Question about Acer Computers & Internet
When switch on the power button the led will lit for 1 sec. then turn off
  • 32 Answers
Try cleaning the gold plate of the RAM using an pencil eraser. Be careful on touching the gold plate.
Posted on Apr 04, 2011
Where and what does the reset switch for the 1996Volvo 850 lookslike
Volvo 850 (1993-1995) Service Light Reset
Under the hood there are 2 diagnostic units (labeled A and B on the cover) next to the washer reservoir.
1. Turn on the ignition and open diagnostic unit A.
2. Locate the flylead (the test wire that is in the plastic holder).
3. Insert the flylead into socket 7.
4. Press the large round test button on the diagnostic unit 4 times, briefly but firmly.
5. When the LED flashes and then stays lit, it will accept the reset code.
6. The reset code for the service light is 1-5-1.
7. Press the large round test button firmly one time and then release it. The LED should be lit.
8. Press the button firmly 5 times and then release it. The LED should be lit.
9. Press the button firmly one more time and then release it. The LED will flash several times.
10. Turn off the ignition switch and replace the flylead in its holder and close the cover.
The Service Light has now been reset.
May 13, 2015 | 1996 Volvo 850
Power led light on when pressing power it tuns on and goes of right away? power still lit..
I have the same problem, did you figure out what the problem is and solution by any chance? i purchased it recently, it started doing this the night after i left it on for the night. next day everytime i turn on, it turns off in 2 sec. after a month i tried a shot, it started and stayed up for 1 min may be... then same thing again 2 sec. i guess i have to wait for a year to turn it on .
garden led light
May 29, 2012 | Office Equipment & Supplies
Reset counter
By the way, what is the make and model of your printer?
  1. Resetting the Drum Page Counter
    • 1 reset-counter-dell-laser-printer-1.1-800x800.jpg Toggle switch in back of the printer. Shut off the printer.
    • 2 reset-counter-dell-laser-printer-1.2-800x800.jpg Front door opened Hold down the "Continue" button while opening the front door. Then turn on the printer.
    • 3 reset-counter-dell-laser-printer-1.3-800x800.jpg Error LED lit Keep the Continue button held down until only the "Error LED" is on then release the button. Close the door.
    • 4 reset-counter-dell-laser-printer-1.4-800x800.jpg Top 3 LEDs lit. The Continue button, Ready/Data, Toner Low, and Load Paper LEDs should all be lit up.
    • 5 reset-counter-dell-laser-printer-1.5-800x800.jpg Toner low LED lit. Press "Cancel" a few times to cycle through the LEDs until just the "Toner Low LED" is lit.
    • 6 Press and hold the "Continue" button until the LEDs cycle through and release only when the LED stops at Toner Low.
    • 7 Turn the printer off and back on.
I hope you find it very helpful. Best regards.
Aug 16, 2011 | Office Equipment & Supplies
NOTE BOOK SCREEN DOES NOT COME ON
Screen does not come ON or not showing any display even the power LED is lit. Sometimes it is due to the laptop was not shutdown properly or the battery was drained or laptop was left idle. This is a simple solution that may fix the problem. If the power LED is lit, turn off the NB, remove all the power sources (battery and charger). Without the power sources, hold the power button for 10 secs and put the power sources back and turn ON the laptop. If this doesn't resolve the problem, it needs to be checked for possible Motherboard problem.
Hope it works!
Mar 12, 2011 | Acer Aspire One PC Notebook
Error 5 code is what
A) E5, E6 or E4 - it is cartridges error - to fix press the "stop\reset" button for 5-7 sec. and then release
it.
B) E27 - it is code for reset absorber (EEPROM reset or Waste
ink counter reset) and follow the described below
procedure:
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting for menu selection)
4) When the on/off lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
orange and green, starting with orange.)note: press 4 times for waste ink counter reset.
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset
5) Turn off the printer.( it must be turn off)
then turn it on again.
Only in B) case you can enter into "service mode", in A) case or if have e.g. paper jam, or another error you CAN'T enter
the "service mode"
Try it
Anonymous see A) case: E5, E6 or E4 - it is cartridges error - to fix press the "stop\reset" button for 5-7 sec. and then release
it.
Mar 23, 2010 | Canon PIXMA MP190 All-In-One InkJet...
My wrt300n power led is blinking and the rest of
Hi Friend
Please follow the steps to reset the router in a different way
1) Press the reset button for 10 secs and after that unplug the power cable from the router and wait for 10 secs
2) Plug the power cable back and press the reset button again for 10 secs and after that unplug the power cable from the router and wait for 10 secs
3) Plug the power cable back and press the power button for 10 secs again and unplug the power cable from the router for 10 secs
After trying these steps if you see the power light still blinking then you need to replace the router. Please call the customer care of linksys 1800 546 5797,they will let you know how to replace the router
warm regards
Chiranjeet Mitra
Oct 06, 2009 | Linksys WRT300N Wireless Router
My 4100b is flashing ethernet green and power green that's all.
Hello I have the same modem and it had the same problem where it only lit the Power and the Ethernet LEDS. It is Quite easy to fix. All you have to do is Hard Reset it because soft resetting it wont do.
To hard reset it: 1. Hold the Reset button on the back of the modem for ~10 sec. until it resets itself. 2. >>Before all the LEDS disappear and only show power then Ethernet<< turn it off and unplug all the connections. Leave it unplugged for a few hours just to make sure that it goes back to Factory Default setting.
After that, plug everything in and turn it on.
Now, if it does not change and returns to normal. Press the Reset button while all the LEDS are lit then quickly unplug the 12vdc plug and wait.
If this fails, Search google for forums that mentions this similar modem ad same symptoms and see if they have a solution.
Hope it works, GOOD LUCK!!
Jul 09, 2009 | Siemens SpeedStream Modem (4100) (SS4100)
Satellite a135-s2356 aill not boot up
a friend had same issue , i dissembled laptop and found a burnt diode chip beneath where power button sits on top cover panel there are two clips under power button , one of the clips shorted the diode , only orange power button would lit up on front edge of lower case
Apr 25, 2009 | Toshiba Satellite A135-S2356 Notebook
Power LED on but no boot up
it could be your power switch, veriy that it isnt the power supply by
1.) un-plug it from the main board
2.) look at the main board connector(one coming of the power supply)
3.) you should see green wire and next to it a black one
4.) using a paper clip bridge the too wires
5.) if it works proceed to net step if not get a new power supply
to check case switch and board switch
1.) plug in power supply to main board
2.) look at the pins where the power button connects to
3.) using a metal object (blade screw driver) bridge the pins
if the board should start up>
then its your power button on the case that is bad, you can try to repair it, chage it or buy a new case,
if it doesnt work.
1.) ensure that jcms(jumper to flash the bios) is set correctly
2.) unjack each drive one at a time to see if any is causing stalling
3.) get a new main board
Jan 02, 2008 | EliteGroup L7VMM2 Motherboard
SHR 1040 "Froze Up"
You can try holding down mode and channel 2 at
the same time for 10 secs. This should reboot the recorder.
Dec 23, 2007 | Samsung 4 Channel Dvr
Computers & Internet Logo
19 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
