Question about Garden
I forgot to put oil in gas mix. It ran for awhile then died and now won't start even with the right mix. Is it dead?
    Brigadier General:
  • 3,911 Answers
Yes it is dead, you need to buy another and toss that one. the lubrication in the fuel is a necessity, not an option. you many want to buy a four stroke device next time, they have really come down in weight and price, and that way you do not need to worry about oil in the gas anymore.
Posted on Apr 04, 2011
Why is my craftsman lawn mower keep shutting down every 5 feet or so. Its about 4 years old. Any suggestions?
Are you sure you have to mix the gas with oil.I don't think Craftsman engines mix the gas. It you have a dipstick that tells me that you put oil to the full mark on the stick. If your carb has a cup on the bottom of the carb take it off and clean it out. Also clean the fine holes out that's in the bolt as they get plugged with dirt.and engine won't run.Usually an air gun will do the trick. When you put it back together make sure the gasket is installed properly. If there is not much oil when you check it you could seize the engine.
Jun 29, 2014 | Craftsman Garden
2002 Chevy Tahoe ran out of gas got gas filled it up,started right up drove about 4 miles or less and died out again? Notice check engine light was on?and low engine oil flashed on the dash?So I put a...
you need to do the fallowing :
- make sure that you donr have a n oild leak some where look under the car
- u have a missfire in cylinder number 5 ( it colde be the spark plug or the coil )
if you wana go cheep , start by buying 1 spark plug and change it in number 5 if fix the problem ok if not , get the coil and change it
Jun 25, 2013 | Cars & Trucks
My craftsman 200mph/430CFM 25cc leaf blower will start and last for about 5 mins. on half choke and then die out and not start. It cant be put on run or it will die right away.eplaced spark plug. Still...
check age of gas. Cannot be more than 30 days old.
Make sure to use fresh gas w/synthetic 2-cycle oil @ 40:1 ratio (1 gal.) Gas to 3.2 oz. Oil). Do not use old or stale oil/gas mixture. Always use the proper oil/gas mix. If you do not, your engine will suffer rapid, permanent damage.May need to clean or replace carburetor.
May 12, 2012 | Craftsman Garden
Ran out of gas put gas in wont start,pulled spark plug and put a little gas in ,it fired but wont stay running,the primmer bulb seems to be not working
Hate to tell you this but if you didn't mix oil with the gas properly (most likely a 40:1 ratio) then the chain saw will seize up and won't work again.
Jun 17, 2011 | Garden
I have an audi a6 4.2 v8. it ran out of gas before i could get to the gas station and i tried to buy some gas and put in there. so i did and it still wouldnt turn on. so i got more i checked the oil and...
Check and replace if necessary the fuel pump. When the car ran out of gas the fuel pump was not cooled enough and worked with air inside, then fails more and more often.
Apr 30, 2011 | Audi A6 Cars & Trucks
Makes extra oil, has died & won't start, rplaced o2 sensor started and ran for a bit, has now died again??
It can't make oil. It must be fuel or antifreeze mixing with the oil. Is it running really rich and flooding the engine out? That would explain gas in the oil. Or do you notice the antifreeze level going down?
May 15, 2010 | 1994 GMC Sierra
Forgot to mix the fuel with oil in a chainsaw
If you didn't burn up the engine yet, DON'T USE IT. Dump the gas back in the can, and then mix the oil.
If you used it, and the chainsaw died, its done. Not worth even trying to fix. You could buy a new one for the price.
Nov 27, 2009 | Husqvarna Chain Saw 20" Bar
Lawn Tractor won't start after wrong fuel used, drained, etc
Check the fuel shutoff solenoid (on the bottom of the carburetor -- has a wrie plugged onto it) -- it may be sticking.
Spray carburetor with carb cleaner. Then if you can get it to run long enough to do any good, put carb cleaner in the fuel -- follow mixing proportions on the label.
If this doesn't work, need to take carb apart and thoroughly clean it.
Charlie
Aug 29, 2009 | Garden
Chain saw emitted sparks and now does not start.
Hi
When the engine get warm and die(I suppose)check the spark at the sparkplug.You can let the saw run until it ran out of gas and you will not distroy the engine.Change the sparkplug.
best regards savumihai71
Dec 16, 2008 | Garden
Garden Logo
149 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
