Question about Maytag Dishwasher
My GE Quiet Power 3 has always been quiet but the past week it has gotten progressively louder and now the motor has a 'growling' sound. Is this possibly a motor or bearing issue?
  • Maytag Master
  • 3,053 Answers
Hello, cattleshan
I was trying to help you out here. I am not sure if this well help you? But here is a link to about everything you want to know about your dishwasher, from repair to trouble shooting on most common dishwashers. If you go to this link and click around, I am sure you will find out so much about your Dishwasher, you will know more that the company that made it.If you already solved the problem this is good for future problems. Here Is the link for you to click on.
http://home.howstuffworks.com/dishwasher.htm
Please if this helps you at all, and if you can find the time to rate my help and some kind words written would be appreciated for my free help. Here is also my direct link to my own pages of other areas of my expertise for other problems you might have in Automotive,Appliance, and Electronics. Drop In anytime for my help. Thanks So Much, Mike :)
http://beta.fixya.com/users/mc1bean
Posted on Oct 27, 2011
We have an 05 Pacifica Touring. No engine problems yet.(read a previous post, all Pacificas eventually burn oil) However we have a whining sound coming from the rear. go slow(5mph), no sound, as you...
have you looked at the tires- if they are wore down the wear bars-little bands of rubber that cross the grooves in tread will be exposed and the noise is your warning to get new tires soon
Jul 30, 2011 | 2005 Chrysler Pacifica
2005 mazda 3 manual trans 2.3L, when youre driving the car with windows rolled up and any gear change or speed you can hear a constant growling noise like two gears meshing together, was told it was warped...
Sounds like bearings to me. Jack car up and check for play. may be hard to detect. May only be on one side. car is kind of new to have bearings going out. That it is quiet on turns is usually a dead giveaway, but usually only gets quiet when turning a certain direction and not the other.
Sep 26, 2010 | 2005 Mazda 3
I HAVE A 1996 GMC WITH A 154000 MILES ON A 5.7L ENGINE. IT ALWAYS HAD A LITE VALVE TAP WHEN IT FIRST STARTED, ESPECALLY IN THE COLDER MONTHS. THE LAST COUPLE OF WEEKS THE VALVE TAPPPING HAS GOTTEN LOUDER...
try putting lucas in it. that is a temp. fix altimtley you will need to replace the valves. also try running high test gas and see if that helps quiit it down at all
Jul 11, 2010 | 1996 GMC Sierra
I have had the GE top frezer a little over 2 months...Afew weeks ago I noticed a noise starting , a kind of weird noise....(its not the ice maker....I turned that off a week ago and it still does it....the...
Sounds like the defrost timer doing its job but with loud efforts. GE is known for its different sounds some clanks to clicks to popping. Thank God for good hearing but curse GE for its poor noise reduction efforts. This is why GE is cheaper than its other competitors. They cut corners welcome to the world of GE. BB
Dec 15, 2009 | GE Refrigerators
Makes growling noises throughout the cycle.
HI. here are the most common issues that will cause a noise during the wash.
* Check the spray arm for damage and obstructions
* Check the inlet filter screens
* Test the water inlet valve(see below for test procedure)
* Check the motor and mounts- The motor may e loose or one of the mounts may have separated form the housing. this will cause mis-alignment.
* Check the fan motor and blade
* Check the drain for obstructions
NOTE
If all checks out above, the culprit will be a cracked pump impeller. this will occur if the drive stud becomes unstable, allowing the impeller to partially separate form the motor spin drive stud. this will cause the impeller to rub or grind during the wash cycle. If this is the case, there are impeller repair kits available for purchase that will correct this issue.
Sep 25, 2009 | GE Dishwashers
Spin cycle is very loud, used to be very quiet.
It could be Quite a few things either not level to the ground or off track on the inside. try running washer without clothes see if it still makes that sound.
Jun 25, 2009 | 2006 Maybach 62
Engine noise,a dull hissing, slight grinding sound
Take the vehicle for diagnosis. this could be the same as a nocking sound no matter how you service your vehicle. It might be over working.
Mar 21, 2009 | 1997 Toyota Tacoma
Goodman ac condenser, Loud and wet
Over charged with refrigerant>
Sep 12, 2008 | Heating & Cooling
Maytag Dishwasher Logo
132 people viewed this question
Top Maytag Dishwashers Experts
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
