Question about Samsung YP-P3JCB Digital Media Player
Some of the spot on the touch screen won't work .Is there a way to ajust the touch screen
How does a touchpad work on laptops
a touchpad works off the static electrical charge that resides all living tissue as far as I know. if you were to statically charge that piece of metal you are referring to, it would work. as far as why the mouse pointer doesn't jump when you touch a specific spot on the touch pad is because people, in general, don't want it to so the software that controls it has been designed not to.
Jul 06, 2014 | Computers & Internet
Screen getting darker and color will not adjust
THIS LOT FAULT AJUSTMENT YOU ARE ELECTRONICS PERSON TAKE 25 W SOLDERING IRON RESOLDERING TO CRT NICK BORAD OR AJUST ON LOT, WATCH BELOW VIDEOS
NOTE:DONT TOUCH LOT ON SUPPLY
DONT TOUCH LOT&CRT LINKING PLACE WITH OR WITH OUT SUPPLY
SEE :LOT(LINE OUT PUT TARASFORMER) IMAGE ON GOOGLE
Mar 23, 2014 | Mitsubishi WS-65819 TV
Big gray spot on screen
Unfortunately, It's likely that your screen has been irreparably damaged. Probably, pressure was applied to the screen and ruined that part of it.
If you like to fix electronics, it may be possible to buy a non-working Sansa on eBay, open the case and replace the screen.
You can probably continue to use the player without fixing the gray spot. If it bothers you, the easiest solution would be to get another player....
Dec 03, 2011 | SanDisk Sansa Audio Players & Recorders
How to align screen e755 pocket pc
To align your screen
select Settings, System, Align Screen to ajust the touch screen,
If the screen alignment loses calibration it may not be possible to adjust alignment useing the above method.
In that case the align screen command can be executed by simultaneously pressing the power button and scroll button.
useing the stylus when comanded touch the cross hairs and the Pocket PC will align the screen
Feb 24, 2011 | Toshiba e755 Pocket PC
Touch screen doesn't work in some spots on my Pioneer AVIC-D1 GPS system.
THIS IS A COMMON PROBLEM WITH THIS UNIT. A PIECE NEEDS TO BE REPLACED INSIDE IT. CAN BE FIXED FOR $175. INQUIRE AT OUR SHOP
WWW.AUDIODEZIGN.COM
Jan 18, 2010 | Pioneer AVIC-D1 In-Dash Mobile Navigation...
My Htc Touch pro screen, looks like it has a large wet spot in the middle, i know for a fact it hasn't been near water, my screen is totally visable but not able to use by touching the screen, what could...
I suggest taking it to your compaany store but before you go to the store and have them tell u the phone is water damaged, you can save yourself the trip by looking for yourself. There should be a little square located in the back of you phone right below the battery and a little square locatedd on the batery where it connects to the phone. If the phone has water damage then the littl e squares should be red if they dont have water damage, the squares should be white with a plaid kind of design.
Jun 17, 2009 | HTC Touch Pro Smartphone
Iphone screen smashed, touch still works but white spots
If hard resetting and restoring it doesn't work you have a broken LCD screen. There is an iphone repair guide website that shows you how to replace the screen yourself.
Mar 18, 2009 | Apple iPhone Smartphone
Htc touch screen not working.
Hi, I had the same problem. Whenever, I touched my screen the wrong things would respond, then finally one day my phone locked & when I tried to unlock it the screen wouldn't respond at all.Took my phone to 3 sprint stores and all the techs couldn't help. One even accused water damage or overheating because they saw spots under my screen. But I never wet my phone so I thought it might be overheating since I do live in a warm climate. They all tried to get me to buy a new phone, which seemed like a scam. I didn't want to hard reset & lose all my data so I looked closer at the screen & noticed the spots didn't look like water spots & peeled the screen back. I noticed that the glue from around the screen actually leaked onto the screen, so I dampened one end of a q-tip & wiped the glue off the dryed it with the other end. I turn the phone back on and the screen worked fine. Try cleaning thr screen before doing a hard reset or paying for a replacement phone. It'll save you time & headache.
Hope this helps =)
Jan 09, 2009 | HTC Touch Cell Phone (Unlocked) - Soft...
Green spots
have you tried doing convergence from the menu? and them magic focus?
Oct 22, 2007 | Hitachi 61SDX01B 61" Rear Projection...
A magnet touched my screen
My son touched my television screen with a magnet in two spots leaving two discolored areas on the screen,purple and green in hue. I read many quick solutions to this problem on the net and none seemed to work completely,so what i did is took the same magnet that touched the screen and held it in my fist,then with TV on i waved my fist all around the screen working from the spots outward to the edges and this worked completely! Hope this helps someone..
Apr 04, 2006 | Sanyo DS27800 27" TV
Samsung YP-P3JCB  Digital Media Player Logo
59 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electro Med Services...
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
