Question about Car Audio & Video
I disconnected the battery 1999 honda accord and the radio asked for a 5 digit code, but i don't know whatit is.
    Scholar:
  • 71 Answers
You must contact the dealership with the VIN of you car (found on the metal plate on the driver side of the dash up by the windshield) and some form of ID that you own the car. A Honda dealership should be able to give you this code then. It is an antitheft mechanism. They may or may not charge you, unfortunately. WRITE IT DOWN. You will need it any time you replace the batter or if the battery goes dead.
Posted on Apr 04, 2011
How to reset a radio code
Usually this happens when the battery has been disconnected or replaced. Or it's a replacement Honda radio. The Honda radio requires a 5 digit code to reset. You will need the serial number of the radio. You may need to remove the radio to get that info. Take a cellphone picture of the serial # to have it handy. Once you have the number, call your local Honda dealer and ask for the parts department. They should be able to get you the code for the radio based on the serial #. if not, you may need to take the car in for them to get you the code .
Sep 05, 2014 | 1998 Honda Accord
Radio is locked after battery disconnected
Look around for a small label with a 5 digit number on it. Look inside the glove box and console. You will need the 5 digit code to unlock the radio. To get the code you will need the serial # of the radio. In order to get the serial # it is necessary that you remove the radio from the dash or at least remove enough of the dash so you can see the serial #. The serial # is located on top of the radio chassis. Numbers that start with M1C, M3G, M46, & YEFM are not the serial #. Look for another number on the chassis. Now with the serial # and the VIN number off the car go to the Honda Owners Link and register your Honda. You will be able to get the code there for free, but you must have the VIN and Serial #. https://www.ahm-ownerlink.com/login.asp?page=%2Fprod%5Fhome%2Easp
Jul 13, 2010 | 1999 Honda Accord
I need my 5 digit code that ranges anywhere from 1 thru 6 for a 99 Honda Accord Coupe EX V6. My VIN number is 1HGCG2259XA022114. The radio is the Honda Factory stock radio single disc CD for that year. The...
If I'm for sure I don't think your digit code would be with the vin #. I would check your owners manual or ask a Honda mechanic. Hope this helps!?
Please rate solution - Thanks
May 18, 2010 | 1999 Honda Accord
Unlock code for radio 98 honda accord
Your battery must have gone dead or you replaced it.
Your car’s audio system will disable itself if it is disconnected from electrical power for any reason. To make it work again, you must enter a specific five-digit code in the Preset buttons. Because there are hundreds of number combinations possible from five digits, making the system work without knowing the exact code is nearly impossible.
You should have received a card with your manual(if you have one) that lists your audio system’s code number and serial number. If you don't have the card, you can get the code number from your Honda dealer, but to do this, you will need the system’s serial number, or maybe the accord's vin number.
If your car’s battery is disconnected or goes dead, or the radio fuse is removed, the audio system will disable itself. If this happens, you will see ‘‘Code’’ in the frequency display the next time you turn on the system. Use the Preset buttons to enter the five-digit code. If it is entered correctly, the radio will start playing.
Hope this is helpful.
Oct 25, 2009 | 1999 Honda Accord
My 1997 honda accord radio
Unlocking Error E3 on Honda AccordI had the same problem after my battery died and I didn't know what "Code" meant so I just pushed buttons until I got Error E3 and it locked up. You need to disconnect one battery terminal for 30 seconds or so, then reconnect, and the radio will say "Code" again. Type in the 5 digit code fount on the Anti-Theft Radio Identification Card (a white credit card size card that comes with the vehicle at the time of purchase). This will unlock the radio and return it to a functional state. It worked for me, so I hope that helps.
Try this
I discovered a very easy and FREE way to fix your radio. Make sure your radio is OFF. Hold down the preset buttons 1 and 6 at the same time. Turn the radio on and your SERIAL NUMBER will appear. 4 numbers first and then 4 more. Write them down (obviously) then call (800) 999-1009. Make sure you have your VIN number handy because they will ask for it. They will ask for your name and approx. milage, and your radio's serial number. They will then give you your radio unlock code--WRITE IT DOWN!
hope this helps.
thanks.
Sep 09, 2009 | 1997 Honda Accord
Need code to get my stock radio to work again in my 92 honda accord
Take it to your local dealer and give them the vin number and they can look it up for you or you can call them but they prefer you bring it in so they know it's not stolen.
May 30, 2009 | 1992 Honda Accord
Honda radio says ERROR E
You only get like 10 tries this means you made to many attempts trying to put the wrong code in. Disconnect the battery cable and then try putting the code in the radio again.
Feb 26, 2009 | 2004 Honda Accord
Radio unlock code
I need help fixing my radio on a 2006 Honda Accord...I could not find the code and after so many attempts my radio is saying ErrE and now i have found the code and now i can't start over with codes again....what can i do?
Aug 26, 2008 | 2006 Honda Accord
Code for honda accord 1999 car radio
sorry for bad news, but please rate me fixya!
this is why shops plug in a cigarette lighter plug battery before disconnecting car battery...you can make one yourself...
Jul 07, 2008 | 1999 Honda Accord
Car Audio & Video Logo
43 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
