Question about Dishwashers
How to use a 'leisure DWLT 48' dishwasher? - Dishwashers
Dwlt 48 integrated.Dishwasher wont start cycle...can hear it trying but no water coming in. Filter seems blocked but have no idea how to get to it to clean it.
Might be a clogged filter. Try searching on youtube for a video I saw called KitchenAid Dishwasher Repair. He documents taking out the racks, tools you'll need and what to do. Hope this helps, good luck.
Aug 09, 2016 | Dishwashers
My Intex spa is reading error code 90. We have put new filters on cleaned it all.
Take a look here...
Intex HongKong Limited Service Center
or...
JOHN ADAMS LEISURE LTD MARKETING HOUSE, BLACKSTONE ROAD,
HUNTINGDON, CAMBS.PE29 6EF.,
UK TEL: 0333 400 45 48 FAX: 01480 414761 WEBSITE: http://www.intexspares.com EMAIL: sales@johnadams.co.uk
Apr 22, 2015 | Intex Pool & Spa
The power button is crackling when i turn my Leisure DWLT65 dishwasher on. is it the power switch?
Hello. Here is the link to the power button for your unit. Most likely, the contacts inside the switch have worn out causing arcing--hence the crackling sound you heard. I would not use the washer until you get the switch repaired! If the internal contacts are not touching properly, heat will be generated and could cause the switch to melt, thereby creating a real safety hazard(I've seen this happen). Leisure DWLT65 On Off Power Switch I hope I helped you!
Feb 23, 2015 | Leisure Dishwashers
Not emping water
This is a generalize answer, but remove the bottom kick panel to manually rotate the pump motor. In general they can get locked up by objects. Locking up the pump.
May 26, 2014 | Leisure DWLT65 Dishwasher
Dishwasher will not start after being switched on- can you help
Here is the link to the power button for your dishwasher: http://www.amazon.co.uk/Leisure-DWLT65-Off-Power-Switch/dp/B00O470CVM. I hope this helps you!
Jan 03, 2014 | Leisure DWLT65 Dishwasher
Where do i buy replacement parts for 10'x8' US Leisure shed
where can i buy roof panels for leisure storage shed
10 ft x 8 ft
Nov 24, 2013 | Us Leisure Storage Building. Stronghold 10...
My leisure dwlt65 dishwasher keeps switching its self off when going till wash
see this causes and fix it. God bless you
Touchpad and Control Panel If the buttons don't work on the control panel the entire touchpad and control panel assembly may need to be replaced. If the display works but the dishwasher functions are all out of synch, or some of the buttons don't respond properly the entire touchpad and control panel might need to be replaced.
Touchpad If the buttons don't work on the control panel, the dishwasher touchpad might be at fault. Generally speaking, if the dishwasher display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad.
Main Control Board The dishwasher has a main control board which regulates nearly every function in the dishwasher. If the control panel buttons don't work, and other causes have been have ruled out, the main control board might need to be replaced.
Sep 28, 2012 | Leisure DWLT65 Dishwasher
Dishwashers Logo
155 people viewed this question
Top Dishwashers Experts
