Question about HP LaserJet 9500n Printer
HP 9500 hdn - error message 57.50. If I replace the fuser kit will this solve the problem?
2 Suggested Answers
seeker5211
  • 1089 Answers
SOURCE: hp 9500 hdn - error message 57.70. Can I relace
No!
The 57.7 error says that the fuser fan could be bad.
If you take the back cover off the printer and look to the right, you will see two fans, one above the other.
The bottom fan is the one you want. It is probably clogged with dirt or else the dirt got inside the fan and is preventing it from spinning. Replace it
Posted on Apr 04, 2011
Getting a 50.6 FUSER ERROR on a HP color Laserjet 9500 printer. I bought the image fuser kit and replaced it. Still getting the error. Suggestions?
check the connector that the fuser connects to for damage. If the plug is intact you will probably need to replace the power supply (Low Voltage PS) C8546-69003 is the part number
on a unit of this vintage the part won't be cheap. A quick search on the net shows it from $350 - $600
Good luck
Dec 04, 2015 | HP LaserJet 9500n Printer
I keep getting a "replace fuser kit" message on my
If you replaced with new fuser even getting same error, then check,
>Check the fuser connector (J5001). If
it is broken or damaged, replace it.
>. Check the connector (J1025) on the
DC controller PCB.
>. Replace the DC controller PCB.
Oct 07, 2011 | HP LaserJet 4700 Printer
Hp 9500 hdn - error message 57.70. Can I relace the fuser kit to repair the problem?
No!
Apr 04, 2011 | HP LaserJet 9500n Printer
HP laserjet 3600 error message 50.9 Fuser Error
Thank you for the inquiry.
Yes you will probably have to replace the fuser. If this is a new printer still under warranty and the page count has not reached the service life of the fuser, contact HP for warranty replacement. Once the new fuser in installed you will need to restore the service count.
nav?h_pagetype=z-001&h_lang=en&h_cc=us&h_client=z-a-r1002-1&h_product=501046
Fuser Kit Part Number: (Sometimes Called a Maintenance Kit)
RM1-2665 This fuser is compatible with the following printers: HP Color LaserJet 2700, 3000, 3000N, 3000DN, 3000DTN, 3600, 3600N, 3600DN,
Link to Installation pictures and instructions:
http://printertechs.com/tech/mkinst/3000/mk-3000-2fuser.php
Restoring the maintenance count after installing new fuser.
This printer tracks the number of pages printed on the fuser, and a reminder message will appear when the fuser reaches a certain page count. The message will instruct you to replace your fuser. Whenever you install a new fuser, you should reset the fuser page count so the warning message will not appear prematurely.
To reset the fuser count :
1. Press MENU to enter the MENUS.
2. Press Down arrow to highlight Configure Device.
3. Press Checkmark to select Configure Device.
4. Press Down arrow to highlight RESETS.
5. Press Checkmark to select RESETS.
6. Press Down arrow to highlight RESET SUPPLIES.
7. Press Checkmark to select RESET SUPPLIES.
8. Press Down arrow to highlight NEW FUSER KIT.
9. Press Down arrow to select NEW FUSER KIT.
10. Press Down arrow to highlight YES.
11. Press Checkmark to select YES.
The fuser count will be reset and then the printer is ready to use.
Thank you for being a FixYa Valued Customer.
Hope this helps helps. Please keep us updated and remember to rate this answer.
TF
Jan 19, 2011 | HP LaserJet 3600 Printer
Hp color laser jet 9500 hdn i have this message error 49.4c02
Unplug the printer from the pc or the network to clear the error, the upgrade the firmware.
Jun 09, 2010 | HP LaserJet 9500n Printer
I have an hp LJ 9500 and the paper keep jamming
first check for the life of maintenence kit if it expires then
replace the maintenence kit / clear the position where the paper jaamed
in maintenence kit all the roller & fuser replaced .
Apr 27, 2010 | HP LaserJet 9500n Printer
Hp colour laserjet 9500 hdn with noise and fuser error 50.6 .
Look at fuser rollers and make sure the new one doesnt have spacing to far in between rollers. Also on front side of fuser there is a big connector that meshes with one inside machine. The fuser connector assy RG5-5925-000CN could be broken as well
Jan 21, 2009 | HP Color LaserJet 9500HDN Printer
HELP! 3 year old HP color Laserjet 3500 Installed first fuser kit...error message 50.2 fuser is hot message. Worked through directions; same message appears repeatedly.
The connecter between Fuser and printer is not connected properly. Reset the fuser.
To remove the fuer fuser and measur resistance between the fuser connectors J50132A-2(mainth)and J50132A-1 (gnd) if it is not within the range of 330k ohms TO 50k ohms at (abient temp) Replace the fuser.
Oct 08, 2008 | HP Computers & Internet
HP Laserjet 9500 HDN
magenta motor is knackered, change it. the clunking noise when printer starts up is the fuser gears meshing together, nothing to worry about. you can change/swap the motor with another motor and see if the startup error message changes from 59.6M(magenta) to 59.C(cyan) or something similar.
Apr 03, 2008 | HP LaserJet 9500n Printer
HP LaserJet 9500n Printer Logo
265 people viewed this question
Seeker5211
Seeker5211
