Question about Citizen IDP-3210 Printer
Will not print, goes thru the motions but no ink on paper
My selphy going through the motions of printing but nothing is on the paper
100 pics is a lot of ink
have you replaced the cartridges to fix the problem
Oct 29, 2016 | Office Equipment & Supplies
My printer will not print. it goes thru the motion but nothing prints
The ink-jets that spray the ink onto the paper may be clogged; run a few "print-head-cleaning" cycles. Also, check that you've not run out of ink.
Feb 26, 2011 | Dell V313w AllInOne InkJet Printer
Brand new Casio HR-150TM pringting calculator will not print. It goes thru the motions, but acts as if there is no ink. I can touch the printing wheel and will have ink on my finger, but nothing on the...
There is a plastic protective strip on the printing area. You have to take the ink pad off to remove the strip. Then evry carefully put the ink pad back on. You may need to wiggle the ink pad back on to make sure the black AND red ink is fully engaged. Now if I could just find a manual telling me what the rest of the buttons are for. This user manual is terrible!
Aug 10, 2010 | Office Equipment & Supplies
Printer goes thru printing motions, but the paper is blank,
Have you upgraded any software recently? I suggest you go to Dell website, download & install new printer drivers. After all, teh printer just prints what the software tells it.
Oct 19, 2009 | Dell 926 All-In-One InkJet Printer
Mac OS 10.5.8 HP Photosmart C3180 does not print
Exactly what I'm experiencing, it goes though all the motions, but no ink is on the paper. I just installed 10.5.8 last night on my Mac Pro. The drivers are up to date, but no ink hits the paper.
Sep 22, 2009 | HP Photosmart C3180 All-In-One InkJet...
All 8 new ink cartridges, new MT tank, nothing prints. it goes thru the motions of rinting, but no little to no ink is on paper, less and less ink each subsequent print. Most recent print has a hint of...
take your ink cartridge out from your printer. you can see at the ink carriage there are little pipes where the ink usually flow from cartridge. If head cleaning and power cleaning does not work, then try to clean those pipes by using 96% alcohol fluids and **** the pipes using something.
Sep 12, 2009 | Epson Stylus Pro 4800 InkJet Printer
Lexmark x1240 will not print
did you tried to set the properties to mono ?
Apr 12, 2008 | Lexmark X1240 All-In-One InkJet Printer
Wants to print but won't put ink on paper
I'm experiencing the same problem. I tried to troubleshoot through software that came with printer, but no luck. Here's what happens:
The printer worked great for a month or so. Then, I didn't use it for a few months. When I tried to use it again, it acts like it's printing. My computer shows it's printing, the printer runs through all the steps, including moving the print cartridges back and forth over the paper as it should, but no ink comes out on paper.
Any suggestions?
Nov 05, 2007 | Lexmark X1270 All-In-One InkJet Printer
Citizen IDP-3210 Printer Logo
Top Citizen Office Equipment & Supplies Experts
jay kaye
jay kaye
Roy May
Are you a Citizen Office Equipment and Supply Expert? Answer questions, earn points and help others
