Question about Bosch Washing Machines
I have a Bosch WFK 5730 Washing Machine (getting a bit old now!!). The washing cycle has now stopped using the fabric softener in the drawer. The rest of the wsh cycle appears to work as it should. Can anyone help me to know whether this is correctable or not; and if so how to do it? Thank you - Howard
    Guru:
  • 500 Answers
Getting old yes indeed, but the problem should be fixable.
There are two things to look for, firstly the cap on the fabric softener compartment.
You should remove the whole drawer, by pressing down the one part hooking it onto the outer Soap Box. Once done, you can take of the cap and clean it. These caps are usually blocked by softener build-up, and thus nothing can get through the hole to the drum - Most common problem if the compartment runs over with water but no fabric softener goes to the drum.
Or you should check the outer soap box. To do this is a bit more tricky - Remove the top panel, usually screwed tight at the back of the machine by 2 screws. After removing the panel, you should see the big detergent outer box, remove its top panel and clean the small water holes at its reverse. What happens here is these holes also get blocked (by age - you said it was old), and by unblocking these holes you will allow water to get through with no problem.
Good Luck
* If you found this solution helpful, please rat 4 thumbs up and leave a small testimonial. :-)
Posted on Apr 04, 2011
Testimonial: "Thanks very prompt reply. First attempt no good. Second excellent after some adaption. You have made an old man very happy."
Dispenser fabric softener slot
Fabric Softener Compartment Full Of Water - White Goods ...
www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help
Jul 9, 2013 - The small fabric conditioner compartment in the soap dispenser drawer has a plastic cap or tube at the back for the water to siphon up through. ... Make sure the washer is level front to back as well as side to side. .... If the washing machinehasn't been used since there's always the possibility that the plastic ...
The fabric softener part of my washing machine drawer keeps ...
www.mumsnet.com > Topics > Housekeeping
MumsnetAfter each wash, the fabric conditioner part of the drawer is f. ... The fabric softener part of my washing machine drawer keeps filling with water ... Stopped using thedispenser compartment for fab softener and instead did I separate ... see if that clears it up and also try cleaning behind the drawer in case there is a blockage.
Washing Machine ' Fabric Softener ' Problem ' Won't Empty
Jan 16, 2016 | Washing Machines
I have a Bosch Nexxt washer, model number WFMC 32000C/01. Yesterday I noticed the fabric softener was still in the dispenser after the cycle was completed. I cleaned out the dispenser and ran another...
Could be the fine holes in upper dispenser are blocked. Remove soap dispenser drawer and use a washing up brush to clean upper dispenser, replace drawer & test. If not could be upper dispenser or inlet valve.
Jan 10, 2011 | Bosch Washing Machines
My bosch nexxt washer will not drain the fabric softener into the load during the rinse cycle. The same amount I put into the fabric softener hopper is still there after the load is complete
Take out the drawer and clean the compartment and pipe at the end of the drawer with hot soapy water - washing up liquid works well. Clean all around it. To show this is working OK, put it in the sink and fill up the compartment with water until it is overflowing then stop. The water should drain out of the compartment on its own.
Next, where the drawer fits in the machine clean the water exit above the drawer with a washing up brush. This can appear brown or white depending on your water type. If this is OK try running the machine. If there is still a problem, remove the drawer again and turn off the power at the mains. Use something like a paper clip to poke all the holes in the water dispenser area above the drawer. There are lots of them so some patience might be required. If you live in a hard water area it could be blocked with limescale in which case an application of a descaling mousse or spraty will assist. Once complete, make sure you rinse the drawer area, drawer and put the drawer back in and run the machine on a short cold fill wash cycle. Put some fab con in the drawer to test that the machine drains it correctly. If all is well then there will be no fab con left. If it is still there then you will need to get into the water dispensing area to see what is wrong. Occasionally the mechanism can get jammed, lose a spring or just get broken, in which case it will need replacing.
Oct 22, 2009 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Fabric softener doesn't leave the dispenser
Oct 21, 2009 | Bosch Axxis WFL 2060 Front Load Washer
Fabric softener compartment blocked
The fabric softener section in the drawer on my washing must be blocked as the fabric softener is staying in the drawer. Does anyone know any way to unblock it
May 01, 2009 | Bosch Washing Machines
Hard scratchy towels. Have used all wash cycles, and use fabric softener
have you tried just white vinegar as your rinse aid. Do a full cycle of your washing machine using white vinegar instead of detergent, to clean any residue from pipes, and then in the next wash try white vinegar as your rinse aid.
Apr 18, 2009 | Bosch Nexxt 700 Series WFMC6401UC Front...
A mold smell from my washing machine
IMPORTANT: Read thoroughly. DO NOT add detergent or other laundry products to this cycle.
1. Remove all items from the washer.
2. Open the dispenser drawer and 2/3 cup (160 mL) of liquid chlorine bleach to the bleach compartment. DO NOT use more than 2/3 cup (160mL) of bleach per cycle as this will lead to product damage.
3. Close the washer door and dispenser drawer.
4. Select the Clean Washer cycle or a full wash cotton 104 F wash (40 C). DO NOT use any higher temperature as this will cause unnecessary fumes
5. Press Start and allow cycle to complete.
6. If the bad odour persists, repeat the procedure 1 or 2 more times. This may be necessary if this is the first time you have run this cycle.
7. After the cycle is complete, leave the door open slightly to allow ventilation and drying of the washer interior.
8. Repeat the cleaning procedure monthly.
To maintain the washer freshness:
1. Use only HE High Efficiency detergent.
2. Leave the door open after each cycle to for better ventilation and drying of the washer interior.
3. Use warm / hot water in your machine unless the fabric you are washing requires cold.
4. Use the correct amount of fabric softener.
5. If your laundry room is damp, use a dehumidifier.
6. Clean the door seal of visible residue.
Dec 28, 2008 | Bosch Classixx WFO 2466 Front Load Washer
My bosch classixx 1000 express wont take the fabric softener
take out the soap drawer and clean it there will b a blockage in the softener nozzle this will clear the problem
Dec 21, 2008 | Washing Machines
Fabric softener stays in drawre
I had this same problem to
If you take out the drawer of the washing machine and look upwards there are 4 very very small holes get a pipe cleaner and giver them a jolly good clean.
This should then solve the problem
Jul 07, 2008 | Bosch Classixx WFL 2066 Front Load Washer
Washing Machines Logo
385 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
