I have a Westinghouse Stackable washer dryer that is probably 10 yrs old. The washer door is locked and won't come unlocked when the spin cycle or whole cycle is complete.
    Brigadier General:
  • 6,277 Answers
I would gently suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my complete guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Apr 04, 2011
Our Maytag Neptune stackable washer MLE2000AYW stops after every cycle. I must manually click the knob to the next cycle for it to continue. I have also noticed that the fabric softener area doesn't...
Hello, can you determine if your machine shutsdown in the rinse cycles? If it does then the cause is probably the water inlet screens are clogged with debris. See Neptune Help FAQ #8 for more help.
I would be concerned about your door latch wax motor ( part # 12002535) though... See Neptune Help for more information about replacing the faulty wax motor with brown colored actuator tip before it damages your machine control board. When the wax motor shorts out it will blow the Q6 triac and then the R11 resistor will burn and your door probably won't lock anymore as indicated by the door locked light not coming on. The next thing you will notice is that your clothes will be soaking wet after the wash cycle because the spin cycle will not work if the door does not lock...
Your machine control board is located above the dryer on the right side.
Every Maytag Neptune front loader with a timer knob (non digital) has a wax motor and all of them shipped with faulty one except the later 2000 series stacker models. You should proactively replace the wax motor with the new design (with black tip) to prevent the Q6 R11 failure on the control board. If you're too late you can try the STAGE 1 repair kit at the same site above.
To inspect your door latch wax motor on the stackers you:
  • Unplug machine
  • Remove the (2) screws holding center panel and remove panel
  • Remove the (1) center screw holding the top panel located inside compartment above washer
  • Remove the top panel to expose the door latch assembly
    I hope this helps you.
May 24, 2011 | Maytag Neptune MLE2000A Front Load Stacked...
Ge stackable washer dryer MODEL wsm2700wbwww
3 year old GE stackable washing machine, had water coming out the top and would not drain or go through cycle, when shut off it drained a little but when turned on again it filled up and over flowed.
Apr 18, 2010 | GE Spacemaker Washer and Dryer Electric...
Washer won't drain or spin
YOU MIGHT BROKE THE DOOR SWITCH CHEC IT OUT FIRST... IT CAN BE BYPASS IF YOU WANT :) LET ME KNOW
Feb 21, 2010 | Maytag LSE7806A Top Load Stacked...
Dryer does not operate at all / flash of light
you broke the door switch
probably jammed it right through itself, and shorted out
it is a very easy repair
goto www3.sears.com
type in your model number
sellect the door list and look for the door switch
most run about 15 or so dollars
Oct 04, 2009 | Whirlpool LER4634J Electric Dryer
Excessive spin
I had this issue when I first purchased my stackable washer.. Because it was still under warranty, I had someone check it out. Apparently when it was installed they forgot to take out the security clamp that secures the unit during delivery.. duh!!
Jul 20, 2009 | Frigidaire GLEH1642DS Front Load Stacked...
Mle2000ayw Stackable washer/dryer not washing, spinning
If the door lock light is on then is might be the "door lock enable spin switch" the plunger at the opposite end from the wax motor is not fully depressing the switch. In the stackable it is just behing the door lock. Remove the two middle covers (2 white phillips screws and one hex head screw on the middle of lower cover by the wires)to test place a few layers of masking tape on the end of the plunger and cycle the machine. Might also be a weak Wax motor (dark brown in color) to be safe replace both for about $12 each. Fix in 10 - 15 min.
Apr 13, 2009 | Maytag MLE2000 Front Load Stacked Washer /...
Stops mid cycle, won't spin
You need to check and see if the door-lock light is on ,if not then you have either a faulty door lock mech. or a defective solid state board in the control panel
Dec 27, 2008 | Maytag Neptune MLE2000A Front Load Stacked...
Washing Machines Logo
22 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
