Question about Panasonic Microwave Ovens
NE1757 commercial microwave display is F 82. What is the problem?
I downloaded Panasonic's error code pdf file and troubleshot from there.
Posted on Aug 07, 2008
6ya staff
SOURCE:
Amw528 error5
Microwaves have fault codes to help us determine the problem. Click the link below, it will take you to the Panasonic Combi Microwave site. Look at the manual closely. Either the fuses are blown or the microprocessor board is fried. Good Luck and be careful! Safety first! Commercial Microwave Ovens Large Microwave Commercial Kitchen Appliances...
Feb 05, 2016 | In Microwave Ovens
Display door open?
the door spring has probably snapped and just needs replaced
Aug 15, 2014 | Merrychef eikon e5-1530 Commercial...
How to remove call service
The messages probably will go away after the microwave is serviced.
Jun 02, 2014 | Amana rfs518s commercial microwave...
F 14
I do not see an error code F 14 in the error code list. Is it posssible you have a display with some segments out and the 4 is actully a different number?
Apr 09, 2014 | Panasonic Pro NE1757 Microwave Oven
F 82 code
Call an authorised Panasonic appliance company to repair your microwave. It needs either a magnetron or an invertor board, or both.
Feb 04, 2011 | Panasonic Pro NE1757 Microwave Oven
What does F-82 mean?. it is flashing on the display and the Microwave is not working. Thanks
F82 means there is no power being supplied to the lower high voltage transformer. It may be due to:
- failure of relay RY-4 on the circuit board
- 10A fuse open
- controller failure
We have the service manual and have uploaded it to our site here to help you.
You can order parts from Encompass here or you can call them toll-free at 866-779-5835.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more free information & help.
William E. Miller, AS-EET
[email protected]
http://www.microwavedisplay.com
Microwave Oven Control Panel Repair Nationwide
Jun 17, 2010 | Panasonic Pro NE1757 Microwave Oven
Parts breakdown for panasonic ne-1757
The suffix will make a difference, but the two service manuals are here http://www.microwavedisplay.com/NE1257A_C_NE-1757A_C_NE-2157A_C_sm.pdf AND here
http://www.microwavedisplay.com/NE1257R_CR_NE-1757R_CR_NE-2157R_CR_NE-1258R_sm.pdf
Sep 10, 2009 | Panasonic Pro NE1757 Microwave Oven
Amana microwave RC17
There is a bulletin that shows how to reset this code on Amana commercial microwaves.
We have uploaded it to our site here to help you.
Oct 03, 2008 | Amana RC17 Microwave Oven
F82 code
If it's a Panasonic commercial model (NE1757,NE2157), check the two fuses first. If one is blown, first take a look at the upper door switch to be sure it's activating. If that and the bracket look ok, you most likely have one of the following parts that need to be replaced...
Fan motor, HV Transformer, or Magnetron tube (or a combination of). Also look at the two white wires going to the middle relay on the lower relay board. If they're burned, you'll need this board and possibly one of the above parts as well.
Jun 30, 2008 | Panasonic Microwave Ovens
Keypad problem
You have a defective membrane keypad, but both that part and its replacement is shown as being no longer available. About your only hope is to contact local shops to see if they may have a salvage unit with a good keypad. They should be able to swap what's called the "escutcheon" or front panel frame. The keypad for models NE1057 and NE1257 was the same, too, in case they may have one of those. These were pretty neat microwaves, mostly used in commercial environments. Sad to see it go. Good luck.
Nov 09, 2006 | Panasonic Pro NE1757 Microwave Oven
Microwave Ovens Logo
144 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
