 | Garden
How to change oil and where i put the oil in to the lawn mower mtd 3.5hp / 20
Warm up the engine so the oil will flow out. Push the handle to the ground and either have someone stand on it or wedge it underneath something to hold it down. Disconnect spark plug!! Remove blade. Place a drain pan underneath mower (one that's shallow enough to lower the mower down on) and using a 3/8 extension on a ratchet, stick the square end of the extension in the drain plug in the bottom of the engine and unscrew. Lower mower back down for a couple of minutes then reverse proceedure. I think it holds about 20 oz. of oil. Put in 18 oz. and check it. Be sure not to overfill.
Jun 03, 2009 | Mtd Yard - Man 160cc, 21" Self - Propelled...
My Troy-Bilt 21'' 3-in-1 self-propelled mower will not start
Next time keep the carburetor up...tipping it down will allow oil to go where it's not supposed to. For now drain out the remaining oil, replace the air cleaner and remove the spark plug. When the plug is out pull the engine over a few times. It's possible that there is oil in the cylinder and this will help clear it out. Replace with a new plug and try. If this doesn't work, repost.
Apr 11, 2009 | Troy Garden
Oil drain plug how do you find it
the oil drain plug is underneath the motor by the blade you can use the socet wrench to open it
Apr 04, 2009 | Mtd 22" Yard Machine Push Mower
Toro Power Lawn Mower Logo
460 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
lnbn1975
Mike Squire
Are you a Toro Garden Expert? Answer questions, earn points and help others
